Cross compiling from OSX section in elinux.org maybe wrong
Posted: Wed Feb 26, 2014 1:37 am
by lilzz
It says Complete script requires raspberrypi.config to be in the same folder that you execute from
http://elinux.org/RPi_Kernel_Compilatio ... nel_source
#Make a case sensitive 3gb disk image, raspberrypi-kernel, and attach it
hdiutil create -size 10g -type SPARSEBUNDLE -nospotlight -volname raspberrypi-kernel -fs "Case-sensitive Journaled HFS+" -attach ./raspberrypi-kernel.dmg
cp raspberrypi.config /Volumes/raspberrypi-kernel/
mkdir /Volumes/raspberrypi-kernel/src
cd /Volumes/raspberrypi-kernel/src
That Scriot won't work because it's creating volume on the Raspberry Pi. It says secpificailly this is for crossing-compiling on a mac for Raspberry Pi. That script won't run on a Mac for sure.
Re: Cross compiling from OSX section in elinux.org maybe wro
Posted: Wed Feb 26, 2014 9:11 am
by tvjon
Have you simply read these statements & believe them to be wrong, or actually tried them?
"That Scriot won't work because it's creating volume on the Raspberry Pi. It says secpificailly this is for crossing-compiling on a mac for Raspberry Pi. That script won't run on a Mac for sure."
Actually, it does run fine on a mac.
I've just run that first line "hdiutil ...." on a macbook
& it has created a sparse image of < 1K & then mounted it in Finder. It's visible in the sidebar too. I can now write files just fine to that image. It's a useful feature & I've used that idea (for OS X, not Linux stuff) several times over the years.
As I'm interested in RPi, I prefer to build natively on RPi where possible, but if I can find some time, I'll install Yagarto again (mine was an older version). Obviously build times will be faster on a mac.
