Pi keeps stalling
Posted: Thu Jun 26, 2014 12:22 am
by JustCurious
I use the RPi with Volumio and the Pi-DAC from IQaudIO. The RPi keeps stalling after a certain amount of time. Always when not operated (running though), and within between 10 minutes and 3 days.
Re: Pi keeps stalling
Posted: Thu Jun 26, 2014 2:31 am
by AndrewS
Have you been in touch with IQaudIO ?
Posted: Thu Jun 26, 2014 8:57 am
by JustCurious
AndrewS wrote:Have you been in touch with IQaudIO ?
Yes. My DAC board will be examined by IQaudIO. But what are you aiming at exactly? :)
Posted: Thu Jun 26, 2014 9:12 am
by RaTTuS
staling how ?
does dmesg say anything
Posted: Thu Jun 26, 2014 10:08 am
by JustCurious
RaTTuS wrote:staling how ?
Ping times out and ssh/telnet get no response. (t.i. wirelessly)
Posted: Thu Jun 26, 2014 10:13 am
by DougieLawson
What WiFi dongle are you using?
Have you disabled power management for it?
Post the output from a lsusb command.
Posted: Sat Jun 28, 2014 7:09 pm
by JustCurious
Lsusb:
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
I don't know how to disable power management of the WiFi dongle.
As for dmesg, I don't know what it means but I suspect it reports about the initialisation phase of the operating system.
It looks like Volumio (or the WiFi dongle) goes to sleep and I can wake it up by initiating a connection and waiting a while.
Posted: Sat Jun 28, 2014 7:22 pm
by MrEngman
You can disable power management for thr EW-7811Un by making file /etc/modprobe.d/8192cu.conf.
Use command
sudo nano /etc/modprobe.d/8192cu.conf
to edit the file and add the lines, well only second line is really needed.
# Disable power management
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
Save the file and terminate the editor using keys Cntl-x, y, enter.
This will turn off power management and stop the EW-7811Un disconnecting from the USB bus.
MrEngman
Posted: Sun Jun 29, 2014 8:45 am
by JustCurious
Thanks MrEngman! That works! :D
Posted: Mon Aug 25, 2014 1:51 pm
by thaddeussmith
What would be the proper syntax to create the same file/settings for this device?
Bus 001 Device 004: ID 0846:9041 NetGear, Inc. WNA1000M 802.11bgn [Realtek RTL8188CUS]
I'm having the exact same symptoms, but different device. Running Volumio 1.41 (raspyfi)
Posted: Mon Aug 25, 2014 4:53 pm
by thaddeussmith
After re-reading the thread, I just realized that I'm dumb and the existing syntax should also work for my Netgear adapter. I was getting hung up on manufacturer names and assuming there was a difference.
