bigguyone wrote:Yes this is what i did downloaded NOOBS and downloaded OPEN ???? (forgot what it said now). Now i did the first download with HDMI at home and it did just fine. But when hook to older TV didnt work out to good, thats when i downloaded raspberrybmc and still came up with samething. So with doing it the last download sould it have work with older tv? Also could i copy my one sdcard to this one? I know it works on both HDMI & other tv.
"OPEN ????" probably == OpenELEC ?
Unfortunately, as indicated in my previous post, once you've used NOOBS to install any O.S. (or multiple O.S.'s) using an HDMI video device you
cannot simply move the Pi, change the connecting leads etc., and use it with a composite video device. (NOOBS assumes you're only going to be using one type of video device with a given SDHC card installation). However, you
can have one SDHC card setup for HDMI and another card setup for composite (and maybe use a USB flash drive to share files between setups). Or, for Raspbian, but perhaps not Arch, OpenELEC, RaspBMC etc. (I don't use those distro's much, so I'm not sure),
if you install by the "raw image" method**, you
may (still) be able to use one card only because Raspbian
may be able to detect the absence of an HDMI hotplug signal (if your monitor/TV/cable connection provides that in the first place) and thus "fall back" to composite video mode.
Trev
** http://www.raspberrypi.org/downloads "Raw Images" section
