mcgyver83
0bda:8176 Realtek RTL8188CUS wifi
Sat Apr 19, 2014 9:11 am
I'm using Bus 001 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter usb wifi adapter.
Internet browsing speed is fine but when I copy files (via samba share) from the raspberry usb hdd (ext4 partition) to my desktop computer it's very slow, 200KBytes/sec.
Desktop is connected via ethernet and raspberry via wifi.
What happens?
Re: 0bda:8176 Realtek RTL8188CUS wifi
Sat Apr 19, 2014 9:59 am
Assuming you've got a reasonable power supply (if not use a powered hub) then it's probably something you'll just have to live with.
The Raspberry Pi isn't the fastest thing on the planet, it has a problem that ALL network and USB peripheral I/O goes through a single SMSC9512/9514 chip (it's driving the Ethernet and the USB hub (both ports)). You may get some improvements with later firmware but it will never be lightening fast.
mcgyver83
Sat Apr 19, 2014 12:07 pm
I0m using a nokia 1,2A power supply and directly plugged into rpi usb-wifi adapter.
Maybe the issue could be that I'm reading from usb HDD and sending data via wifi :(
pluggy
Sat Apr 19, 2014 7:14 pm
Just out of interest I hooked up a Pi B to an RTL8188CUS Wifi and a USB HDD directly with no USB hub (The HDD was externally powered) and using SSH/SCP to my Ubuntu PC I was able to achieve ~3.0 MB/s both to and from the Pi. Samba is a lot more pain to set up especially with a Linux PC but I can't honestly see Samba being a whole lot slower than SSH. My setup is subject to the same 'iffy' USB setup and the slow Pi.
mcgyver83
Mon Apr 21, 2014 8:35 pm
I'm in the same scenario: usb wifi dongle and usb hdd (external powered) attached directly to the rpi ports.
iffy? :shock:
I tried now from my ubuntu laptop, scp /rpi/folder /tmp/. and it transfer stuff at 60KByte/sec :roll: :roll: :roll:
