Rpi and Kali
Posted: Sat Jul 26, 2014 2:51 pm
by arwald
Hi guys, I'm new here, as i recieved my raspberry few days ago.
I'm sorry to bother you with a subject already seen in this forum and on the internet, but i didn't found the solution...
I explain myself,
I want to set up Kali linux on my raspberry B+, but nothing seems to work. The pi won't boot. I tried a lot of image, but only from windows. (1.0.5,1.0.6,1.0.6a,1.0.7,1.0.8, the rpi version, and the armel version.)
I try raspbian, archlinux and riscos, everything works.
I don't know what to do, if someone had an idea!
Thanks!
Re: Rpi and Kali
Posted: Sat Jul 26, 2014 2:59 pm
by DirkS
Maybe you should ask on the Kali forum (
https://forums.kali.org/forum.php)?
There's also a doc there on installing Kali on the Pi
http://docs.kali.org/armel-armhf/instal ... spberry-pi
Re: Rpi and Kali
Posted: Sat Jul 26, 2014 3:06 pm
by DougieLawson
Have you updated the /boot (FAT partition) with bootcode.bin and start.elf which have the B+ firmware changes?
Re: Rpi and Kali
Posted: Sat Jul 26, 2014 3:11 pm
by arwald
DougieLawson wrote:Have you updated the /boot (FAT partition) with bootcode.bin and start.elf which have the B+ firmware changes?
I didn't read anything about this. Thanks a lot! Looking for this right now
Re: Rpi and Kali
Posted: Sat Jul 26, 2014 3:17 pm
by DougieLawson
arwald wrote:DougieLawson wrote:Have you updated the /boot (FAT partition) with bootcode.bin and start.elf which have the B+ firmware changes?
You can pull those from
https://github.com/raspberrypi/firmware ... aster/boot
Re: Rpi and Kali
Posted: Sat Jul 26, 2014 3:40 pm
by arwald
I tried twice with 1.0.5 and 1.0.6a with a boot folder updated, but still not work
Re: Rpi and Kali
Posted: Sat Jul 26, 2014 3:42 pm
by DougieLawson
arwald wrote:I tried twice with 1.0.5 and 1.0.6a with a boot folder updated, but still not work
Then you'll need to ask for help on the Kali forums.
Re: Rpi and Kali
Posted: Sat Jul 26, 2014 5:18 pm
by arwald
I'll let you know as soon as i get an answer from kali forums
Re: Rpi and Kali
Posted: Sat Jul 26, 2014 5:40 pm
by arwald
I have also tried with Pwnpi and Ha-pi. Even if i replace bootcode.ini and start.elf or the whole boot folder, nothing happen.
Seems like i can only use the os include in noob
If this info could help : both led are on (red and green) and they don't move
Re: Rpi and Kali
Posted: Mon Jul 28, 2014 9:31 am
by arwald
As i didn't get any response from Kali forums, I up the topic, if someone get something more.
Re: Rpi and Kali
Posted: Mon Jul 28, 2014 8:48 pm
by AndrewS
Nope, I'm afraid if Kali can't / won't fix their distro to work on the B+, then there's not much you can do.
I guess if you were desperate you could buy a Model B (not B+) Pi?
Re: Rpi and Kali
Posted: Mon Jul 28, 2014 9:09 pm
by arwald
Yeah, I think a second raspberry could be a great idea for my projects
Re: Rpi and Kali
Posted: Wed Jul 30, 2014 7:00 pm
by daddadhad
I had a different problem:
My would boot but kept on displaying this message so I couldn't login.
usb 30000x21(something like that): error usb (can't remember the rest)
something about it not being able to find the device even when nothing was plugged in right after saying it found it.
Help?
Re: Rpi and Kali
Posted: Wed Jul 30, 2014 7:09 pm
by AndrewS
daddadhad wrote:I had a different problem:
If you've got a different problem, please start a new thread rather than 'hijacking' another thread.
I'm afraid we need the
exact error message in order to be able to diagnose any problems. Maybe you could take a mobile-phone-camera picture? (but again, in a new thread please
Re: Rpi and Kali
Posted: Sat Aug 02, 2014 9:02 pm
by evoverride
I got Kali working on the B+ with the 3.12.y kernel. I built mine on an existing kali vm with the following commands:
git clone https://github.com/offensive-security/kali-arm-build-scripts
cd kali-arm-build-scripts
sed -i 's/3.13.y/3.12.y/g' rpi.sh
./build-deps.sh
yes "" | ./rpi.sh 1.3.3.7
After it's done building the compressed image will be located at kali-arm-build-scripts/rpi-1.3.3.7/kali-1.3.3.7-rpi.img.xz
Re: Rpi and Kali
Posted: Mon Aug 04, 2014 1:16 pm
by arwald
Thanks! I'll try this tonight at home!
Re: Rpi and Kali
Posted: Sun Aug 10, 2014 4:59 am
by anomie-p
My B+ came in the mail today, Kali wouldn't boot, made a local clone of the above with git, mounted the fat32 partition on the micro SD card, copied bootcode.bin and start.elf over. Powered up the pi, figuring that based on the contents of this thread that it probably wouldn't help - and it booted.
I used kali-linux-1.0.6a-rpi.img that I downloaded maybe a week ago or so when I originally wrote the card.
When it wasn't booting, the red LED would be on and the green would flash and go dark (whereas the raspbian sd image I have would flash green a bit more and boot) - which is different than the 'red and green both on' reported here. Anyway - figured I'd throw that out there, replacing bootcode.bin and start.elf are worth a try if you're having this issue and haven't yet tried it.
Re: Rpi and Kali
Posted: Mon Aug 18, 2014 7:38 pm
by hosnappp
Try booting into the GUI though. startx results in a failure of your peripherals.
Re: Rpi and Kali
Posted: Thu Aug 21, 2014 3:33 pm
by for_ever
DougieLawson wrote:arwald wrote:DougieLawson wrote:Have you updated the /boot (FAT partition) with bootcode.bin and start.elf which have the B+ firmware changes?
This worked like a charm for me! Thanks!
Re: Rpi and Kali
Posted: Fri Aug 22, 2014 9:17 am
by astaicu
This is interesting, what version of kali are you using?
Not working for me on a B+ with latest kali-1.0.7-rpi.img : USB and Ethernet drivers missing.
Tried with the latest bootcode.bin and start.elf from git, and also with bootcode.bin and start.elf from a current NOOBS image....
Re: Rpi and Kali
Posted: Wed Oct 22, 2014 5:41 pm
by Kokoroyoma
Some things to try -
Try downloading the Kali-109-rpi Image directly from the ARM Custom Images
Then write the image to the SDcard (This worked first time for me)
