Unfortunately no success. The network connection still drops after a while.jdb wrote:Update:
The BRANCH=next firmware now has a fix for one of the potential sources of the "FIQ reported NYET" messages seen when using a heavily loaded system. It may also fix cases where network devices suddenly stop responding.
What is your Pi being used as?Forage wrote:Unfortunately no success. The network connection still drops after a while.jdb wrote:Update:
I'm using MilhouseVH's 'daily' build of OpenElec, thus using it solely as an XBMC machine.jdb wrote:What is your Pi being used as?Forage wrote:Unfortunately no success. The network connection still drops after a while.jdb wrote:Update:
You mean the output of dmesg right after boot or as soon as the network connection is lost again?jdb wrote:Can you post a full dmesg since boot?
Unable to establish SSL connection.
!!! Failed to download update for rpi-update!
!!! Make sure you have ca-certificates installed and that the time is set correctly
A load of people have come across this problem in the last few days. Take a look here for a fix. http://www.raspberrypi.org/phpBB3/viewt ... 19#p523519B+W wrote:Sorry for mentioning this again, but am I the only one unable to redownload the BRANCH=next rpi-update?
https://github.com/Hexxeh/rpi-update is now missing the next branch and "sudo BRANCH=next rpi-update" is giving me this error:ca-certificates is installed. Date and time is correct.Code: Select all
Unable to establish SSL connection. !!! Failed to download update for rpi-update! !!! Make sure you have ca-certificates installed and that the time is set correctly
Thank you.
Thank you for the reply. I don't think I've ever manually updated this way. How would this work for installing the next branch?MrEngman wrote: A load of people have come across this problem in the last few days. Take a look here for a fix. http://www.raspberrypi.org/phpBB3/viewt ... 19#p523519
Just to let you know that after this fix I haven't seen any "FIQ reported NYET" messages (OpenELEC based on 3.13.y-next) - 2.5 days uptime and dmesg is 100% clear, excellent stuff!jdb wrote:Update:
Please test and report back any changes.
Getting a log was easier said than done on OpenElec. To get it I used a script that created a log every 15 minutes.jdb wrote:Can you post a full dmesg since boot?Forage wrote:Unfortunately no success. The network connection still drops after a while.jdb wrote:Update:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.13.6 ([email protected]) (gcc version 4.8.2 (GCC) ) #1 PREEMPT Wed Mar 19 22:38:17 GMT 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 81920
[ 0.000000] free_area_init_node: node 0, pgdat c0a8d0c8, node_mem_map c0ae7000
[ 0.000000] Normal zone: 640 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 81920 pages, LIFO batch:15
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 81280
[ 0.000000] Kernel command line: dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 root=/dev/ram0 rdinit=/init BOOT_IMAGE=/kernel.img dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708.boardrev=0xd bcm2708.serial=0xbdbbc159 smsc95xx.macaddr=B8:27:EB:BB:C1:59 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 quiet
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 313500K/327680K available (6183K kernel code, 246K rwdata, 1364K rodata, 2979K init, 353K bss, 14180K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd4800000 - 0xff000000 ( 680 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd4000000 ( 320 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0766f1c (7548 kB)
[ 0.000000] .init : 0xc0767000 - 0xc0a4fd4c (2980 kB)
[ 0.000000] .data : 0xc0a50000 - 0xc0a8db10 ( 247 kB)
[ 0.000000] .bss : 0xc0a8db1c - 0xc0ae62f0 ( 354 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Offload RCU callbacks from all CPUs
[ 0.000000] Offload RCU callbacks from CPUs: 0.
