bb12jo
How many motors can be hooked up on Raspberry Pi?
Tue May 27, 2014 10:21 pm
Hi! I was wondering how many motors can I hook up on a Raspberry Pi's GPIO pins without needing to buy adapters? I have 4 motors running on two H-bridges and I need to know if I can hook up all the motors. Thanks in advance!!
Re: How many motors can be hooked up on Raspberry Pi?
Tue May 27, 2014 10:49 pm
Zero.
You need opto-isolators, transistors, relays or motor controller chips. The GPIO pins can't provide enough current to run a 3V3 motor and the back emf when a motor stops is deadly to your RPi.
joan
Tue May 27, 2014 10:52 pm
You have not given enough information.
I suppose the correct answer is between 0 and infinity.
bb12jo
Tue May 27, 2014 11:16 pm
Sorry I am a serious noob at the Pi. I need to run 4 6V motors on the Pi pins. I will hook up the motors like this guy did in this picture: http://i1.ytimg.com/vi/b4uhh_j8uR0/maxresdefault.jpg
mikronauts
Tue May 27, 2014 11:41 pm
You need three Pi GPIO's per motor, using the driver from that photo.
So with four motors, that's 12 GPIO's.
For each motor, use PWM for its enable line, and use its direction pins to set /forward/reverse/break
Enable A, IN1, IN2 is for motor A
Enable B, IN2, IN3 is for motor B
You must drive the motors from a different power supply than the Pi if you wish to avoid potential problems.
Use joan's excellent PIGPIO library, it makes the PWM and I/O easy.
bb12jo wrote:Sorry I am a serious noob at the Pi. I need to run 4 6V motors on the Pi pins. I will hook up the motors like this guy did in this picture: http://i1.ytimg.com/vi/b4uhh_j8uR0/maxresdefault.jpg
bb12jo
Wed May 28, 2014 12:57 am
Could you please link Joan's PIGPIO library?
Thanks for your help!
mikronauts
Wed May 28, 2014 1:06 am
Here you go:
http://abyz.co.uk/rpi/pigpio/
And a YouTube video for it:
https://www.youtube.com/watch?v=pqz2W6ekKS4
bb12jo wrote:Could you please link Joan's PIGPIO library?
BMS Doug
Wed May 28, 2014 6:14 am
mikronauts wrote:You need three Pi GPIO's per motor, using the driver from that photo.
Surely 2 GPIO's per motor for a total of 8 GPIO's.
connect the enables permanently on via the link jumper and just use inputs.
Doug.
mikronauts
Wed May 28, 2014 1:38 pm
Depends on the H-Bridge
If you PWM enable, than the motors will coast when disabled.
If you tie enable high, and pulse one of the directions, the motors will break during the low period of the pulsed direction pin, which causes more power to be used, and shortens the life of the motors.
Mind you, there are some modules that take care of this internally to avoid such breaking, but for example the common L298 driver boards would behave thus.
johndough
Thu May 29, 2014 9:39 am
Hi
I agree 8 pins it is.
2 pins per motor. Driving 2 relays.
Gives Forward and Reverse with the option to connect for a locked rotor.
1 little sainsmart relay board per motor.
Cancelor
Thu May 29, 2014 10:30 am
If you are hooking them up to one of those .... do you want variable speed or just forward, reverse and stop?
If you just want unidirectional, fixed speed on and off then one pin and a relay will do! ;)
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
