Bikko
Network freezing up? + mouse
Wed Jun 13, 2012 10:11 pm
Hi
Just got a D-link powered USB hub (6 ports)
When connecting it to raspberry PI you can run HDD, keyboard, USB pen drive and other things fine from it
As soon as you connect a mouse to the hub or to the board the raspberry Pi network connection just dies and can't browse the network at all.
Everything else is fine and the pi doesn't slow down it's just network card
any ideas?
grumpyoldgit
Re: Network freezing up? + mouse
Wed Jun 13, 2012 11:24 pm
Try a different mouse.
Bikko
Thu Jun 14, 2012 3:41 pm
Tried 3 different mice and still same
grumpyoldgit
Thu Jun 14, 2012 5:15 pm
A good starting point would be to get yourself up-to-date.
sudo apt-get install update
sudo apt-get install upgrade
Then the instructions on
https://github.com/Hexxeh/rpi-update
There are quite a few threads about rpi-update, which updates the firmware. I had an issue with a freezing mouse and keyboard after I moved the file system to a memory stick. The various upgrades eventually sorted out the problem.
marsman2020
Fri Jun 15, 2012 12:01 am
You may be running into a bug with the USB on the Pi. See https://github.com/raspberrypi/linux/issues/29.
Can you try a different powered hub?
Does the network connection die only in X/LXDE or does it die in the console as well?
Were all 3 mice Logitech mice?
