NicoVanDerDussen
White Space Issues
Sat Mar 22, 2014 11:50 am
while setting up a 3G modem, I configured wvdial and had lots of trouble.
I copied the configuration from http://nvdd.info/1iNncLt into Nano
And I got error messages that there was no Dialer Section 3gconnect when using this config file.
From my early Linux experience many years ago, I remembered that this could be due to "white space issues" eg the ^M problem.
But I could not remember how to view the "white space characters"
In the end I manually deleted all the spaces and end of lines and replaced them by hand with the required character (space bar or enter key)
This did solve the problem.
What is the better way of correcting such problems?
How can one make it visible easier?
and how does one prevent it from happening?
Nico
Setting up your Raspberry Pi to work with a 3G dongle http://nvdd.info/11gKrsZ
Re: White Space Issues
Sat Mar 22, 2014 11:55 am
Easier than trying to see them is to simply get rid of them
sudo apt-get install dos2unix
dos2unix windows.text.file.txt
If you use vi (aka vim) it will show the DOS chars.
rpdom
Sat Mar 22, 2014 1:27 pm
Using the "file" command can help you detect those bad line endings.
As an example I created a Linux text file called "jim" and then made a copy of it with "DOS" style line endings called fred. This is the ouput of using the "file" command on them.
pi@raspberrypi:~$ file fred jim
fred: ASCII text
jim:  ASCII text, with CRLF line terminators
You can then fix the file using a number of methods, but the way dougie suggested is a good one.
