AlessioMTX
Save file to USB Drive
Sun Apr 20, 2014 10:28 am
I'm using a USB drive in my Raspberry to store my website. Now I want to also save my videos made with `motion`.
I wasn't able also to save in a folder different from `/tmp/motion` so googling I found I had to give permission to do what I wanted.
$ sudo chmod 777 /path/
I tried in the user directory `/home/pi` and it worked, then I tried the same on my USB drive.
- Filesystem /dev/sda1
- Size 3.6G
- Used 1.3M
- Avail 3.6G
- Use% 1%
- Mounted On /home/pi/usbdrv
$ sudo chmod 777 /home/pi/usbdrv
But as soon as `motion` try to save files in the usb Drive the service thread crashes. What do I have to do?
hunternet93
Re: Save file to USB Drive
Sun Apr 20, 2014 8:40 pm
Saving to USB should work OK, do you get any error messages? If so please copy/paste them here.
Sun Apr 20, 2014 10:29 pm
What type of filesystem is on your USB drive?
What options do you use when you mount it?
This is a doctor free zone.
AlessioMTX
Tue Apr 22, 2014 3:55 pm
From terminal:
$ sudo service motion start
motion start working, I can see images via browser, but as soon as the webcam try to save a file (e.g. a photo) the thread of the webcam crash, if there is only one webcam. Trying stop motion in the same way
$ sudo service motion stop
I get
[....] Stopping motion detection demon: motionNo /usr/bin/motion found running; none killed.
. ok
else if there are more webcams service still run until when all of them try to save datas.
while if I try, always from terminal:
$ sudo motion
I get
[0] Processing thread 0 - config file /etc/motion/motion.conf
[0] Processing config file /etc/motion/thread1.conf
[0] Processing config file /etc/motion/thread2.conf
[0] Motion 3.2.12 Started
[0] Exit motion, cannot create process id file (pid file) /var/run/motion/motion.pid: No such file or directory
[0] Motion going to daemon mode
PS: I have two thread file, because I have two webcams.
/dev/sda1 on /home/pi/usbdrv type vfat (rw,nosuid,relatime,sync,uid=1000,gid=1000,fmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors,remount-ro)
Tue Apr 22, 2014 4:31 pm
It look like the problem isn't with your USB device, but with the file /var/run/motion/motion.pid.
What are the permissions on /var/run and /var/run/motion (if it exists)?
ls -ld /var/run
ls -ld /var/run/motion
AlessioMTX
Wed Apr 23, 2014 9:59 am
[email protected] ~ $ ls -l
total 752
-rw-r--r-- 1 motion motion 190962 Apr 19 23:28 01-20140419232612.avi
-rw-r--r-- 1 motion motion 557284 Apr 19 23:35 02-20140419233318.avi
drwxr-xr-x 2 pi     pi       4096 Jan  7 23:09 Desktop
drwxrwxrwx 2 pi     pi       4096 Apr 20 11:42 Documents
drwxr-xr-x 3 pi     pi       4096 Mar 16 18:00 indiecity
drwxr-xr-x 9 pi     pi       4096 Jan  1  1970 usbdrv
[email protected] ~ $ ls -ld /var/run
lrwxrwxrwx 1 root root 4 Jan  7 22:01 /var/run -> /run
[email protected] ~ $ ls -ld /var/run/motion
ls: cannot access /var/run/motion: No such file or directory
Configuration files:
