dervin
Unable to install python-dev
Sat Jun 07, 2014 8:25 pm
Hello
When I'm trying to install python-dev with
sudo pip install Pillow
, I get this error message:
  • gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -DHAVE_LIBZ -I/usr/include/freetype2 -I/tmp/pip_build_root/Pillow/libImaging -I/usr/include -I/usr/local/include -I/usr/include/python2.7 -I/usr/include/arm-linux-gnueabihf -c _imaging.c -o build/temp.linux-armv6l-2.7/_imaging.o
    _imaging.c:76:20: fatal error: Python.h: No such file or directory
    compilation terminated.
    error: command 'gcc' failed with exit status 1
    Cleaning up...
    Command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip_build_root/Pillow/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-ARlKYX-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip_build_root/Pillow
    Storing debug log for failure in /root/.pip/pip.log
Anyone knows how to fix this?
thx for help :)
DirkS
Re: Unable to install python-dev
Sun Jun 08, 2014 1:54 am
dervin wrote:When I'm trying to install python-dev with
That doesn't look right to me. You're trying to install Pillow (version of Python Imaging Library) with that command. One of the prerequisites is python-dev.
See http://pillow.readthedocs.org/en/latest ... stallation.
As you can see there you'll have to install python-dev first using apt-get:
sudo apt-get install python-dev
HTH
Dirk.
dervin
Sun Jun 08, 2014 10:50 am
CODE: SELECT ALL
HTH
Dirk.
I tried to install python-dev but then this error message shows up:
Package python-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
python
E: Package 'python-dev' has no installation candidate
I also tried
sudo apt-get update
DirkS
Sun Jun 08, 2014 3:55 pm
Very odd. Ok, back to basics...
Which distro are you using (Raspbian, Arch or other).
You mentioned to tried 'sudo apt-get update'. Did you get any error messages?
Did you try to install python-dev *after* running the apt-get update?
Gr.
Dirk.
dervin
Sun Jun 08, 2014 4:10 pm
I'm running Raspbian and the command 'sudo apt-get update' was successful. But after I tried to install the python-dev the same error message occurred. :/
thx for the answer
dervin
DirkS
Sun Jun 08, 2014 4:24 pm
Right now I don't know what to check next...
Maybe someone else has an idea?
Gr.
Dirk.
Sun Jun 08, 2014 4:36 pm
Can you list the contents of the file /etc/apt/sources.list and also all files in /etc/sources.list.d/?
It sounds like you may have something missing from one of these.
dervin
Sun Jun 08, 2014 4:41 pm
sources.list: http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
I can't find anything named with sources.list.d in /etc :/
DirkS
Sun Jun 08, 2014 4:45 pm
Yes, that would explain it.
Normally the first line is:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
Insert this line at the top of the file and save it.
After this you should run apt-get update again before trying to install python-dev
HTH
Dirk.
dervin
Sun Jun 08, 2014 4:55 pm
Thank you very much!! I could finally install it now
