mmascaro
No audio on the HDMI port
Tue May 27, 2014 5:37 pm
I have a model B Raspberry Pi running Raspian Build 3.10.25+
I have no audio out on my HDMI port.
If I use Raspi-config to force audio out the 3mm plug and test with Speaker-test I can get a sine wave o headphones.
But once I change it to force HDMI I get no audio. At first I thought it might be the lapdock but I connected the Pi to my TV through the same cable as my Apple TV and still no audio.
Thanks in advance
Mark
Re: No audio on the HDMI port
Tue May 27, 2014 5:44 pm
Retired disgracefully.....
......to a more gentile life !
mmascaro
Tue May 27, 2014 6:17 pm
The first two suggestions do not work.
If I try to edit config.txt with leafpad it will not save. I tell it to overwrite the existing config.txt file and it says "Can't open file to write".
Leafpad gives me the same problem if I try to save as to a different name.
If I boot and hold down the shift button the NOOBS screen will not open config.txt to edit(option is greyed out)
DeeJay
Tue May 27, 2014 6:23 pm
Have you filled all the free space on your root filesystem on the SD card perhaps?
mmascaro
Tue May 27, 2014 6:29 pm
File manager shows /boot has 42.5MB free on an 8 gig SD card
drgeoff
Tue May 27, 2014 11:03 pm
mmascaro wrote:The first two suggestions do not work.
You need to be root to write files in /boot. Either prefix the editor invocation with sudo or put the SD card in another computer and edit it there.
atomic3
Wed May 28, 2014 12:10 am
mmascaro wrote:I have a model B Raspberry Pi running Raspian Build 3.10.25+
Thanks in advance
Mark
Not sure how you are testing your audio, but when I run omxplayer I always have to use option -r for the audio to work.
mmascaro
Wed May 28, 2014 12:25 am
I am plugging the Pi's HDMI port into a HDMI TV that I know passes audio to the speaker. And not getting any audio from the Pi.
I have used MOC to play a track. It plays thru the Audio jack when that is selected but not to the HDMI port when that is selected.
Still trying to find a way to edit Config.txt
mmascaro
Wed May 28, 2014 12:52 am
OK got it working.
Edited Config.txt by reading the MagPi Vol 3 PG 4
sudo nano /boot/config.txt
Changed the HDMI_drive=2 and its working with Mocp (DR Who theme) and speaker-test sine wave
Thanks to all for the help
Mark
