[SOLVED] internet access Buffalo WLI-UC-GNM2
Posted: Sat Jun 21, 2014 8:40 am
by RASPmke
I have a problem with accessing the internet using a WIFI dongle.
Dongle: Buffalo WLI-UC-GNM2
I tried to setup using the GUI from the desktop.
The scan finds my WIFI router.
I enter the password and click on add.
Now, it tries to access it but it doesn't seem to work. Never did I get an IP address.
The error message is: 4-Way Handshake failed - pre-shared key may be incorrect
If I look into /etc/wpa_supplicant/wpa_supplicant.conf, I find several times a "network" entry and one of them contains a wrong password (psk key). I tried to fix it using nano, but it doesn't work.
Could this be the reason, or should I look for something else.
Thank you
Michael
Connection by wire is OK.
Re: No internet access using WIFI dongle
Posted: Sat Jun 21, 2014 9:06 am
by Cancelor
I dunno but in what way did nano not work. Did if fail to write to the file or is the password in the file now okay?
Posted: Sat Jun 21, 2014 10:54 am
by RASPmke
Sorry, misunderstanding.
nano itself worked flawlessly.
I wanted to say, I corrected the wrong password with nano and then checked again. I got the same error, even after rebooting.
Posted: Sat Jun 21, 2014 9:45 pm
by DougieLawson
Please post the output from
uname -a
lsusb
cat /etc/network/interfaces
sudo cat /etc/wpa_supplicant/wpa_supplicant.conf (with the password redacted)
Posted: Sat Jun 21, 2014 11:46 pm
by RASPmke
Thank you for looking into it.
Regarding the password, in two cases, the second and third character is missing - see below.
The requested information follows.
uname - a
Linux raspberrypi 3.12.22+ #691 PREEMPT Wed Jun 18 18:29:58 BST 2014 armv6l GNU/Linux
> lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 8564:4000
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 006: ID 0411:01ee BUFFALO INC. (formerly MelCo., Inc.) WLI-UC-GNM2 Wireless LAN Adapter [Ralink RT3070]
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
update_config=1
network={
ssid="BUFFALO-4C10A3"
psk="tu5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
group=TKIP WEP104 WEP40
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
network={
psk="t83u5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
Posted: Sat Jun 21, 2014 11:55 pm
by DougieLawson
Try
sudo apt-get install rpi-update
sudo rpi-update
sudo reboot
If that doesn't fix it you should buy a new WiFi dongle that uses a well supported realtek or ralink chipset.
Posted: Sun Jun 22, 2014 12:16 am
by MrEngman
I would suggest you edit your /etc/wpa_supplicant/wpa_supplicant.conf and set it to
update_config=1
network={
	ssid="network-name"
	psk="network-password"
wpa_supplicant will sort out all the remaining entries such as pairwise, group etc. itself.
If you are using command
wpa_passphrase essid passphrase
to generate the psk try using the plain text phrase instead. Searching the internet using the error message you've been getting has suggested there may be a problem with command wpa_passphrase.
MrEngman
Posted: Sun Jun 22, 2014 2:03 am
by RASPmke
Yes, and it seems that this happens already since more than 10 years.
Nevertheless, I found the solution (I am writing this now using the WIFI dongle).
In
"network={
psk="tu5++++++++"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
I first corrected the wrong password and then I changed
"proto=RSN"
to
"proto=WPA RSN"
as indicated in
https://forums.freebsd.org/viewtopic.php?&t=37031
So, whom should I contact to tell about this problem and its solution?
And thank you to you guys for taking your time with other people's problems.
Michael
