Internet problems
Posted: Thu Apr 24, 2014 4:34 pm
by pangren
Hi, I don't really know how to classify my problem , but here it goes. Generally it goes like this : When I write python code to access a webpage on the pi , it returns an error :
[Errno -5] No address associated with hostname
whether is it using libraries like :
import urllib2
import smtplib
from email.mime.text import MIMEText
etc etc
This error is exculsive to the Pi and never gives the same error on my Win7 pc.
to get wget working , I sort of have to add inet4_only = on to /etc/wgetrc .
wget works, internet works with midori, but somehow simple codes like this errors out close to 90% of the time
import urllib2
response = urllib2.urlopen('http://www.pythonforbeginners.com')
print response.info()
html = response.read()
response.close()
It is as if I cannot connect to the internet via python codes or there is a timelimit to the pi trying to access the internet and if it passes the limit, it'll give me the error.
Anyone has any idea what is happening? All help is appreciated
Re: Internet problems
Posted: Thu Apr 24, 2014 10:36 pm
by DougieLawson
What's in /etc/resolv.conf?
What do you get from a host google.co.uk command?
What do you get from a host www.pythonforbeginners.com command?
Posted: Fri Apr 25, 2014 2:10 pm
by pangren
my etc/resolv.conf returned this:
nameserver 192.168.1.254
and when i tried "host google.co.uk"
-bash: host: command not found
Posted: Fri Apr 25, 2014 2:44 pm
by DougieLawson
OK so you don't have the host package installed.
What do these commands
route -n
ping -c3 8.8.8.8
traceroute 8.8.8.8
get?
Posted: Sun Apr 27, 2014 6:20 am
by pangren
ok route -n gives this:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.254   0.0.0.0         UG    0      0        0 eth0
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
ping -c3 8.8.8.8 gives :
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_req=1 ttl=44 time=5.48 ms
64 bytes from 8.8.8.8: icmp_req=2 ttl=44 time=4.69 ms
64 bytes from 8.8.8.8: icmp_req=3 ttl=44 time=5.03 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 4.699/5.073/5.487/0.322 ms
traceroute 8.8.8.8 gives :
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
 1  192.168.1.254 (192.168.1.254)  0.984 ms  1.106 ms  0.889 ms
 2  * * *
 3  202.166.123.50 (202.166.123.50)  5.354 ms  5.069 ms  4.851 ms
 4  ae3-10.tp-ar11.singnet.com.sg (202.166.123.49)  52.592 ms  3.684 ms  2.954 ms
 5  202.166.121.82 (202.166.121.82)  3.526 ms  8.163 ms  3.179 ms
 6  ae4-0.pepsi.singnet.com.sg (202.166.123.70)  13.353 ms  8.028 ms  7.866 ms
 7  203.208.191.201 (203.208.191.201)  20.010 ms 203.208.190.197 (203.208.190.197)  19.160 ms 203.208.191.197 (203.208.191.197)  3.761 ms
 8  72.14.210.137 (72.14.210.137)  4.126 ms  3.499 ms  3.917 ms
 9  66.249.95.122 (66.249.95.122)  4.134 ms 66.249.95.124 (66.249.95.124)  4.255 ms  4.031 ms
10  72.14.239.61 (72.14.239.61)  6.246 ms 209.85.244.25 (209.85.244.25)  4.780 ms 64.233.174.109 (64.233.174.109)  5.025 ms
11  * * *
12  google-public-dns-a.google.com (8.8.8.8)  4.258 ms  4.924 ms  4.090 ms
Posted: Sun Apr 27, 2014 7:35 am
by DougieLawson
Your system is working and is configured correctly.
You can ping google, you can resolve it's name to an ip address and reverse resolve it's ip address to a name. The rest of the internet should work for you.
So I have no idea why you're getting the strange error from your python code. Try using python3
Try this sample
#!/usr/bin/python3
from urllib.request import urlopen
ip = urlopen('http://ipaddr.me/').read()
ip = ip.decode('utf-8')
print (ip)
import socket
name, alias, addresslist = socket.gethostbyaddr(ip)
print (name)
Posted: Sun Apr 27, 2014 8:49 am
by pangren
Thank you for being so patient DougieLawson , I tried your code and it returned this.
