reslomo
Raspberry keeps crashing
Mon Apr 14, 2014 8:45 pm
Setup:
Raspberry Pi Model B running raspbmc (latest version).
My RPI keeps crashing when watching videos.
Sometimes its possible to watch a movie from beginning to end (even 19gb mkv) without any problems but sometimes it crashes every 20-30 minutes.
Already installed a fresh raspbmc distribution and checked the power supply..
Please let me know if you need other logs!
/var/log/messages
Apr 14 20:57:34 raspbmc kernel: Modules linked in: bcm2708_wdog ipv6 xt_state iptable_mangle iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_filter ip_tables x_tables snd_soc_bcm2708_i2s regmap_mmio snd_soc_core snd_compress regmap_i2c regmap_spi snd_pcm snd_page_alloc snd_timer snd i2c_bcm2708
Apr 14 20:57:34 raspbmc kernel: CPU: 0 PID: 2761 Comm: COMXPlayerAudio Not tainted 3.10.24 #2
Apr 14 20:57:34 raspbmc kernel: task: d781fbe0 ti: d6c38000 task.ti: d6c38000
Apr 14 20:57:34 raspbmc kernel: pc : [<c0054ba0>] lr : [<c0054ce8>] psr: 60000093
Apr 14 20:57:34 raspbmc kernel: sp : d6c39e18 ip : 00000000 fp : d6c39e54
Apr 14 20:57:34 raspbmc kernel: r10: d6a4ac80 r9 : 00000000 r8 : 00000410
Apr 14 20:57:34 raspbmc kernel: r7 : d6c38000 r6 : 00000001 r5 : 00000000 r4 : d6a4ac88
Apr 14 20:57:34 raspbmc kernel: r3 : 00000000 r2 : 00000001 r1 : c099e350 r0 : 1affff8c
Apr 14 20:57:34 raspbmc kernel: Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Apr 14 20:57:34 raspbmc kernel: Control: 00c5387d Table: 16acc008 DAC: 00000015
Apr 14 20:57:34 raspbmc kernel: Backtrace:
Apr 14 20:57:34 raspbmc kernel: Function entered at [<c0054b70>] from [<c04b0420>]
Apr 14 20:57:34 raspbmc kernel: Function entered at [<c04b0358>] from [<c04b0fd0>]
Apr 14 20:57:34 raspbmc kernel: Function entered at [<c04b0f98>] from [<c04af970>]
Apr 14 20:57:34 raspbmc kernel: Function entered at [<c04af8e0>] from [<c0049bc0>]
Apr 14 20:57:34 raspbmc kernel: Function entered at [<c0049ad8>] from [<c0049d70>]
Apr 14 20:57:34 raspbmc kernel: Function entered at [<c0049cd0>] from [<c000eea0>]
Apr 14 20:57:34 raspbmc kernel: r4:0000000a
Apr 14 20:57:34 raspbmc kernel: ---[ end trace 96f38adc385802c1 ]---
Apr 14 20:57:34 raspbmc kernel: note: COMXPlayerAudio[2761] exited with preempt_count 2
/var/log/kern.log
Apr 14 20:57:34 raspbmc kernel: Unable to handle kernel NULL pointer dereference at virtual address 00000040
Apr 14 20:57:34 raspbmc kernel: pgd = d6acc000
Apr 14 20:57:34 raspbmc kernel: [00000040] *pgd=16ac8831, *pte=00000000, *ppte=00000000
Apr 14 20:57:34 raspbmc kernel: Internal error: Oops: 17 [#1] PREEMPT ARM
Apr 14 20:57:34 raspbmc kernel: Process COMXPlayerAudio (pid: 2761, stack limit = 0xd6c381b0)
Apr 14 20:57:34 raspbmc kernel: Stack: (0xd6c39e18 to 0xd6c3a000)
Apr 14 20:57:34 raspbmc kernel: 9e00: d781fd60 d6a4ac80
Apr 14 20:57:34 raspbmc kernel: 9e20: c099e328 c099e2e0 c00541c8 5f97a7e0 d781fd60 d6c39f20 d6c38000 c099e2e0
Apr 14 20:57:34 raspbmc kernel: 9e40: c099e2e0 d781fbe0 d6c39e94 d6c39e58 c04b0420 c0054b7c c004ad84 c099de5c
Apr 14 20:57:34 raspbmc kernel: 9e60: 5f9751f0 00004d79 20000013 00989680 00000000 d6c39f20 00000000 d6c38000
Apr 14 20:57:34 raspbmc kernel: 9e80: d6c39f20 00000000 d6c39ea4 d6c39e98 c04b0fd0 c04b0364 d6c39efc d6c39ea8
