Hello all,
I've searched for awhile and couldn't find what I needed so I've decided to ask for your help. I've had my pi up and running (successfully) for a little over a month now. I am using it as a NAS with one 1TB HDD hooked up to it with all of my documents on it. I recently did some updating and tweaking with no issues. After a reboot or two I noticed that my Windows 7 network drive (Z:) that I had set the raspnas up on said "This folder doesn't contain any files". I went back through the set up process and basically did everything over again which worked and I could see my files. Today I was making sure I had SSH up and running and after a reboot my files are "missing" again. I've tried everything from redoing the entire setup process to unmounting and remounting the HDD to no solution. Any ideas are greatly appreciated. Links below to the setup instructions I am using.
build:
RASPBIAN
Debian Wheezy
Version:January 2014
Release date:2014-01-07
tutorials:
(below link used until step 4 and then switched to youtube video)
http://www.dingleberrypi.com/2013/05/tu ... ge-server/
https://www.youtube.com/watch?v=jr2Jz8km2BU
