Maritime_pi
Is my pi secure?
Sun Mar 16, 2014 4:20 am
I have a pi web server. I use port forwarding for 80 and 443 and I have fail2ban running. I have changed the user name and password on my pi and removed the test database from MYSQL. I have a domain name that points to my IP address given to me by my ISP. My iptables file has a default of INPUT DROP and only 80 and 443 are accepted. I thought that I had to expose my server in the DMZ, but I found that with port forwarding I do not have to do that. Is there anything more that I should do?
DeeJay
Re: Is my pi secure?
Sun Mar 16, 2014 9:57 am
You have said nothing about your webserver itself. The security of your system depends absolutely on how well it was written and how carefully it has been configured.
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
Sun Mar 16, 2014 10:05 am
The other thing you MUST do is
sudo apt-get update && sudo apt-get upgrade
EVERY WEEK to stay current with security fixes.
This is a doctor free zone.
Maritime_pi
Mon Mar 17, 2014 12:55 am
Thank you for the replies and constructive criticisms. I am weak on all of these technical subjects, but weakest on the subject of web servers. I will be doing more research and work on the LAMP stack as time goes by.
Regards
iinnovations
Mon Mar 17, 2014 1:51 am
One important thing is controlling who can log in remotely.
Add to /etc/ssh/sshd_config
AllowGroups sshers
This restricts ssh access to members of the sshers group.
Add pi (or your preferred username), and whatever user you might use to upload web content, whatever, to the sshers group:
sudo addgroup sshers
sudo usermod -aG sshers pi
MAKE SURE to use the -a option and capitalize the G. Forgetting the -a will make sshers your only group. This includes sudoers. If you have a root password, this is easily undone. If not, it's not.
Restart sshd and you've disabled root ssh access.
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
gkreidl
Mon Mar 17, 2014 6:42 am
Did you set a password for root? Otherwise any intruder can use sudo and has access to the complete system.
Minimal Kiosk Browser (kweb)
rgrbic
Fri Jun 13, 2014 11:28 am
Here you can find small article with tips how to improve security of your Raspberry Pi. In essence, keep your system up to date, use key authentication and install some kind of software which parse your log files and automatically bans suspicious IP adresses (like fail2ban). However, services that are running on your Pi usually need some kind of tweaking. For example, ask yourself do you really need remote connection to mysql database or you need connection only from localhost? Make users with minimal required privileges, do you really need phpmyadmin and so on...
At 127.0.0.1
Twitter: @rgrbic
IoT-projects.com
LinuxUser42
Fri Jun 13, 2014 4:21 pm
DougieLawson wrote:The other thing you MUST do is
Even then, that only helps with ones that are patched. Just pointing out some security fixes take longer then others, and bugs (like Heartbleed) may be out in the wild, just not openly published.
Security is unfortunately, never 100% and I hate it when people get that impression.
cyrano
Fri Jun 13, 2014 10:47 pm
Security is a state of mind.
Even good software isn't secure without good practices. Use a really long passphrase and only for one service. Change the passphrase every now and then.
Make sure to have an offline backup. If you suspect there's been a breach but can't prove it, taking the system offline and replacing with a backup gets you running again fast. And you can study the offline system at your ease, if you need to.
Keep every step documented. I got severely bitten last week because I added dotdeb to the repository list a year ago and forgot about it. I only needed one lib from dotdeb, but forgot to document it. A year later, I managed to eradicate php by patching/updating other stuff and landing in dependency hell...
Security may also mean protection from one's own idiocy.