Apr 14 20:57:34 raspbmc kernel: 9ea0: c04af970 c04b0fa4 0000c350 00000001 00000001 d6c39ec0 c004b97c c00415d8
Apr 14 20:57:34 raspbmc kernel: 9ec0: d781fd64 00000000 00000000 00000000 d68dae20 00989680 00000000 009959d0
Apr 14 20:57:34 raspbmc kernel: 9ee0: 00000000 00000001 d6c39f20 d6c38000 d6c39f84 d6c39f00 c0049bc0 c04af8ec
Apr 14 20:57:34 raspbmc kernel: 9f00: 20000013 00000000 d6c39f74 c000ea54 d6c38000 00000000 d6c39f3c d6c39f28
Apr 14 20:57:34 raspbmc kernel: 9f20: d6d51f20 00000000 00000000 00000000 6ae26374 00004d78 6ae1a024 00004d78
Apr 14 20:57:34 raspbmc kernel: 9f40: c0048328 c099de50 00000001 00000000 d781fbe0 a74ba1f0 000032b1 00000000
Apr 14 20:57:34 raspbmc kernel: 9f60: a74ba1f0 000032b1 000000a2 c000f024 d6c38000 00000000 d6c39fa4 d6c39f88
Apr 14 20:57:34 raspbmc kernel: 9f80: c0049d70 c0049ae4 00000000 00989680 a74bd470 0000000a 00000000 d6c39fa8
Apr 14 20:57:34 raspbmc kernel: 9fa0: c000eea0 c0049cdc 0000000a a74ba1f0 abffeca0 00000000 00000002 00000000
Apr 14 20:57:34 raspbmc kernel: 9fc0: 0000000a a74ba1f0 000032b1 000000a2 00de1740 a74ba1f0 00cb8440 00cb84a0
Apr 14 20:57:34 raspbmc kernel: 9fe0: 00000000 abffec98 b57a2ff8 b5764a24 80000010 abffeca0 00000000 001c4981
Apr 14 20:57:34 raspbmc kernel: Code: 0a00007e e3a09000 e3a08e41 ea000008 (e59c3040)
joan
Re: Raspberry keeps crashing
Mon Apr 14, 2014 9:06 pm
Have you overclocked the Pi?
ThomasS
Mon Apr 14, 2014 9:58 pm
Just to clarify, when you say 'checked the power supply', do you mean you measured the voltage?
ThomasS
Tue Apr 15, 2014 7:27 am
What audio device do you have connected? Is it in a powered hub?
You're also a long way behind the current 3.10.36+ kernel so you may want to use rpi-update to get current.
I'll do your homework for you for a suitable fee.
reslomo
Tue Apr 15, 2014 9:27 am
joan wrote:Have you overclocked the Pi?
Yes, but on "fast" setting on raspbmc.
Problem occurs even without overclocking.
ThomasS wrote:Just to clarify, when you say 'checked the power supply', do you mean you measured the voltage?
Yes, thats what I meant.
DougieLawson wrote:What audio device do you have connected? Is it in a powered hub?
Only audio output device is HDMI.
Okay thank you, I will update the FW later.
GTR2Fan
Tue Apr 15, 2014 9:52 am
Just to clarify the "checked the power supply" part. How did you check it? Did you measure between the two test points with the Pi playing Full-HD video? Was it always above 4.75V?
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
reslomo
Tue Apr 15, 2014 1:16 pm
GTR2Fan wrote:Just to clarify the "checked the power supply" part. How did you check it? Did you measure between the two test points with the Pi playing Full-HD video? Was it always above 4.75V?
Yes, thats what I did.
I also read about measuring the fuse, but I had some difficulties with my multimeter so I skipped that part (afaik a broken fuse would cause other problems than mine).
reslomo
Wed Apr 16, 2014 5:19 pm
DougieLawson wrote: You're also a long way behind the current 3.10.36+ kernel so you may want to use rpi-update to get current.
Im running Raspbmc and its suggested not to patch the kernel manually.
And others suggestions?