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483648000ns
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000472] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.08 BogoMIPS (lpj=3333)
[ 0.000497] pid_max: default: 32768 minimum: 301
[ 0.000775] Mount-cache hash table entries: 512
[ 0.001592] CPU: Testing write buffer coherency: ok
[ 0.001958] Setting up static identity map for 0x60f7e8 - 0x60f820
[ 0.004372] devtmpfs: initialized
[ 0.016522] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.016973] xor: measuring software checksum speed
[ 0.050337] arm4regs : 973.200 MB/sec
[ 0.083748] 8regs : 470.400 MB/sec
[ 0.117165] 32regs : 416.400 MB/sec
[ 0.117183] xor: using function: arm4regs (973.200 MB/sec)
[ 0.117479] NET: Registered protocol family 16
[ 0.122484] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.123073] cpuidle: using governor ladder
[ 0.123095] cpuidle: using governor menu
[ 0.123613] bcm2708.uart_clock = 0
[ 0.125462] ------------[ cut here ]------------
[ 0.125517] WARNING: CPU: 0 PID: 1 at fs/sysfs/dir.c:486 sysfs_warn_dup+0x74/0x98()
[ 0.125532] sysfs: cannot create duplicate filename '/devices/platform/pcm5102a-codec'
[ 0.125544] Modules linked in:
[ 0.125568] CPU: 0 PID: 1 Comm: swapper Not tainted 3.13.6 #1
[ 0.125579] Backtrace:
[ 0.125627] [<c0011410>] (dump_backtrace+0x0/0x10c) from [<c00116e8>] (show_stack+0x18/0x1c)
[ 0.125642] r6:c01103bc r5:00000009 r4:d3839ce8 r3:00000000
[ 0.125689] [<c00116d0>] (show_stack+0x0/0x1c) from [<c060b5d8>] (dump_stack+0x20/0x28)
[ 0.125719] [<c060b5b8>] (dump_stack+0x0/0x28) from [<c001dc2c>] (warn_slowpath_common+0x70/0x90)
[ 0.125746] [<c001dbbc>] (warn_slowpath_common+0x0/0x90) from [<c001dc84>] (warn_slowpath_fmt+0x38/0x40)
[ 0.125760] r8:c0a7dae0 r7:00002001 r6:d387de00 r5:d3804dc0 r4:d381a000
[ 0.125799] [<c001dc4c>] (warn_slowpath_fmt+0x0/0x40) from [<c01103bc>] (sysfs_warn_dup+0x74/0x98)
[ 0.125812] r3:d381a000 r2:c06f6550
[ 0.125841] [<c0110348>] (sysfs_warn_dup+0x0/0x98) from [<c0110418>] (sysfs_add_one+0x38/0x40)
[ 0.125855] r6:d3804dc0 r5:d3880440 r4:ffffffef r3:00000000
[ 0.125890] [<c01103e0>] (sysfs_add_one+0x0/0x40) from [<c0110554>] (create_dir+0x70/0xdc)
[ 0.125903] r6:c0a5e3d0 r5:d3804dc0 r4:d3880440 r3:00000000
[ 0.125938] [<c01104e4>] (create_dir+0x0/0xdc) from [<c01108d0>] (sysfs_create_dir_ns+0x84/0xb8)
[ 0.125952] r7:c0a7dad8 r6:00000000 r5:d3804dc0 r4:c0a5e3d0
[ 0.125997] [<c011084c>] (sysfs_create_dir_ns+0x0/0xb8) from [<c03d1640>] (kobject_add_internal+0xc4/0x23c)
[ 0.126011] r6:00000000 r5:c0a7dae0 r4:c0a5e3d0
[ 0.126044] [<c03d157c>] (kobject_add_internal+0x0/0x23c) from [<c03d1b44>] (kobject_add+0x54/0x98)
[ 0.126058] r8:c076a28c r7:c0a7dad8 r6:00000000 r5:c0a7dae0 r4:c0a5e3d0
[ 0.126106] [<c03d1af0>] (kobject_add+0x0/0x98) from [<c042c908>] (device_add+0xe8/0x4f8)