  1. /etc/motion/motion.conf
# Rename this distribution example file to motion.conf
# This config file was generated by motion 3.2.12
# Daemon
# Start in daemon (background) mode and release terminal (default: off)
daemon on
# File to store the process ID, also called pid file. (default: not defined)
process_id_file /var/run/motion/motion.pid
# Basic Setup Mode
# Start in Setup-Mode, daemon disabled. (default: off)
setup_mode off
# Capture device options
# Videodevice to be used for capturing  (default /dev/video0)
# for FreeBSD default is /dev/bktr0
; videodevice /dev/video0
# v4l2_palette allows to choose preferable palette to be use by motion
# to capture from those supported by your videodevice. (default: 8)
# E.g. if your videodevice supports both V4L2_PIX_FMT_SBGGR8 and
# V4L2_PIX_FMT_MJPEG then motion will by default use V4L2_PIX_FMT_MJPEG.
# Setting v4l2_palette to 1 forces motion to use V4L2_PIX_FMT_SBGGR8
# instead.
# Values :
# V4L2_PIX_FMT_SN9C10X : 0  'S910'
# V4L2_PIX_FMT_SBGGR8  : 1  'BA81'
# V4L2_PIX_FMT_MJPEG   : 2  'MJPEG'
# V4L2_PIX_FMT_JPEG    : 3  'JPEG'
# V4L2_PIX_FMT_RGB24   : 4  'RGB3'
# V4L2_PIX_FMT_UYVY    : 5  'UYVY'
# V4L2_PIX_FMT_YUYV    : 6  'YUYV'
# V4L2_PIX_FMT_YUV422P : 7  '422P'
# V4L2_PIX_FMT_YUV420  : 8  'YU12'
v4l2_palette 8
# Tuner device to be used for capturing using tuner as source (default /dev/tun$
# This is ONLY used for FreeBSD. Leave it commented out for Linux
; tunerdevice /dev/tuner0
# The video input to be used (default: 8)
# Should normally be set to 0 or 1 for video/TV cards, and 8 for USB cameras
input 8
# The video norm to use (only for video capture and TV tuner cards)
# Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
norm 0
# The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
frequency 0
# Rotate image this number of degrees. The rotation affects all saved images as
# well as mpeg movies. Valid values: 0 (default = no rotation), 90, 180 and 270.rotate 0
# Image width (pixels). Valid range: Camera dependent, default: 352
width 320
# Image height (pixels). Valid range: Camera dependent, default: 288
height 240
# Maximum number of frames to be captured per second.
# Valid range: 2-100. Default: 100 (almost no limit).
framerate 2
# Minimum time in seconds between capturing picture frames from the camera.
# Default: 0 = disabled - the capture rate is given by the camera framerate.
# This option is used when you want to capture images at a rate lower than 2 pe$
minimum_frame_time 0
# URL to use if you are using a network camera, size will be autodetected (incl$
# Must be a URL that returns single jpeg pictures or a raw mjpeg stream. Defaul$
; netcam_url value
# Username and password for network camera (only if required). Default: not def$
# Syntax is user:password
; netcam_userpass value
# The setting for keep-alive of network socket, should improve performance on c$
# 1.0:         The historical implementation using HTTP/1.0, closing the socket$
# keep_alive:  Use HTTP/1.0 requests with keep alive header to reuse the same c$
# 1.1:         Use HTTP/1.1 requests that support keep alive as default.
# Default: 1.0
; netcam_http 1.0
# URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
# If a port number other than 80 is needed, use "http://myproxy:1234".
# Default: not defined
; netcam_proxy value
# Set less strict jpeg checks for network cameras with a poor/buggy firmware.
# Default: off
netcam_tolerant_check off
# Let motion regulate the brightness of a video device (default: off).
# The auto_brightness feature uses the brightness option as its target value.
# If brightness is zero auto_brightness will adjust to average brightness value$
# Only recommended for cameras without auto brightness
auto_brightness off
# If auto_brightness is enabled, this value defines the average brightness level
# which Motion will try and adjust to.
# Valid range 0-255, default 0 = disabled
brightness 0
# Set the contrast of a video device.
contrast 0
# Set the saturation of a video device.
saturation 0
# Set the hue of a video device (NTSC feature).
hue 0
# Round Robin (multiple inputs on same video device name)
# Number of frames to capture in each roundrobin step (default: 1)
roundrobin_frames 1
# Number of frames to skip before each roundrobin step (default: 1)
roundrobin_skip 1
# Try to filter out noise generated by roundrobin (default: off)
switchfilter off
