ProSpectre
Trouble stting Rasp Pi up as a WiFi AP
Fri May 30, 2014 8:30 pm
I was trying to set up my Pi as a WiFi AP (using this guide https://learn.adafruit.com/setting-up-a ... t?view=all ).
All fine and ok till I'm trying to modify the dhcp.conf. The file is empty for me, no lines in it to modify.
What is it I'm doin wrong?
Thanks for any kind of help.
hunternet93
Re: Trouble stting Rasp Pi up as a WiFi AP
Sun Jun 01, 2014 1:31 am
Are you using the correct filename? The file to edit is /etc/dhcp/dhcpd.conf, not dhcp.conf as in your post. If that doesn't help, list the files in /etc/dhcp with the command:
ls /etc/dhcp
There should be a couple files in there, including dhcpd.conf, if not then isc-dhcp-server might not be installed correctly.
