bigguyone
Hot to the touch
Thu Apr 24, 2014 11:39 pm
Hi, Iam having a prob with pi. It seams to be running hoter them I remember & it turns off and restarts. I run it all day & its fine & then late afternoon it starts turning off. I don't notice it runnimh all that hot tills on about 5 to 6 hrs. Its pretty hot on the two chips area.I don't recall it being this hot before, its not over clock & pretty norm setup. It has raspbmc on it.
any one know what it mite be doing?
FLYFISH TECHNOLOGIES
Re: Hot to the touch
Fri Apr 25, 2014 1:51 am
What peripherals are connected to the RasPi ?
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
Fri Apr 25, 2014 5:45 am
The chips will often feel hot to the touch. That is quite normal and normally nothing to worry about.
What temperature does the system report when you do
vcgencmd measure_temp
as long as that is under 85°C the CPU/GPU is within acceptable temperature range.
The shutting down thing is a bit worrying. The first things I would check are the power supply (measure the voltage between TP1 and TP2), and, as Ivan said, any peripherals that are connected to the USB or GPIOs
bigguyone
Fri Apr 25, 2014 4:23 pm
Hi the only things are a mouse & keyboard, ( not WIFI) power is what came with it as it was a package deal.
The temp if i did it right (went to XBMC system info ) is 128F to 131F
GTR2Fan
Fri Apr 25, 2014 4:26 pm
That's around 54°C which I'd say was perfectly normal when idling in XBMC.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
Fri Apr 25, 2014 4:27 pm
bigguyone wrote:Hi the only things are a mouse & keyboard, ( not WIFI) power is what came with it as it was a package deal.
When you convert those temps back to a sensible international temperature unit they aren't outside a normal range (53.3 to 55). [I've yet to work out why the US of A sticks with non-SI units. I can see why we don't use SI units for normal ambient values.]
bigguyone
Fri Apr 25, 2014 4:44 pm
Hi prob because to sounds better LOL. Yea iam not sure what its doing but just started over the past few days doing this, I havent added any new addons or changed anything so not sure. i woundering if my SDcard mite be going bad i have heard they cut off and then dont have any program on it. Iam also trying to set up a usb stick but i dont know how to do that just yet. There are some good info on how to do it but i dont know how to get into the code thing yet . so if anyone knows what to do on that it would be great.
Fri Apr 25, 2014 5:21 pm
I checked both of my RPis. Pi is running at 45.4°C, raspberry is running at 44.5°C.
bigguyone
Fri Apr 25, 2014 5:27 pm
Well i guess mine is doing ok as temp gos. I dont know maybe it is the SDcard