[ 0.126120] r3:00000000 r2:00000000
[ 0.126133] r6:c0a5e3c8 r5:00000000 r4:c0a5e3d0
[ 0.126165] [<c042c820>] (device_add+0x0/0x4f8) from [<c0430918>] (platform_device_add+0xb4/0x218)
[ 0.126178] r9:000000fc r8:c076a28c r7:c0a8dea0 r6:c0a5e3c8 r5:c0a5e3b8
[ 0.126178] r4:00000000
[ 0.126220] [<c0430864>] (platform_device_add+0x0/0x218) from [<c0430fe4>] (platform_device_register+0x28/0x2c)
[ 0.126233] r7:c0a8dea0 r6:c0a5c3b8 r5:c0a5ccf8 r4:c0a5e3b8
[ 0.126284] [<c0430fbc>] (platform_device_register+0x0/0x2c) from [<c076d460>] (bcm_register_device+0x10/0x14)
[ 0.126298] r4:c0789414 r3:00000010
[ 0.126330] [<c076d450>] (bcm_register_device+0x0/0x14) from [<c076d61c>] (bcm2708_init+0x1b8/0x26c)
[ 0.126360] [<c076d464>] (bcm2708_init+0x0/0x26c) from [<c076a2b0>] (customize_machine+0x24/0x30)
[ 0.126373] r7:c0a8dc00 r6:c0a8dc00 r5:00000003 r4:c078cd18
[ 0.126408] [<c076a28c>] (customize_machine+0x0/0x30) from [<c0008670>] (do_one_initcall+0x100/0x160)
[ 0.126436] [<c0008570>] (do_one_initcall+0x0/0x160) from [<c0767bc4>] (kernel_init_freeable+0xfc/0x1f4)
[ 0.126479] [<c0767ac8>] (kernel_init_freeable+0x0/0x1f4) from [<c0603354>] (kernel_init+0x10/0x120)
[ 0.126510] [<c0603344>] (kernel_init+0x0/0x120) from [<c000e638>] (ret_from_fork+0x14/0x3c)
[ 0.126524] r4:00000000 r3:00000000
[ 0.126593] ---[ end trace eab86e3d9c90d00a ]---
[ 0.126619] ------------[ cut here ]------------
[ 0.126647] WARNING: CPU: 0 PID: 1 at lib/kobject.c:223 kobject_add_internal+0x214/0x23c()
[ 0.126663] kobject_add_internal failed for pcm5102a-codec with -EEXIST, don't try to register things with the same name in the same directory.
[ 0.126673] Modules linked in:
[ 0.126692] CPU: 0 PID: 1 Comm: swapper Tainted: G W 3.13.6 #1
[ 0.126701] Backtrace:
[ 0.126733] [<c0011410>] (dump_backtrace+0x0/0x10c) from [<c00116e8>] (show_stack+0x18/0x1c)
[ 0.126747] r6:c03d1790 r5:00000009 r4:d3839d80 r3:00000000
[ 0.126787] [<c00116d0>] (show_stack+0x0/0x1c) from [<c060b5d8>] (dump_stack+0x20/0x28)
[ 0.126815] [<c060b5b8>] (dump_stack+0x0/0x28) from [<c001dc2c>] (warn_slowpath_common+0x70/0x90)
[ 0.126841] [<c001dbbc>] (warn_slowpath_common+0x0/0x90) from [<c001dc84>] (warn_slowpath_fmt+0x38/0x40)
[ 0.126855] r8:c0a7dae0 r7:c0a7dad8 r6:ffffffef r5:c0a7dae0 r4:c0a5e3d0
[ 0.126896] [<c001dc4c>] (warn_slowpath_fmt+0x0/0x40) from [<c03d1790>] (kobject_add_internal+0x214/0x23c)
[ 0.126909] r3:c06317ac r2:c07198a8
[ 0.126938] [<c03d157c>] (kobject_add_internal+0x0/0x23c) from [<c03d1b44>] (kobject_add+0x54/0x98)
[ 0.126951] r8:c076a28c r7:c0a7dad8 r6:00000000 r5:c0a7dae0 r4:c0a5e3d0
[ 0.126994] [<c03d1af0>] (kobject_add+0x0/0x98) from [<c042c908>] (device_add+0xe8/0x4f8)
[ 0.127007] r3:00000000 r2:00000000
[ 0.127021] r6:c0a5e3c8 r5:00000000 r4:c0a5e3d0