# Motion Detection Settings:
# Threshold for number of changed pixels in an image that
# triggers motion detection (default: 1500)
threshold 1500
# Automatically tune the threshold down if possible (default: off)
threshold_tune off
# Noise threshold for the motion detection (default: 32)
noise_level 32
# Automatically tune the noise threshold (default: on)
noise_tune on
# Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not def$
# Recommended value is EedDl. Any combination (and number of) of E, e, d, and D$
# (l)abeling must only be used once and the 'l' must be the last letter.
# Comment out to disable
despeckle EedDl
# Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2$
# A script (on_area_detected) is started immediately when motion is         4 5$
# detected in one of the given areas, but only once during an event.        7 8$
# One or more areas can be specified with this option. (Default: not defined)
; area_detect value
# PGM file to use as a sensitivity mask.
# Full path name to. (Default: not defined)
; mask_file value
# Dynamically create a mask file during operation (default: 0)
# Adjust speed of mask changes from 0 (off) to 10 (fast)
smart_mask_speed 0
# Ignore sudden massive light intensity changes given as a percentage of the pi$
# area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
# Picture frames must contain motion at least the specified number of frames
# in a row before they are detected as true motion. At the default of 1, all
# motion is detected. Valid range: 1 to thousands, recommended 1-5
minimum_motion_frames 1
# Specifies the number of pre-captured (buffered) pictures from before motion
# was detected that will be output at motion detection.
# Recommended range: 0 to 5 (default: 0)
# Do not use large values! Large values will cause Motion to skip video frames $
# cause unsmooth mpegs. To smooth mpegs use larger values of post_capture inste$
pre_capture 0
# Number of frames to capture after motion is no longer detected (default: 0)
post_capture 0
# Gap is the seconds of no motion detection that triggers the end of an event
# An event is defined as a series of motion images taken within a short timefra$
# Recommended value is 60 seconds (Default). The value 0 is allowed and disables
# events causing all Motion to be written to one single mpeg file and no pre_ca$
gap 60
# Maximum length in seconds of an mpeg movie
# When value is exceeded a new mpeg file is created. (Default: 0 = infinite)
max_mpeg_time 600
# Always save images even if there was no motion (default: off)
output_all off
# Image File Output
# Output 'normal' pictures when motion is detected (default: on)
# Valid values: on, off, first, best, center
# When set to 'first', only the first picture of an event is saved.
# Picture with most motion of an event is saved when set to 'best'.
# Picture with motion nearest center of picture is saved when set to 'center'.
# Can be used as preview shot for the corresponding movie.
output_normal on
# Output pictures with only the pixels moving object (ghost images) (default: o$
output_motion off
# The quality (in percent) to be used by the jpeg compression (default: 75)
quality 75
# Output ppm images instead of jpeg (default: off)
ppm off
# FFMPEG related options
# Film (mpeg) file output, and deinterlacing of the video input
# The options movie_filename and timelapse_filename are also used
# by the ffmpeg feature
# Use ffmpeg to encode mpeg movies in realtime (default: off)
ffmpeg_cap_new on
# Use ffmpeg to make movies with only the pixels moving
# object (ghost images) (default: off)
ffmpeg_cap_motion off
# Use ffmpeg to encode a timelapse movie
# Default value 0 = off - else save frame every Nth second
ffmpeg_timelapse 0
# The file rollover mode of the timelapse video
# Valid values: hourly, daily (default), weekly-sunday, weekly-monday, monthly,$
ffmpeg_timelapse_mode daily
# Bitrate to be used by the ffmpeg encoder (default: 400000)
# This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
ffmpeg_bps 500000
# Enables and defines variable bitrate for the ffmpeg encoder.
# ffmpeg_bps is ignored if variable bitrate is enabled.
# Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
# or the range 2 - 31 where 2 means best quality and 31 is worst.
ffmpeg_variable_bitrate 0
