RandomPerson wrote:THERE IS NOTHING WRONG WITH THE STUPID TV IT WORKED BEFORE I WALKED UP TO THE PI AND GAVE IT A STATIC SHOCK AND NOW IT IS BROKEN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sorry to confuse you but I never said anything about a broken TV......
The RPi has 2 types of video outputs, HDMI and Composite (NTSC). If your burned the Composite output (ON THE RPi), then try the HDMI output using an HDMI monitor or TV with HDMI inputs.
If the HDMI and Composite both don't work then try to connect to the RPi remotely from another computer. If that does not work then bin the RPi.
Also here is some basic ESD info:
Handling Precautions:
The Raspberry Pi board has exposed circuitry and electronic components which are subject to irreparable damage or destruction by static electricity.
You don't have to see, hear or feel a Electro-Static Discharge (ESD). Damage can be done without knowing it.
Damage is not always instantaneous. ESD related failure can show up days or months later.
You must take anti static ESD precautions as you would with all exposed electronic circuits such as memory cards, motherboards, peripheral cards etc.
- Avoid carrying the RPi in your bare hands especially when walking across a carpeted floor. If you have to, then hold the board by the edges and discharge static from you body before setting the board down.
- When transporting use the anti static bag that came with your RPi. Never use a common 'zip lock' or other type of bag.
- Discharge static from your body by touching a grounded metal object before handling the RPi board.
Also do not allow metal objects to come into contact with a powered on RPi board, especially the GPIO pins
