RunningForNoReason
RPI-Update issue
Thu Mar 20, 2014 8:16 am
The following error started to appear today using rpi-update:
GnuTLS: A TLS warning alert has been received.
Unable to establish SSL connection.
!!! Failed to download update for rpi-update!
!!! Make sure you have ca-certificates installed and that the time is set correctly
I did a :
update-ca-certificates
No luck any ideas?
SkyRise
Re: RPI-Update issue
Thu Mar 20, 2014 8:43 am
Have you tried:
sudo apt-get install ca-certificates
Not sure why they wouldn't have been installed as standard, but worth a try.
RunningForNoReason
Thu Mar 20, 2014 8:50 am
The certificates are installed and I performed an update which did not resolve the error
joan
Thu Mar 20, 2014 8:57 am
Check that your Pi's date and time is correct.
RunningForNoReason
Thu Mar 20, 2014 9:05 am
Date and time is correct, used it without issue till today
Nefarious1
Thu Mar 20, 2014 9:13 am
I am getting the same error as well, so likely an issue on rpi's side. Just try again later.
ortega
Thu Mar 20, 2014 9:28 am
Same issue for me. It worked fine yesterday evening.
Already installed ca-certificates and the other suggested "commands" to solve this issue, but nothing is working.
fruizalonso
Thu Mar 20, 2014 11:12 am
I have now the same problem as Ortega. Last night rpi-update works. Now, TLS warning.
Github's issues maybe?
sharix
Thu Mar 20, 2014 12:21 pm
Same here, certificates and time are set up correctly.
MrEngman
Thu Mar 20, 2014 1:52 pm
And same here as well. certificates and time are correct.
MrEngman
bullrider
Thu Mar 20, 2014 3:00 pm
this fixed the issue for me.
sudo apt-get install libgnutls28 libgnutlsxx28 libgnutls-dev gnutls-dev
cheers
sharix
Thu Mar 20, 2014 3:30 pm
bullrider wrote:this fixed the issue for me.
cheers
I get errors:
E: Unable to locate package libgnutls28
E: Unable to locate package libgnutlsxx28
sudo apt-get update; apt-cache search libgnutls
libgnutls-dev - GNU TLS library - development files
libgnutls-openssl27 - GNU TLS library - OpenSSL wrapper
libgnutls26 - GNU TLS library - runtime library
libgnutls26-dbg - GNU TLS library - debugger symbols
libgnutlsxx27 - GNU TLS library - C++ runtime library
python-gnutls - Python wrapper for the GNUTLS library
bullrider
Thu Mar 20, 2014 3:35 pm
my /etc/apt/sources.list
deb http://mirror.netcologne.de/raspbian/raspbian/ wheezy main contrib non-free rpi firmware
deb-src http://mirror.netcologne.de/raspbian/raspbian/ wheezy main contrib non-free rpi firmware
make sure you have all
do a apt-get update and try again, good luck!
OR replace 28 with 26
libgnutls26 ..... libgnutlsxx26
MrEngman
Thu Mar 20, 2014 3:38 pm
cheers
Didn't help me. I got
[email protected] $ sudo apt-get install libgnutls28 libgnutlsxx28 libgnutls-dev gnutls-dev
Reading package lists... Done
Building dependency tree
Package gnutls-dev is a virtual package provided by:
  libgnutls28-dev 3.0.20-3
  libgnutls-dev 2.12.20-8+deb7u1
You should explicitly select one to install.
E: Package 'gnutls-dev' has no installation candidate
MrEngman
ortega
Thu Mar 20, 2014 3:39 pm
I've got this message:
I have tried to install both of them but for me the rpi-update problem is still there.
ortega
Thu Mar 20, 2014 3:59 pm
bullrider wrote:my /etc/apt/sources.list
Thanks for your support, but unfortunately for me is not working, I have update the sources like you said, and tested to change 28 to 26 (and combinations... 26 28, 28 26 :D ) but still the error. Thanks again.
Nefarious1
Thu Mar 20, 2014 5:20 pm
cheers
I tried this and no luck. Thanks for offering it though.
bullrider
Thu Mar 20, 2014 5:43 pm
have you installed libgnutls26 then ? are you on wheezy? maybe switch to anther mirror in sources.list
$ lsb_release -a;uname -a;apt-cache search libgnutls
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 7.2 (wheezy)
Release:        7.2
Codename:       wheezy
Linux raspberrypi 3.10.33+ #658 PREEMPT Tue Mar 18 17:35:55 GMT 2014 armv6l GNU/Linux
libgnutls28 - GNU TLS library - main runtime library
libgnutls28-dbg - GNU TLS library - debugger symbols
libgnutls28-dev - GNU TLS library - development files
libgnutlsxx28 - GNU TLS library - C++ runtime library
g7ruh
Thu Mar 20, 2014 5:59 pm
Two PIs here, one with latest firmware, one with 14th Feb firmware: both refuse to let rpi-update complete and stop with "GnuTLS: A TLS warning alert has been received."
