Pi stops responding after some time.
Posted: Sat Jul 26, 2014 2:40 pm
by bharathyes
Hi.
My name is Bharath and I recently bought the RPi model B+. Initially I connected it to my TV set and separate mouse and keyboards. But after learning about ssh and VNC, I started controlling it from my laptop.
But I started to face a problem. If I left the Pi running without interacting with it for some time and try to ssh or VNC to it after a while, it stops responding back. But the ethernet lights and the Power (red) LED keeps glowing without indicating any activity. I tried unplugging and reconnecting the LAN wire, pendrives, etc. but the only way was to unplug the power cord and restart the RPi.
This has been happening for some time and I am annoyed by this. Also worried that the improper shutdowns might harm the Pi.
Is there any way to keep this happening.
Looking forward for a solution.
Thank you.
Ps: I am running the latest release of Raspbian without using NOOBS on an 8GB SD card. I have only connected a Power source and an Ethernet wire to the Pi. Ask for any other details you want, but help me with a solution.
Re: Pi stops responding after some time.
Posted: Sat Jul 26, 2014 3:12 pm
by DougieLawson
Posted: Wed Sep 11, 2019 7:11 am
by Gurudut3
I am trying to run Raspberry Pi board with OS please check the following point as am facing problems.
1. My raspberry Pi is running fine for 20 mins after that only red power light and LAN connectivity light is on.
2. ACT light stops blinking or sometimes its constant green at same time we cannot SSH or ping the Raspberry PI board.
So require a proper and quick solution so as to complete my project.
Thanks and Regards,
Gurudas Shenoy
Posted: Sun Sep 22, 2019 8:36 pm
by seelhsu
Thanks and Regards,
Gurudas Shenoy
I met the same problem.
