Mouse not clicking well
Posted: Fri Jun 01, 2012 8:21 pm
by Scotty T
I didn't see anything on the troubleshooting section.
I have to click several times to get something to open in X windows. Some times it's hit or miss.
Some times I can click it and other times it seems like I need to click it just right.
Ideas?
Re: Mouse not clicking well
Posted: Fri Jun 01, 2012 8:28 pm
by Scotty T
Nevermind, I found it.
Posted: Fri Jun 01, 2012 9:16 pm
by Grumpy Mike
Go on tell us what it was, there could be others with the same problem.
Posted: Sat Jun 02, 2012 6:15 pm
by Scotty T
It's right in the RPI troubleshooting guide.
http://elinux.org/R-Pi_Troubleshooting# ... ey_presses
Found an external hub that provides max of 500mAh to the port.
I'm still convinced not having a GPU driver makes the mouse run a little less effective, but we will see what happens when the GPU driver is developed.
Posted: Tue Jun 23, 2015 8:46 pm
by johnthethird
Three years ago and "Never mind I have it solved."
I have the problem that the mouse click time can not be changed.
I do not think it is a power supply problem.
The mouse click must be fast or no effect.
If I use Menu, Preferences, Windows Settings, Mouse, Double click time,
it has no effect.
Openbox Configuration Manage comes preinstalled and I did try to install it again.
I am using a pi 2 with raspbrian.
Posted: Wed Jun 24, 2015 4:01 am
by johnthethird
Never mind I found the answer.
Should I leave it at that? but just is case another has this problem:
viewtopic.php?f=63&t=48814
sudo nano ~/.gtkrc-2.0
gtk-double-click-time=1000
I assume the 1000 can be adjusted as you like.
