BreadedFungus
Raspberry Pi acting erratic despite new install
Thu Mar 27, 2014 5:15 pm
I decided to reinstall Rasbian onto my Raspberry Pi, via NOOBS. I'm using all default settings except I have the thing overclocked at 800mHz. I type things into the CLI but my inputs seem to be not registering consistantly. When i finally log in I type startx to get to the GUI. I experience the same issuses with the LXTerminal. Sometimes the mouse freezes, and I can't move it, and I have to reboot the system. I decide after 5 times of experienceing these issues, and rebooting, to reformat the SD card and reinstall Rasbian, via NOOBS, ALL defaults and I experience the same issues. I know it is not my keyboard and mouse becuae I tested those on my normal computer and they worked fine. Its not my USB ports because I have a usb fan and it worked on both of my USB ports.
ThomasS
Re: Raspberry Pi acting erratic despite new install
Thu Mar 27, 2014 7:26 pm
Sounds like a power supply problem. Try another and see if that helps.
ThomasS
BreadedFungus
Thu Mar 27, 2014 7:48 pm
I have a model B. My adaptor says it has an output of 5V, and 700 mA. Is this enough? The power requirements of the FAQ says that the model B uses 700-1000mA. Is this input or output?
ThomasS
Thu Mar 27, 2014 7:58 pm
It should be, but adapters don't always output the power they say they do. If you have another micro-usb phone charger lying around, you could try that.
ThomasS
redhawk
Thu Mar 27, 2014 8:29 pm
Kernel panics, freezing or reboots are classic symptoms of an unsuitable power supply or F3 polyfuse going bad.
Sometimes even measuring the voltage at TP1/TP2 may look normal, but don't be fooled it's not always a good indicator as I have discovered with one of my phone chargers.
Richard S.
