docmorris
No Internet Connection
Tue Feb 25, 2014 9:49 pm
Hey!
I just started my Raspberry Pi with Raspbian for the first time.
It is connected to my router/network via ethernet and I had no trouble at all connecting to it via SSH.
The thing is, when I use
sudo apt-get update
, I get a lot of errors which indicate that I have no working internet connection.
I tried pinging IPs and google.com but it doesn't work either.
What can I do about this?
Thanks in advance! ;)
Re: No Internet Connection
Wed Feb 26, 2014 5:15 am
First please show output of the following commands:
cat /etc/network/interfaces
/sbin/ifconfig -a
/sbin/route
cat /etc/resolv.conf
These will show the configuration of your networking.
docmorris
Wed Feb 26, 2014 3:13 pm
Alright.
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
/sbin/ifconfig -a
eth0      Link encap:Ethernet  HWaddr b8:27:eb:96:f7:79
          inet addr:192.168.178.66  Bcast:192.168.178.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:359 errors:0 dropped:0 overruns:0 frame:0
          TX packets:220 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:28504 (27.8 KiB)  TX bytes:32388 (31.6 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
/sbin/route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.178.0   *               255.255.255.0   U     0      0        0 eth0
nameserver 8.8.8.8
Thanks a lot.
ripat
Wed Feb 26, 2014 3:23 pm
you have no route to your gateway. Try
$ sudo route add default gw <ip of your router/modem)>
# or
$ sudo ip route add default via  <ip of your router/modem)>
Using Linux command line usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
docmorris
Thu Feb 27, 2014 2:11 pm
ripat wrote:you have no route to your gateway. Try
# or
Worked! Thanks a lot!!
ripat
Thu Feb 27, 2014 5:34 pm
You now have to make it persistent. For some reason your DHCP server (router?) failed to give you a valid route to the gateway. Investigate that first. If no luck with that and in last resort, consider giving your RPi a static address in the /etc/network/interfaces file. For example:
iface eth0 inet static
    address 192.168.0.205
    netmask 255.255.255.0
    gateway 192.168.0.200
If you prefer to configure your network interfaces in DHCP and you could not find out why the DHCP failed to send a valid route, you can try this trick
post-up ip route add default via  192.168.0.200 || true
The conditional || true is there to prevent the ifup command that reads the interfaces file to stall if the post-up stanza fail for some reason.
jayman27
Fri Feb 28, 2014 3:11 am
I'm in the exact same situation.
Although, when I enter...
sudo route add default gw (IP)
I get...
siocaddrt: network is unreachable
ripat
Fri Feb 28, 2014 6:03 am
Can you post the result of
sudo ifconfig
sudo route -n
Fri Feb 28, 2014 5:45 pm
jayman27 wrote:I'm in the exact same situation.
I get...
The command is
sudo route add default gateway [ipaddr] dev eth0
or
sudo ip route add default via [ipaddr] dev eth0
jojopi
Fri Feb 28, 2014 5:55 pm
"sudo route add default gw (IP)" is absolutely fine. The error "Network is unreachable" means that the gateway IP you are trying to add is not in any of your local subnets.
So, you are not in the exact same situation. You have no IP address at all, or one that is completely wrong.
jayman27
Fri Feb 28, 2014 6:30 pm
Thanks everyone for the help, but aparently I just needed to wait a day. I booted my pi and the internet now works. Not sure why I had no luck yesterday (booted a bunch of times), but I'm happy everything is on track. This is my first attempt at anything pi related, it's nice to know there are people ready to help so quickly. :D