[ 0.127051] [<c042c820>] (device_add+0x0/0x4f8) from [<c0430918>] (platform_device_add+0xb4/0x218)
[ 0.127064] r9:000000fc r8:c076a28c r7:c0a8dea0 r6:c0a5e3c8 r5:c0a5e3b8
[ 0.127064] r4:00000000
[ 0.127106] [<c0430864>] (platform_device_add+0x0/0x218) from [<c0430fe4>] (platform_device_register+0x28/0x2c)
[ 0.127120] r7:c0a8dea0 r6:c0a5c3b8 r5:c0a5ccf8 r4:c0a5e3b8
[ 0.127161] [<c0430fbc>] (platform_device_register+0x0/0x2c) from [<c076d460>] (bcm_register_device+0x10/0x14)
[ 0.127175] r4:c0789414 r3:00000010
[ 0.127207] [<c076d450>] (bcm_register_device+0x0/0x14) from [<c076d61c>] (bcm2708_init+0x1b8/0x26c)
[ 0.127236] [<c076d464>] (bcm2708_init+0x0/0x26c) from [<c076a2b0>] (customize_machine+0x24/0x30)
[ 0.127306] r7:c0a8dc00 r6:c0a8dc00 r5:00000003 r4:c078cd18
[ 0.127352] [<c076a28c>] (customize_machine+0x0/0x30) from [<c0008670>] (do_one_initcall+0x100/0x160)
[ 0.127381] [<c0008570>] (do_one_initcall+0x0/0x160) from [<c0767bc4>] (kernel_init_freeable+0xfc/0x1f4)
[ 0.127415] [<c0767ac8>] (kernel_init_freeable+0x0/0x1f4) from [<c0603354>] (kernel_init+0x10/0x120)
[ 0.127447] [<c0603344>] (kernel_init+0x0/0x120) from [<c000e638>] (ret_from_fork+0x14/0x3c)
[ 0.127461] r4:00000000 r3:00000000
[ 0.127477] ---[ end trace eab86e3d9c90d00b ]---
[ 0.127605] mailbox: Broadcom VideoCore Mailbox driver
[ 0.127695] bcm2708_vcio: mailbox at f200b880
[ 0.127788] bcm_power: Broadcom power driver
[ 0.127808] bcm_power_open() -> 0
[ 0.127819] bcm_power_request(0, 8)
[ 0.628517] bcm_mailbox_read -> 00000080, 0
[ 0.628536] bcm_power_request -> 0
[ 0.628802] Serial: AMBA PL011 UART driver
[ 0.628936] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.653202] bio: create slab <bio-0> at 0
[ 0.709425] raid6: int32x1 46 MB/s
[ 0.766000] raid6: int32x2 65 MB/s
[ 0.823009] raid6: int32x4 89 MB/s
[ 0.879966] raid6: int32x8 98 MB/s
[ 0.879987] raid6: using algorithm int32x8 (98 MB/s)
[ 0.879999] raid6: using intx1 recovery algorithm
[ 0.880639] SCSI subsystem initialized
[ 0.880980] usbcore: registered new interface driver usbfs
[ 0.881072] usbcore: registered new interface driver hub
[ 0.881310] usbcore: registered new device driver usb
[ 0.882984] Switched to clocksource stc
[ 0.895108] NET: Registered protocol family 2
[ 0.896045] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.896149] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.896249] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.896416] TCP: reno registered
[ 0.896454] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.896490] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.896939] NET: Registered protocol family 1
[ 0.897459] RPC: Registered named UNIX socket transport module.
[ 0.897486] RPC: Registered udp transport module.
[ 0.897497] RPC: Registered tcp transport module.
