Realtech 8191su Wifi setup
Posted: Fri Jun 06, 2014 2:10 pm
I cannot seem to get the above to work with my wireless router setup.
It seems every internet Raspberry Pi help site gives a slightly different way of setting up wifi. I've tried them all! What have I left out?
Here is what I have:
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.6.11+ #434 PREEMPT Wed May 1 21:13:52 BST 2013 armv6l GNU/Linux
pi@raspberrypi ~ $ lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 004: ID 0bda:8172 Realtek Semiconductor Corp. RTL8191SU 802.11n WLAN Adapter
pi@raspberrypi ~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.0.3
netmask 255.255.255.0
gateway 192.168.0.2
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "WiFi 2"
wpa-psk "Captain"
pi@raspberrypi ~ $
pi@raspberrypi ~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="WiFi 2"
psk="Captain"
pi@raspberrypi ~ $ iwconfig
wlan0 IEEE 802.11bgn ESSID:"WFYC WiFi 2" Nickname:"rtl_wifi"
Mode:Managed Frequency:2.437 GHz Access Point: F8:D1:11:B1:E4:56
Bit Rate:150 Mb/s Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality=99/100 Signal level=100/100 Noise level=0/100
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
ham0 no wireless extensions.
eth0 no wireless extensions.
pi@raspberrypi ~ $ iwlist wlan0 scan
Cell 06 - Address: F8:D1:11:B1:E4:56
ESSID:"WiFi 2"
Protocol:IEEE 802.11bgn
Mode:Master
Frequency:2.437 GHz (Channel 6)
Encryption key:on
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s; 6 Mb/s; 9 Mb/s
12 Mb/s; 48 Mb/s
Extra:wpa_ie=dd180050f20101000050f20401000050f20401000050f2020c00
IE: WPA Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
Extra:rsn_ie=30140100000fac040100000fac040100000fac020c00
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
IE: Unknown: DD730050F204104A00011010440001021041000100103B00010310470010BF0E09F788936CF72D484F649A6CC5F71021000754502D4C494E4B1023000754502D4C494E4B1024000631323334353610420004313233341054000800060050F20400011011000954442D57383936304E100800020088
Signal level=26/100
auto lo
address 192.168.0.3
gateway 192.168.0.2
allow-hotplug wlan0
wpa-ssid "WiFi 2"
wpa-psk "Captain"
pi@raspberrypi ~ $
update_config=1
network={
ssid="WiFi 2"
psk="Captain"
ESSID:"WiFi 2"
Mode:Master
Encryption key:on
12 Mb/s; 48 Mb/s
IE: WPA Version 1
Group Cipher : CCMP
Group Cipher : CCMP
Signal level=26/100