# Codec to used by ffmpeg for the video compression.
# Timelapse mpegs are always made in mpeg1 format independent from this option.
# Supported formats are: mpeg1 (ffmpeg-0.4.8 only), mpeg4 (default), and msmpeg$
# mpeg1 - gives you files with extension .mpg
# mpeg4 or msmpeg4 - gives you files with extension .avi
# msmpeg4 is recommended for use with Windows Media Player because
# it requires no installation of codec on the Windows client.
# swf - gives you a flash film with extension .swf
# flv - gives you a flash video with extension .flv
# ffv1 - FF video codec 1 for Lossless Encoding ( experimental )
# mov - QuickTime ( testing )
ffmpeg_video_codec mpeg4
# Use ffmpeg to deinterlace video. Necessary if you use an analog camera
# and see horizontal combing on moving objects in video or pictures.
# (default: off)
ffmpeg_deinterlace off
# Snapshots (Traditional Periodic Webcam File Output)
# Make automated snapshot every N seconds (default: 0 = disabled)
snapshot_interval 0
# Text Display
# %Y = year, %m = month, %d = date,
# %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
# %v = event, %q = frame number, %t = thread (camera) number,
# %D = changed pixels, %N = noise level, \n = new line,
# %i and %J = width and height of motion area,
# %K and %L = X and Y coordinates of motion center
# %C = value defined by text_event - do not use with text_event!
# You can put quotation marks around the text to allow
# leading spaces
# Locate and draw a box around the moving object.
# Valid values: on, off and preview (default: off)
# Set to 'preview' will only draw a box in preview_shot pictures.
locate off
# Draws the timestamp using same options as C function strftime(3)
# Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
# Text is placed in lower right corner
text_right %Y-%m-%d\n%T-%q
# Draw a user defined text on the images using same options as C function strft$
# Default: Not defined = no text
# Text is placed in lower left corner
; text_left CAMERA %t
# Draw the number of changed pixed on the images (default: off)
# Will normally be set to off except when you setup and adjust the motion setti$
# Text is placed in upper right corner
text_changes off
# This option defines the value of the special event conversion specifier %C
# You can use any conversion specifier in this option except %C. Date and time
# values are from the timestamp of the first image in the current event.
# Default: %Y%m%d%H%M%S
# The idea is that %C can be used filenames and text_left/right for creating
# a unique identifier for each event.
text_event %Y%m%d%H%M%S
# Draw characters at twice normal size on images. (default: off)
text_double off
# Target base directory for pictures and films
# Recommended to use absolute path. (Default: current working directory)
; target_dir /home/pi/usbdrv/camera/
# File path for snapshots (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-snapshot
# Default value is equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
# File extension .jpg or .ppm is automatically added so do not include this.
# Note: A symbolic link called lastsnap.jpg created in the target_dir will alwa$
# point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
snapshot_filename %v-%Y%m%d%H%M%S-snapshot
# File path for motion triggered images (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-%q
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
# Set to 'preview' together with best-preview feature enables special naming
# convention for preview shots. See motion guide for details
jpeg_filename %v-%Y%m%d%H%M%S-%q
# File path for motion triggered ffmpeg films (mpeg) relative to target_dir
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H%M%S
# File extension .mpg or .avi is automatically added so do not include this
# This option was previously called ffmpeg_filename
movie_filename %v-%Y%m%d%H%M%S
# File path for timelapse mpegs relative to target_dir
# Default: %Y%m%d-timelapse
# Default value is near equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d-timelapse
# File extension .mpg is automatically added so do not include this
timelapse_filename %Y%m%d-timelapse
# Live Webcam Server
# The mini-http server listens to this port for requests (default: 0 = disabled)
webcam_port 8081
# Quality of the jpeg (in percent) images produced (default: 50)
webcam_quality 50
# Output frames at 1 fps when no motion is detected and increase to the
# rate given by webcam_maxrate when motion is detected (default: off)
webcam_motion off
