japester36
Abiword installation issues (resolved)
Fri Jun 08, 2012 8:32 pm
I'm using Debian6 19.04 and have happily set up Chromium and Gimp through the usual sudo apt-get install xxxxx commands.
I'm now trying to install Abiword but despite it reporting success downloading and installing I cannot find it integrated into the LXDE unlike Chromium and Gimp. (Gimp was installed after Abiword)
I have tried removing and reinstalling several times (sudo apt-get install abiword-common) and always no errors and it appears to be fine - just no integration with LXDE.
Any ideas where I might be going wrong?
(4Gb SD card - 1.9 free, have run upgrade successfully, wifi installed fine)
JP
JollyRoger
Re: Abiword installation issues
Tue Jun 12, 2012 6:36 am
I'm having exactly the same problem. Abiword is installed and present in the file system, but there's no sign of it in LXDE. Help!
JollyRoger
Tue Jun 12, 2012 12:13 pm
Problem solved!
My mistake was to do sudo apt-get install abiword-common (I read to do this somewhere on the Raspi site). I should have done:
Everything now works.
japester36
Re: Abiword installation issues (resolved)
Thu Jun 14, 2012 2:30 pm
Thanks JollyRoger, same mistake here and it seems the incorrect advice to use abiword-common rather than just Abiword has appeared in a few places.
Very happy to have a nice small footprint wordprocessor.
sudo apt-get install abiword worked for me too.
Bkswain87
Fri Aug 24, 2012 3:51 am
When I try to install with sudo apt-get install abiword I get:
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libtelepathy-glib0 armhf 0.18.1-2
404 Not Found
Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found
Any advice?
Montala
Fri Aug 24, 2012 4:09 pm
Bkswain87 wrote:When I try to install with sudo apt-get install abiword I get:
404 Not Found
Any advice?
Yes, don't ask the same question in two different places!
You have already started a thread at http://www.raspberrypi.org/phpBB3/viewt ... 26&t=15510 and received a reply, which will hopefully help you.
