arwald
Rpi and Kali
Sat Jul 26, 2014 2:51 pm
Hi guys, I'm new here, as i recieved my raspberry few days ago.
I'm sorry to bother you with a subject already seen in this forum and on the internet, but i didn't found the solution...
I explain myself,
I want to set up Kali linux on my raspberry B+, but nothing seems to work. The pi won't boot. I tried a lot of image, but only from windows. (1.0.5,1.0.6,1.0.6a,1.0.7,1.0.8, the rpi version, and the armel version.)
I try raspbian, archlinux and riscos, everything works.
I don't know what to do, if someone had an idea!
Thanks!
DirkS
Re: Rpi and Kali
Sat Jul 26, 2014 2:59 pm
Maybe you should ask on the Kali forum (https://forums.kali.org/forum.php)?
There's also a doc there on installing Kali on the Pi http://docs.kali.org/armel-armhf/instal ... spberry-pi
Re: Rpi and Kali
Sat Jul 26, 2014 3:06 pm
arwald wrote: I want to set up Kali linux on my raspberry B+, but nothing seems to work. The pi won't boot. I tried a lot of image, but only from windows. (1.0.5,1.0.6,1.0.6a,1.0.7,1.0.8, the rpi version, and the armel version.)
Have you updated the /boot (FAT partition) with bootcode.bin and start.elf which have the B+ firmware changes?
arwald
Re: Rpi and Kali
Sat Jul 26, 2014 3:11 pm
DougieLawson wrote:Have you updated the /boot (FAT partition) with bootcode.bin and start.elf which have the B+ firmware changes?
I didn't read anything about this. Thanks a lot! Looking for this right now :D
Re: Rpi and Kali
Sat Jul 26, 2014 3:17 pm
You can pull those from https://github.com/raspberrypi/firmware ... aster/boot
arwald
Re: Rpi and Kali
Sat Jul 26, 2014 3:40 pm
I tried twice with 1.0.5 and 1.0.6a with a boot folder updated, but still not work :(
Re: Rpi and Kali
Sat Jul 26, 2014 3:42 pm
arwald wrote:I tried twice with 1.0.5 and 1.0.6a with a boot folder updated, but still not work :(
Then you'll need to ask for help on the Kali forums.
arwald
Re: Rpi and Kali
Sat Jul 26, 2014 5:18 pm
I'll let you know as soon as i get an answer from kali forums
arwald
Re: Rpi and Kali
Sat Jul 26, 2014 5:40 pm
I have also tried with Pwnpi and Ha-pi. Even if i replace bootcode.ini and start.elf or the whole boot folder, nothing happen.
Seems like i can only use the os include in noob :cry:
If this info could help : both led are on (red and green) and they don't move
arwald
Re: Rpi and Kali
Mon Jul 28, 2014 9:31 am
As i didn't get any response from Kali forums, I up the topic, if someone get something more.
AndrewS
Re: Rpi and Kali
Mon Jul 28, 2014 8:48 pm
Nope, I'm afraid if Kali can't / won't fix their distro to work on the B+, then there's not much you can do. :(
I guess if you were desperate you could buy a Model B (not B+) Pi?
arwald
Re: Rpi and Kali
Mon Jul 28, 2014 9:09 pm
Yeah, I think a second raspberry could be a great idea for my projects :D
daddadhad
Re: Rpi and Kali
Wed Jul 30, 2014 7:00 pm
I had a different problem:
My would boot but kept on displaying this message so I couldn't login.
usb 30000x21(something like that): error usb (can't remember the rest)
something about it not being able to find the device even when nothing was plugged in right after saying it found it.
Help?
11 years of age
built my own computer at age 10
problem solver since the day I was born
NUKE IN 3 2 1 BOOOOOM!!!
AndrewS
Re: Rpi and Kali
Wed Jul 30, 2014 7:09 pm
daddadhad wrote:I had a different problem:
If you've got a different problem, please start a new thread rather than 'hijacking' another thread.
I'm afraid we need the exact error message in order to be able to diagnose any problems. Maybe you could take a mobile-phone-camera picture? (but again, in a new thread please :) )
evoverride
Re: Rpi and Kali
Sat Aug 02, 2014 9:02 pm
I got Kali working on the B+ with the 3.12.y kernel. I built mine on an existing kali vm with the following commands:
git clone https://github.com/offensive-security/kali-arm-build-scripts
cd kali-arm-build-scripts
sed -i 's/3.13.y/3.12.y/g' rpi.sh
./build-deps.sh
yes "" | ./rpi.sh 1.3.3.7
After it's done building the compressed image will be located at kali-arm-build-scripts/rpi-1.3.3.7/kali-1.3.3.7-rpi.img.xz
arwald
Re: Rpi and Kali
Mon Aug 04, 2014 1:16 pm
Thanks! I'll try this tonight at home!
anomie-p
Re: Rpi and Kali
Sun Aug 10, 2014 4:59 am
DougieLawson wrote:You can pull those from https://github.com/raspberrypi/firmware ... aster/boot
My B+ came in the mail today, Kali wouldn't boot, made a local clone of the above with git, mounted the fat32 partition on the micro SD card, copied bootcode.bin and start.elf over. Powered up the pi, figuring that based on the contents of this thread that it probably wouldn't help - and it booted.
I used kali-linux-1.0.6a-rpi.img that I downloaded maybe a week ago or so when I originally wrote the card.
When it wasn't booting, the red LED would be on and the green would flash and go dark (whereas the raspbian sd image I have would flash green a bit more and boot) - which is different than the 'red and green both on' reported here. Anyway - figured I'd throw that out there, replacing bootcode.bin and start.elf are worth a try if you're having this issue and haven't yet tried it.
hosnappp
Re: Rpi and Kali
Mon Aug 18, 2014 7:38 pm
Try booting into the GUI though. startx results in a failure of your peripherals.
for_ever
Re: Rpi and Kali
Thu Aug 21, 2014 3:33 pm
This worked like a charm for me! Thanks!
astaicu
Re: Rpi and Kali
Fri Aug 22, 2014 9:17 am
This is interesting, what version of kali are you using?
Not working for me on a B+ with latest kali-1.0.7-rpi.img : USB and Ethernet drivers missing.
Tried with the latest bootcode.bin and start.elf from git, and also with bootcode.bin and start.elf from a current NOOBS image....
Kokoroyoma
Re: Rpi and Kali
Wed Oct 22, 2014 5:41 pm
Some things to try -
Try downloading the Kali-109-rpi Image directly from the ARM Custom Images
Then write the image to the SDcard (This worked first time for me)