# Maximum framerate for webcam streams (default: 1)
webcam_maxrate 10
# Restrict webcam connections to localhost only (default: on)
webcam_localhost off
# Limits the number of images per connection (default: 0 = unlimited)
# Number can be defined by multiplying actual webcam rate by desired number of $
# Actual webcam rate is the smallest of the numbers framerate and webcam_maxrate
webcam_limit 0
# HTTP Based Control
# TCP/IP port for the http server to listen on (default: 0 = disabled)
control_port 8080
# Restrict control connections to localhost only (default: on)
control_localhost off
# Output for http server, select off to choose raw text plain (default: on)
control_html_output on
# Authentication for the http based control. Syntax username:password
# Default: not defined (Disabled)
# control_authentication
# Tracking (Pan/Tilt)
# Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=u$
# The generic type enables the definition of motion center and motion size to
# be used with the conversion specifiers for options like on_motion_detected
track_type 0
# Enable auto tracking (default: off)
track_auto off
# Serial port of motor (default: none)
; track_port value
# Motor number for x-axis (default: 0)
track_motorx 0
# Motor number for y-axis (default: 0)
track_motory 0
# Maximum value on x-axis (default: 0)
track_maxx 0
# Maximum value on y-axis (default: 0)
track_maxy 0
# ID of an iomojo camera if used (default: 0)
track_iomojo_id 0
# Angle in degrees the camera moves per step on the X-axis
# with auto-track (default: 10)
# Currently only used with pwc type cameras
track_step_angle_x 10
# Angle in degrees the camera moves per step on the Y-axis
track_step_angle_y 10
# Delay to wait for after tracking movement as number
# of picture frames (default: 10)
track_move_wait 10
# Speed to set the motor to (stepper motor option) (default: 255)
track_speed 255
# Number of steps to make (stepper motor option) (default: 40)
track_stepsize 40
# External Commands, Warnings and Logging:
# You can use conversion specifiers for the on_xxxx commands
# %f = filename with full path
# %n = number indicating filetype
# Both %f and %n are only defined for on_picture_save,
# on_movie_start and on_movie_end
# Quotation marks round string are allowed.
# Do not sound beeps when detecting motion (default: on)
# Note: Motion never beeps when running in daemon mode.
quiet on
# Command to be executed when an event starts. (default: none)
# An event starts at first motion detected after a period of no motion defined $
; on_event_start value
# Command to be executed when an event ends after a period of no motion
# (default: none). The period of no motion is defined by option gap.
; on_event_end value
# Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
# To give the filename as an argument to a command append it with %f
; on_picture_save value
# Command to be executed when a motion frame is detected (default: none)
; on_motion_detected value
# Command to be executed when motion in a predefined area is detected
# Check option 'area_detect'.   (default: none)
; on_area_detected value
# Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
; on_movie_start value
# Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
; on_movie_end value
# Command to be executed when a camera can't be opened or if it is lost
# NOTE: There is situations when motion doesn't detect a lost camera!
# It depends on the driver, some drivers don't detect a lost camera at all
# Some hang the motion thread. Some even hang the PC! (default: none)
; on_camera_lost value
# Common Options For MySQL and PostgreSQL database features.
# Options require the MySQL/PostgreSQL options to be active also.
# Log to the database when creating motion triggered image file  (default: on)
sql_log_image on
# Log to the database when creating a snapshot image file (default: on)
sql_log_snapshot on
# Log to the database when creating motion triggered mpeg file (default: off)
sql_log_mpeg off
# Log to the database when creating timelapse mpeg file (default: off)
sql_log_timelapse off
# SQL query string that is sent to the database
# Use same conversion specifiers has for text features
# Additional special conversion specifiers are
# %n = the number representing the file_type
# Default value:
# insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%$
sql_query insert into security(camera, filename, frame, file_type, time_stamp, ev
