After installing SSH and VPN I find that when I set up to run 'locally' (i.e. with a keyboard, mouse and monitor instead of headless) I get the following error on entering startx
: /tmp/.X11-unix has suspicious ownership (not root:root), aborting
(there may well be a lost character at the start because the screen is out of alignment)
and the GUI fails with a message about being unable to connect to X server
I can't see any mention of this error message in the forum (apologies if I've missed it), but it comes up a lot using Google, mostly in Debian bug discussions which are way beyond me.
I don't quite see how the ownership of any file could have changed so that root access isn't possible, or am I misunderstanding the message?
I'm aware that I could easily make matters worse if I start blundering around at random. Anybody offer to guide me?
Re: suspicious ownership (not root:root)
Background: /tmp/.X11-unix/ is the directory that contains the special socket files that X clients use to connect to a local display server. There can be multiple X servers running on a machine, and they can be running as different users. To ensure that users can create a new socket file, but cannot delete or rename other users' existing files, the containing directory needs to be owned by root (and world-writeable with the sticky bit set).Threlkeld wrote:/tmp/.X11-unix has suspicious ownership (not root:root), aborting
If you have rebooted since your first post it is likely that /tmp will have been cleared and startx will now work. Otherwise it is totally safe to try changing to the correct permissions and ownership yourself: "sudo chmod 1777 /tmp/.X11-unix" and "sudo chown root:root /tmp/.X11-unix". At the very least, this should change the error message that startx gives.
(My first guess as to the cause of the problem is that you may have started a VNC server as the first X server in a given boot. VNC servers do not start with root privileges because they do not need direct access to hardware. So if they have to create the .X11-unix directory they will do so with the wrong ownership.)
Grateful thanks, jojopi, that's helped a lot.
I had rebooted, several times, and found that the problem persisted.
Manually resetting the permissions and ownership using the two commands you listed then enables me to run startx successfully. Great!
However, powering down and rebooting recreates the problem. Is this because I'm firing-up the VNC server as part of the boot sequence, I wonder?
Anyway, a bit of fossicking around should enable me to sort out a complete solution. Thanks again!
We had the same issue today and solved it by entering jojopi's cmd's into to vncboot script (see URL for instructions about creating the script and the changed script in CODE)
http://elinux.org/RPi_VNC_Server
### BEGIN INIT INFO
# Provides: scriptname
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start VNC Server at boot time
# Description: Start VNC Server at boot time.
### END INIT INFO
#! /bin/sh
# /etc/init.d/vncboot
USER=root
HOME=/root
export USER HOME
case "$1" in
start)
echo "Starting VNC Server"
#Insert your favoured settings for a VNC session
sudo mkdir -p /tmp/.X11-unix
sudo chown root:roo /tmp/.X11-unix
su pi -c '/usr/bin/vncserver'
stop)
echo "Not stopping VNC Server at the moment, on the todo list"
echo "Usage: /etc/init.d/vncboot {start|stop}"
exit 1
esac
exit 0
Yes, confirm that sorts out the problem for me as well. Great!
[ small typo:
should of course be
[ small typo:
should of course be
Bet you roo the day you made that typo...