[ 0.897509] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.142433] bcm2708_dma: DMA manager at f2007000
[ 1.142580] bcm2708_gpio: bcm2708_gpio_probe c0a5c5e0
[ 1.143120] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.155584] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.157985] NFS: Registering the id_resolver key type
[ 1.158086] Key type id_resolver registered
[ 1.158105] Key type id_legacy registered
[ 1.158136] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.160233] JFS: nTxBlock = 2449, nTxLock = 19593
[ 1.161499] SGI XFS with security attributes, large block/inode numbers, no debug enabled
[ 1.165953] bio: create slab <bio-1> at 1
[ 1.167675] Btrfs loaded
[ 1.168151] msgmni has been set to 612
[ 1.171473] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.171503] io scheduler noop registered (default)
[ 1.171517] io scheduler deadline registered
[ 1.171574] io scheduler cfq registered
[ 1.171823] bcm2708_fb_debugfs_init: could not create debugfs entry
[ 1.171942] BCM2708FB: allocated DMA memory 52f40000
[ 1.171995] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.207787] Console: switching to colour frame buffer device 240x67
[ 1.225165] uart-pl011 dev:f1: no DMA platform data
[ 1.225218] bcm2708_rng_init=d4d8c000
[ 1.233708] brd: module loaded
[ 1.233931] loop: module loaded
[ 1.234246] nbd: registered device at major 43
[ 1.242714] vchiq: vchiq_init_state: slot_zero = 0xd4804000, is_master = 0
[ 1.243822] Loading iSCSI transport class v2.0-870.
[ 1.244518] iscsi: registered transport (tcp)
[ 1.245495] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 1.246252] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 1.246481] tun: Universal TUN/TAP device driver, 1.6
[ 1.246503] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 1.246852] PPP generic driver version 2.4.2
[ 1.247282] usbcore: registered new interface driver smsc95xx
[ 1.247422] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.447600] Core Release: 2.80a
[ 1.447635] Setting default values for core params
[ 1.447684] Finished setting default values for core params
[ 1.647773] Using Buffer DMA mode
[ 1.647802] Periodic Transfer Interrupt Enhancement - disabled
[ 1.647815] Multiprocessor Interrupt Enhancement - disabled
[ 1.647829] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.647847] Dedicated Tx FIFOs mode
[ 1.648097] WARN::dwc_otg_hcd_init:1040: FIQ DMA bounce buffers: virt = 0xd4d9c000 dma = 0x52f98000 len=9024
[ 1.648134] FIQ FSM acceleration enabled for :
[ 1.648134] Non-periodic Split Transactions
[ 1.648134] Periodic Split Transactions
[ 1.648179] dwc_otg: Microframe scheduler enabled
[ 1.648223] WARN::hcd_init:473: FIQ at 0xc04c5328
[ 1.648241] WARN::hcd_init:474: FIQ ASM at 0xc04c5600 length 36
[ 1.648274] WARN::hcd_init:500: MPHI regs_base at 0xd4d96000
[ 1.648307] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.648364] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.648426] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.648469] Init: Port Power? op_state=1
[ 1.648481] Init: Power Port (0)
[ 1.648796] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.648823] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.648842] usb usb1: Product: DWC OTG Controller
[ 1.648860] usb usb1: Manufacturer: Linux 3.13.6 dwc_otg_hcd
[ 1.648875] usb usb1: SerialNumber: bcm2708_usb
[ 1.649808] hub 1-0:1.0: USB hub found
[ 1.649902] hub 1-0:1.0: 1 port detected
[ 1.650369] dwc_otg: FIQ enabled
[ 1.650388] dwc_otg: NAK holdoff enabled
[ 1.650398] dwc_otg: FIQ split-transaction FSM enabled
[ 1.650420] Module dwc_common_port init
[ 1.650848] usbcore: registered new interface driver usb-storage
[ 1.651201] mousedev: PS/2 mouse device common for all mice
[ 1.651406] i2c /dev entries driver
[ 1.651570] bcm2708_i2c_init_pinmode(0,0)
[ 1.651590] bcm2708_i2c_init_pinmode(0,1)
[ 1.652000] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
[ 1.652067] bcm2708_i2c_init_pinmode(1,2)
[ 1.652084] bcm2708_i2c_init_pinmode(1,3)
[ 1.652668] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
[ 1.653663] bcm2835-cpufreq: min=700000 max=900000 cur=700000
[ 1.653825] bcm2835-cpufreq: switching to governor ondemand
[ 1.653847] bcm2835-cpufreq: switching to governor ondemand
[ 1.655180] sdhci: Secure Digital Host Controller Interface driver
[ 1.655196] sdhci: Copyright(c) Pierre Ossman
[ 1.655265] sdhci: Enable low-latency mode