# Database Options For MySQL
# Mysql database to log to (default: not defined)
; mysql_db value
# The host on which the database is located (default: localhost)
; mysql_host value
# User account name for MySQL database (default: not defined)
; mysql_user value
# User password for MySQL database (default: not defined)
; mysql_password value
# Database Options For PostgreSQL
# PostgreSQL database to log to (default: not defined)
; pgsql_db value
; pgsql_host value
# User account name for PostgreSQL database (default: not defined)
; pgsql_user value
# User password for PostgreSQL database (default: not defined)
; pgsql_password value
# Port on which the PostgreSQL database is located (default: 5432)
; pgsql_port 5432
# Video Loopback Device (vloopback project)
# Output images to a video4linux loopback device
# The value '-' means next available (default: not defined)
; video_pipe value
# Output motion images to a video4linux loopback device
; motion_video_pipe value
# Thread config files - One for each camera.
# Except if only one camera - You only need this config file.
# If you have more than one camera you MUST define one thread
# config file for each camera in addition to this config file.
# Remember: If you have more than one camera you must have one
# thread file for each camera. E.g. 2 cameras requires 3 files:
# This motion.conf file AND thread1.conf and thread2.conf.
# Only put the options that are unique to each camera in the
# thread config files.
thread /etc/motion/thread1.conf
thread /etc/motion/thread2.conf
; thread /etc/motion/thread3.conf
  • /etc/motion/thread1.conf
# /etc/motion/thread1.conf
# Should normally be set to 1 for video/TV cards, and 8 for USB cameras
#  input 8
# Draw a user defined text on the images using same options as C function strftime(3)
text_left CAMERA 1
# Target Directories and filenames For Images And Films
# For the options snapshot_, jpeg_, mpeg_ and timelapse_filename
# you can use conversion specifiers
# Recommended to use absolute patch. (Default: current working directory)
target_dir /home/pi/usbdrv/camera/1
webcam_port 8081
  • /etc/motion/thread2.conf
# /etc/motion/thread2.conf
videodevice /dev/video1
# input 1
text_left CAMERA 2
target_dir /home/pi/usbdrv/camera/2
webcam_port 8082
Wed Apr 23, 2014 12:25 pm
OK, easiest fix here is to change the pid file definition to /var/run/motion.pid
There seems to be a bug in motion where the start init.d script decides that the file should be /var/run/motion.pid, but the default configuration tries to use /var/run/motion/motion.pid but doesn't create the directory.
AlessioMTX
Wed Apr 23, 2014 4:25 pm
Cool!!! Now it works! But only if I start motion with sudo.
If I start without sudo files are saved into user direcetory
[email protected] ~ $ motion
[0] could not open configfile /etc/motion/motion.conf: Permission denied
[0] Not config file to process using default values
[0] ffmpeg LIBAVCODEC_BUILD 3482368 LIBAVFORMAT_BUILD 3478785
[1] Thread 1 started
[1] cap.driver: "uvcvideo"
[1] cap.card: "Vimicro USB Camera (Altair)"
[1] cap.bus_info: "usb-bcm2708_usb-1.3.2"
[1] cap.capabilities=0x84000001
[1] - VIDEO_CAPTURE
[1] - STREAMING
[1] Config palette index 8 (YU12) doesn't work.
[1] Supported palettes:
[1] 0: YUYV (YUV 4:2:2 (YUYV))
[1] Selected palette YUYV
[1] Test palette YUYV (352x288)
[1] Adjusting resolution from 352x288 to 320x240.
[1] Using palette YUYV (320x240) bytesperlines 640 sizeimage 153600 colorspace 00000008
[1] found control 0x00980900, "Brightness", range -10,10
[1] 	"Brightness", default -8193, current 0
[1] found control 0x00980901, "Contrast", range 0,20
[1] 	"Contrast", default 57343, current 10
[1] found control 0x00980902, "Saturation", range 0,10
[1] 	"Saturation", default 57343, current 5
[1] found control 0x00980910, "Gamma", range 100,200
[1] 	"Gamma", default 57343, current 110
[1] mmap information:
[1] frames=4
[1] 0 length=153600
[1] 1 length=153600
[1] 2 length=153600
[1] 3 length=153600
[1] Using V4L2
[1] Resizing pre_capture buffer to 1 items
[1] File of type 1 saved to: ./01-20140423181440-01.jpg
[1] File of type 1 saved to: ./01-20140423181440-02.jpg
[1] File of type 1 saved to: ./01-20140423181440-03.jpg
[1] File of type 1 saved to: ./01-20140423181440-04.jpg
[1] File of type 1 saved to: ./01-20140423181440-05.jpg
[1] File of type 1 saved to: ./01-20140423181440-06.jpg
[1] File of type 1 saved to: ./01-20140423181440-07.jpg
[1] File of type 1 saved to: ./01-20140423181448-06.jpg
[1] File of type 1 saved to: ./01-20140423181448-07.jpg
[1] File of type 1 saved to: ./01-20140423181448-08.jpg
^C[1] Thread exiting
[1] Calling vid_close() from motion_cleanup
[1] Closing video device /dev/video0
[0] Motion terminating
Instead if I try to start the service:
[email protected] ~ $ sudo service motion start
[ ok ] Starting motion detection daemon: motion.
[email protected] ~ $ sudo service motion stop
[....] Stopping motion detection daemon: motionNo /usr/bin/motion found running; none killed.
. ok
Is this normal?
However, thank you!
Wed Apr 23, 2014 5:16 pm
Yes, that is normal.
You have motion configured to not start the daemon at start up, which is standard. The start script will run, but not start the daemon. The stop script will then tell you that the daemon isn't running (unless you have started it manually).
AlessioMTX
Thu Apr 24, 2014 9:21 am
OK, thank you!!! :D
