Crazy
No signal with DVI Adaptor
Wed Apr 02, 2014 3:33 pm
Hi, I need help to connect my raspberry pi to my monitor via an adapter that is now 3H I trials to have any signal but in vain all that I have the right:
Check Cable> No signal> Communication standby
On a screen philips 1920x1080 60Hz
I tried every combination with unimaginable hdmi_mode / hdmi_group
I put hdmi_drive 1 (I precise I do not need her)
PS: I just tried on a Samsung screen works perfectly remains only to find a philips
I hope to find help.
thank you
RaTTuS
Contact: Twitter YouTube
Re: No signal with DVI Adaptor
Wed Apr 02, 2014 3:55 pm
hdmi_force_hotplug=1 may work
what is the contents of your
/boot/config.txt
file
Covfefe
Crazy
Wed Apr 02, 2014 4:07 pm
Already test
My config:
# uncomment if you get no picture on HDMI for a default "safe" mode
#hmdi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=16
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=1
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
arm_freq=700
# for more options see http://elinux.org/RPi_config.txt
core_freq=250
sdram_freq=400
over_voltage=0
RaTTuS
Wed Apr 02, 2014 4:12 pm
post a link to this adapter
Covfefe
Crazy
Wed Apr 02, 2014 4:18 pm
Crazy
Wed Apr 02, 2014 6:01 pm
Anyone?
FTrevorGowen
Wed Apr 02, 2014 8:55 pm
Crazy wrote:Already test
My config:
hdmi_group=2
hdmi_mode=16
From my notes here:
http://www.cpmspectrepi.webspace.virgin ... _VGA_Input ("3-port HDMI Switch --> HDMI to VGA Converter --> Basic VGA Switch --> TV's VGA Input" section)
the above settings (should) force a "VGA-like" 1024 x 768 @60Hz DMT mode which may be not what you want/need.
What happens if you (re-)comment out or remove those lines?
Trev.
RaTTuS
Thu Apr 03, 2014 7:57 am
Crazy wrote:http://www.ebay.fr/itm/Adaptateur-DVI-M ... 2c68736424
Work on my Samsung 1680x1050 20'
I use one of those with no issues [though I do have to force HDMI]
sorry I cannot help any more than that
Covfefe
Crazy
Thu Apr 03, 2014 10:34 am
My config:
hdmi_group=2
hdmi_mode=16
From my notes here:
Trev.
Itry with only
hdmi_group=2
hdmi_mode=16
un recomment all other option
But have black screen----->Check Cable
GTR2Fan
Thu Apr 03, 2014 10:44 am
RaTTuS says that he has to force HDMI with the same adapter, so maybe try adding...
hdmi_drive=2
...to your exisiting commands?
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
FTrevorGowen
Thu Apr 03, 2014 12:49 pm
Crazy wrote:
My config:
hdmi_group=2
hdmi_mode=16
From my notes here:
Trev.
Itry with only
hdmi_group=2
hdmi_mode=16
Slight misunderstanding here perhaps? I meant comment out (or remove) those lines so that the Pi is not "forced" to use/try 1024 x 768 @60Hz (which may not be O.K. for your monitor). One thing that appears to be absent from your config.txt is hdmi_force_hotplug=1 which will ensure that HDMI is in use (rather than composite video) if your cable/monitor is not passing through/providing the expected "hotplug" signal.
Trev.