[ 1.686360] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 1.686543] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 1.686629] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.686937] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.688243] usbcore: registered new interface driver usbhid
[ 1.688258] usbhid: USB HID core driver
[ 1.688476] TCP: cubic registered
[ 1.689294] NET: Registered protocol family 10
[ 1.696800] NET: Registered protocol family 17
[ 1.700094] Key type dns_resolver registered
[ 1.724038] Freeing unused kernel memory: 2976K (c0767000 - c0a4f000)
[ 1.755606] mmc0: read SD Status register (SSR) after 2 attempts
[ 1.761146] mmc0: new high speed SDHC card at address 0007
[ 1.763385] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[ 1.764772] mmcblk0: p1 p2
[ 1.849927] Indeed it is in host mode hprt0 = 00021501
[ 2.043155] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.043330] Indeed it is in host mode hprt0 = 00001101
[ 2.266744] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.266776] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.267459] hub 1-1:1.0: USB hub found
[ 2.267590] hub 1-1:1.0: 3 ports detected
[ 2.546512] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.640091] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.640119] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.642838] smsc95xx v1.0.4
[ 2.686555] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:bb:c1:59
[ 2.769884] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
[ 2.884543] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2003
[ 2.884576] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.884593] usb 1-1.3: Product: Dell USB Keyboard
[ 2.884606] usb 1-1.3: Manufacturer: Dell
[ 2.898727] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 2.903195] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 2.905117] input: Dell Dell USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
[ 2.907390] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-bcm2708_usb-1.3/input0
[ 2.923434] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.515522] random: systemd urandom read with 98 bits of entropy available
[ 3.517477] systemd[1]: systemd 211 running in system mode. (-PAM -LIBWRAP -AUDIT -SELINUX -IMA -SYSVINIT -LIBCRYPTSETUP -GCRYPT -ACL -XZ -SECCOMP -APPARMOR)
[ 3.518093] systemd[1]: Detected architecture 'arm'.
[ 3.519446] systemd[1]: Set hostname to <openelec>.
[ 3.520193] systemd[1]: Initializing machine ID from random generator.
[ 3.605792] systemd-gpt-auto-generator[98]: Out of memory.
[ 3.607067] systemd[96]: /usr/lib/systemd/system-generators/systemd-gpt-auto-generator failed with error code 1.
[ 3.791235] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.796143] systemd[1]: Starting Paths.
[ 3.796508] systemd[1]: Reached target Paths.
[ 3.796746] systemd[1]: Starting Root Slice.
[ 3.797074] systemd[1]: Created slice Root Slice.
[ 3.797244] systemd[1]: Starting User and Session Slice.
[ 3.797655] systemd[1]: Created slice User and Session Slice.
[ 3.797825] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.798225] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.798396] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.798750] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.798958] systemd[1]: Starting udev Control Socket.
[ 3.799325] systemd[1]: Listening on udev Control Socket.
[ 3.799537] systemd[1]: Starting udev Kernel Socket.
[ 3.800046] systemd[1]: Listening on udev Kernel Socket.
[ 3.800270] systemd[1]: Starting Journal Socket.
[ 3.800836] systemd[1]: Listening on Journal Socket.
[ 3.801144] systemd[1]: Starting System Slice.
[ 3.801615] systemd[1]: Created slice System Slice.
[ 3.802241] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.805162] systemd[1]: Mounting Temporary Directory...
[ 3.811848] systemd[1]: Starting Setup User config dir...
[ 3.823326] systemd[1]: Mounted Huge Pages File System.
[ 3.823680] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.843548] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.861488] systemd[1]: Starting Setup Loopback interface...
[ 3.879401] systemd[1]: Mounting Debug File System...
[ 3.907559] systemd[1]: Starting Set ondemand threshold...
[ 3.928162] systemd[1]: Starting Show Version...
[ 3.979547] systemd[1]: Starting Mounting swapfile...
[ 4.007698] random: nonblocking pool is initialized
[ 4.045078] systemd[1]: Starting Load Kernel Modules...
[ 4.094325] systemd[1]: Starting Apply Kernel Variables...
