ahmishgoma
Rpi not connecting to ntp server
Thu May 22, 2014 8:46 pm
Hi everyone,
This is my first time using a raspberry pi and I'm trying to get it to show me the date and time correctly without using an RTC.
Unfortunately, the time is a bit off on the Rpi and I'm trying to fix that. I tried all the solutions posted here
http://www.raspberrypi.org/forums/viewt ... 63&t=59893
but none of them are working.
Bottom line is that whichever ntp server I use, it's not able to connect to it.
When I do ntpq -p this is the terminal just shows 0 for reach and 0.000 for delay, offset and jitter. It just shows a blank(-) under when. Is there something I've configured wrong? I appreciate any help. Thanks!
DeeJay
Re: Rpi not connecting to ntp server
Fri May 23, 2014 6:57 am
Which Operating System are you using on your RPi?
Do you have reason to believe that your RPi has a fully working internet connection?
Fri May 23, 2014 1:40 pm
start with
sudo ntpd -q -g
that will set your clock even if it's off by more than 1000s from current time.
Then
sudo /etc/init.d/ntp start
should get ntp running permanently.
This is a doctor free zone.