All worked fine yesterday on the one with the latest update.
not changed ca-certificates and date / time correct on both.
Strange unless a certificate has expired?
MrEngman
Thu Mar 20, 2014 6:18 pm
Just tried with raspbian 3.10.25+, 2013-12-20-wheezy-raspbian, and rpi-update appears to work although I interrupted it before it started downloading files.
[email protected] ~ $ sudo rpi-update
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS
 *** Performing self-update
--2014-03-20 18:04:30--  https://github.com/Hexxeh/rpi-update/raw/master/rpi-update
Resolving github.com (github.com)... 192.30.252.128
Connecting to github.com (github.com)|192.30.252.128|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://raw.githubusercontent.com/Hexxeh/rpi-update/master/rpi-update [following]
--2014-03-20 18:04:37--  https://raw.githubusercontent.com/Hexxeh/rpi-update/master/rpi-update
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.31.18.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.31.18.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 7174 (7.0K) [text/plain]
Saving to: `/usr/bin/rpi-update.tmp'
100%[==============================================================================================>] 7,174       --.-K/s   in 0.04s
2014-03-20 18:04:43 (157 KB/s) - `/usr/bin/rpi-update.tmp' saved [7174/7174]
 *** Relaunching after update
 *** ARM/GPU split is now defined in /boot/config.txt using the gpu_mem option!
 *** We're running for the first time
 *** Setting up firmware (this may take a few minutes)
Cloning into '//root/.rpi-firmware'...
Connects to same IP as the failing version which is raspbian 3.10.33+ #658 Mar 18. but doesn't even get to download update for rpi-update
[email protected] /mnt/home/pi $ sudo rpi-update
--2014-03-20 18:03:12--  https://github.com/Hexxeh/rpi-update/raw/master/rpi-update
Resolving github.com (github.com)... 192.30.252.131
Connecting to github.com (github.com)|192.30.252.131|:443... connected.
--2014-03-20 18:03:17--  https://raw.githubusercontent.com/Hexxeh/rpi-update/master/rpi-update
ca-certificates are up to date and time is right.
Tried bullrider's suggestions which gave various problems with package names and still no joy.
MrEngman
caldimerda
Thu Mar 20, 2014 6:21 pm
Really hope someone can get to grips with this. Something has changed :?
rpi-update fails for me on the more recent builds. I also have one that's in need of an update:
Linux ron04 3.6.11+ #368 PREEMPT Sun Feb 3 18:35:57 GMT 2013 armv6l GNU/Linux
And the self-update wget works on that - into the temp file - although I'm not actually actioning the update because I liike having an old, working raspi for this very reason!
I also see theregister ran a recent story on a bug in GnuTLS: http://www.theregister.co.uk/2014/03/05 ... patch_now/
Thicko_1970
Thu Mar 20, 2014 6:50 pm
Damn. I can't rpi-update, on any of my RPi. I've been looking forward to trying out the new camera modes, while away on holiday, but I guess I will have to just try again tomorrow and throw a baby tantrum, if I can't get it.
[email protected]
MrEngman
Thu Mar 20, 2014 7:35 pm
I have just run rpi-update on a pi with raspbian 3.10.25+ #622 loaded via NOOBS
It now shows 3.10.33+ #658. I then ran rpi-update again and there was NO problem and it reported firmware was up to date. I deleted file /boot/.firmware_revision to allow rpi-update to run completely again and rpi-update ran OK and reinstalled the firmware without problems.
So I now have 2 cards with raspbian 3.10.33+ #658 installed. rpi-update works ok on one, the one originally installed via NOOBS, and a second card which was installed from rasbian image 2014-01-07-wheezy-raspbian and updated using rpi-update and now rpi-update does NOT work. I had also run apt-get update and upgrade on the second card, but not the first, so just going to try apt-get on the first card to see if that makes any difference.
OK ran apt-get update and apt-get upgrade on the card that still works and now rpi-update FAILS to run. apt-get update installed 20 new files so I presume one of them has screwed things up. Really, really helpful.
MrEngman
ThomasS
Thu Mar 20, 2014 9:11 pm
Same problem. I have tried the posted solutions. Any advice? :(
ThomasS
caldimerda
Thu Mar 20, 2014 9:33 pm
If you're up for editing /usr/bin/rpi-update, then copy it to /home/pi and remove the "update_self" function. That function creates a "rpi-update.tmp" file containing the downloaded copy of itself - so I also copied /usr/bin/rpi-update to /home/pi/rpi-update.tmp.
Then you have the script and the .tmp copy in /home/pi. Make it executable and run it. The rest of the script runs just fine.
Caveat emptor - and good luck. I just tried it - don't think I did anything else!
Incidentally it appears the error causing rpi-update to fail is intermittent but will recur until wget is updated to a newer version.