[ 4.133933] systemd[1]: Starting udev Coldplug all Devices...
[ 4.166856] systemd[1]: Starting Slices.
[ 4.167054] systemd[1]: Reached target Slices.
[ 4.167304] systemd[1]: Mounting Variable Directory...
[ 4.200192] systemd[1]: Started Setup debug config.
[ 4.229275] systemd[1]: Mounted Debug File System.
[ 4.237538] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.237909] systemd[1]: Mounted Temporary Directory.
[ 4.260193] systemd[1]: Started Remount Root and Kernel File Systems.
[ 4.296243] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.386930] systemd[1]: Started Set ondemand threshold.
[ 4.388840] systemd[1]: Started Show Version.
[ 4.420904] systemd[1]: Started Apply Kernel Variables.
[ 4.422129] systemd[1]: Mounted Variable Directory.
[ 4.451448] lirc_dev: IR Remote Control driver registered, major 249
[ 4.463896] systemd[1]: Started Setup Loopback interface.
[ 4.480138] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.690609] systemd[1]: Started Mounting swapfile.
[ 4.871530] systemd[1]: Started udev Coldplug all Devices.
[ 4.917988] systemd[1]: Started Setup User config dir.
[ 5.138142] systemd[1]: Starting Swap.
[ 5.138356] systemd[1]: Reached target Swap.
[ 5.138556] systemd[1]: Starting Restoring Backup...
[ 5.141726] systemd[1]: Started Factory reset.
[ 5.142041] systemd[1]: Started FS Resize.
[ 5.142748] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.208535] systemd[1]: Started Restoring Backup.
[ 5.246055] systemd[1]: Started Create Static Device Nodes in /dev.
[ 5.260133] systemd[1]: Starting Local File Systems (Pre).
[ 5.260337] systemd[1]: Reached target Local File Systems (Pre).
[ 5.260541] systemd[1]: Starting Local File Systems.
[ 5.260688] systemd[1]: Reached target Local File Systems.
[ 5.261018] systemd[1]: Starting Setup Hostname...
[ 5.267271] systemd[1]: Starting Setup machine-id...
[ 5.277611] systemd[1]: Starting Create Volatile Files and Directories...
[ 5.336116] systemd[1]: Started Setup Hostname.
[ 5.389783] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 5.390082] lirc_rpi lirc_rpi.0: lirc_dev: driver lirc_rpi registered at minor = 0
[ 5.390099] lirc_rpi: driver registered!
[ 5.408001] systemd[1]: Started Load Kernel Modules.
[ 5.420739] systemd[1]: Started Setup machine-id.
[ 5.435618] systemd[1]: Started Create Volatile Files and Directories.
[ 5.515818] systemd[1]: Starting Update hwdb.bin...
[ 5.519640] systemd[1]: Started Debug /var/log relink.
[ 5.523417] systemd[1]: Starting Journal Service...
[ 5.533603] systemd[1]: Started Journal Service.
[ 5.863395] systemd-udevd[187]: starting version 211
[ 6.310903] Console: switching to colour dummy device 80x30
[ 6.960903] systemd-journald[183]: Received request to flush runtime journal from PID 1
[ 7.211282] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 9.085521] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 9.088132] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.098581] input: lircd as /devices/virtual/input/input1
[ 10.649065] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 10.666811] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
20:30:52 12.961643 T:3057811456 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:30:52 12.962186 T:3057811456 NOTICE: -----------------------------------------------------------------------
20:30:52 12.962389 T:3057811456 NOTICE: Starting XBMC (14.0-ALPHA1 Git:a1cab7a). Platform: ARM Linux 32-bit
20:30:52 12.962662 T:3057811456 NOTICE: Using Release XBMC x32 build, compiled Mar 19 2014 by GCC 4.8.2 for ARM Linux 32-bit 3.13.6
20:30:52 13.009518 T:3057811456 NOTICE: Running on Linux 32-bit (OpenELEC (Milhouse) - Version: devel-20140320013122-r17977-ge57e1bc, 3.13.6 armv6l)
20:30:52 13.009814 T:3057811456 NOTICE: Host CPU: ARMv6-compatible processor rev 7 (v6l), 1 core available
20:30:52 13.009969 T:3057811456 NOTICE: ARM Features: Neon disabled
20:30:52 13.010262 T:3057811456 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
20:30:52 13.010433 T:3057811456 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
20:30:52 13.010592 T:3057811456 NOTICE: special://masterprofile/ is mapped to: /storage/.xbmc/userdata
20:30:52 13.010751 T:3057811456 NOTICE: special://home/ is mapped to: /storage/.xbmc
20:30:52 13.010911 T:3057811456 NOTICE: special://temp/ is mapped to: /storage/.xbmc/temp
20:30:52 13.011152 T:3057811456 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
20:30:52 13.011465 T:3057811456 NOTICE: Local hostname: OpenELEC
20:30:52 13.011639 T:3057811456 NOTICE: Log File is located: /storage/.xbmc/temp/xbmc.log
20:30:52 13.011838 T:3057811456 NOTICE: -----------------------------------------------------------------------
20:30:52 13.031824 T:3057811456 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
20:30:52 13.057186 T:3057811456 NOTICE: load settings...