  File "/usr/lib/python3.2/urllib/request.py", line 1140, in do_open
    h.request(req.get_method(), req.selector, req.data, headers)
  File "/usr/lib/python3.2/http/client.py", line 970, in request
    self._send_request(method, url, body, headers)
  File "/usr/lib/python3.2/http/client.py", line 1008, in _send_request
    self.endheaders(body)
  File "/usr/lib/python3.2/http/client.py", line 966, in endheaders
    self._send_output(message_body)
  File "/usr/lib/python3.2/http/client.py", line 811, in _send_output
    self.send(msg)
  File "/usr/lib/python3.2/http/client.py", line 749, in send
    self.connect()
  File "/usr/lib/python3.2/http/client.py", line 727, in connect
    self.timeout, self.source_address)
  File "/usr/lib/python3.2/socket.py", line 397, in create_connection
    for res in getaddrinfo(host, port, 0, SOCK_STREAM):
socket.gaierror: [Errno -5] No address associated with hostname
During handling of the above exception, another exception occurred:
  File "testpy.py", line 5, in <module>
  File "/usr/lib/python3.2/urllib/request.py", line 139, in urlopen
    return opener.open(url, data, timeout)
  File "/usr/lib/python3.2/urllib/request.py", line 370, in open
    response = self._open(req, data)
  File "/usr/lib/python3.2/urllib/request.py", line 388, in _open
    '_open', req)
  File "/usr/lib/python3.2/urllib/request.py", line 348, in _call_chain
    result = func(*args)
  File "/usr/lib/python3.2/urllib/request.py", line 1160, in http_open
    return self.do_open(http.client.HTTPConnection, req)
  File "/usr/lib/python3.2/urllib/request.py", line 1143, in do_open
    raise URLError(err)
urllib.error.URLError: <urlopen error [Errno -5] No address associated with hostname>
could it be something in my router? or could I be hacked or something?
Posted: Sun Apr 27, 2014 10:20 am
by DougieLawson
Try this one:
#!/usr/bin/python2
import fcntl, socket, struct
def getHwAddr(ifname):
    s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    info = fcntl.ioctl(s.fileno(), 0x8927,  struct.pack('256s', ifname[:15]))
    return ''.join(['%02x:' % ord(char) for char in info[18:24]])[:-1]
print getHwAddr('eth0')
print getHwAddr('wlan0')
And this one:
#!/usr/bin/python3
import socket
import os
gw = os.popen("ip -4 route show default").read().split()
s.connect((gw[2], 0))
ipaddr = s.getsockname()[0]
gateway = gw[2]
host = socket.gethostname()
print ("IP:", ipaddr, " GW:", gateway, " Host:", host)
I'm still not sure why you can't get the resolver to work with python.
The chances of you having been hacked are ZERO.
One option may be to build a new SDCard with the latest Raspbian (or NOOBS/Raspbian) and try running your stuff on there. You'll need to copy current stuff out to somewhere safe (off the RPi).
Posted: Sun Apr 27, 2014 1:15 pm
by pangren
For the first script , it only worked when I commented out the last line, but the result was
b8:27:eb:f1:15:e7
And the 2nd script's output is
IP: 192.168.1.11  GW: 192.168.1.254  Host: raspberrypi
Well... if there is no solution, I'll have to re install NOOBS but thanks anyway. Probably I should try out these python scripts first before I configure my samba server.
Posted: Mon Apr 28, 2014 3:32 pm
by pangren
Hey Dougie, one last question. Is there a flag that I can input for the urllib2 that sort of adds a longer timeout ? like, eg: give me an error only after you've tried for "x" number of seconds?
Update: Installed a fresh NOOBS(I've checked SHA-1 to be sure) , didn't configure anything at all and still it didn't work. Now I'm looking if there might be router issues?
Posted: Mon Apr 28, 2014 11:56 pm
by DougieLawson
Yes you can set the timeout. Read the fine web pages @ https://docs.python.org/2.7/library/urllib2.html & https://docs.python.org/3.0/library/urllib.request.html
sudo sh -c 'echo "nameserver 8.8.8.8" > /etc/resolv.conf'
Try forcing your RPi to use Google's DNS for resolving domain name to IP addresses