20:30:52 13.361464 T:3057811456 NOTICE: Found 1 Lists of Devices
20:30:52 13.361764 T:3057811456 NOTICE: Enumerated PI devices:
20:30:52 13.361933 T:3057811456 NOTICE: Device 1
20:30:52 13.364422 T:3057811456 NOTICE: m_deviceName : HDMI
20:30:52 13.364689 T:3057811456 NOTICE: m_displayName : HDMI
20:30:52 13.364861 T:3057811456 NOTICE: m_displayNameExtra:
20:30:52 13.365028 T:3057811456 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:30:52 13.365196 T:3057811456 NOTICE: m_channels : FL,FR
20:30:52 13.365360 T:3057811456 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,41400,48000,88200,96000,176400,192000
20:30:52 13.365525 T:3057811456 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
20:30:52 13.365805 T:3057811456 NOTICE: Device 2
20:30:52 13.366126 T:3057811456 NOTICE: m_deviceName : Analogue
20:30:52 13.366313 T:3057811456 NOTICE: m_displayName : Analogue
20:30:52 13.366479 T:3057811456 NOTICE: m_displayNameExtra:
20:30:52 13.366644 T:3057811456 NOTICE: m_deviceType : AE_DEVTYPE_PCM
20:30:52 13.367167 T:3057811456 NOTICE: m_channels : FL,FR
20:30:52 13.367738 T:3057811456 NOTICE: m_sampleRates : 48000
20:30:52 13.367941 T:3057811456 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE
20:30:52 13.438671 T:3057811456 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
20:30:52 13.439209 T:3057811456 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<destroywindowcontrols>false</destroywindowcontrols>
<fanartres>720</fanartres>
<imageres>540</imageres>
<useddsfanart>false</useddsfanart>
<video>
<defaultplayer>omxplayer</defaultplayer>
<defaultdvdplayer>omxplayer</defaultdvdplayer>
<busydialogdelayms>750</busydialogdelayms>
</video>
<network>
<cachemembuffersize>20971520</cachemembuffersize>
</network>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<readbufferfactor>4.0</readbufferfactor>
</network>
</advancedsettings>
20:30:52 13.446994 T:3057811456 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:30:52 13.447322 T:3057811456 NOTICE: Default DVD Player: omxplayer
20:30:52 13.447536 T:3057811456 NOTICE: Default Video Player: omxplayer
20:30:52 13.447701 T:3057811456 NOTICE: Default Audio Player: paplayer
20:30:52 13.447894 T:3057811456 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:30:52 13.448057 T:3057811456 NOTICE: Log level changed to 0
20:30:52 13.448714 T:3057811456 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:30:52 13.478711 T:3057811456 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:30:53 13.487093 T:3057811456 NOTICE: Loaded playercorefactory configuration
20:30:53 13.488166 T:3057811456 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:30:53 13.488798 T:3057811456 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:30:53 13.882479 T:3057800272 NOTICE: Thread ActiveAE start, auto delete: false
20:30:53 13.883228 T:3048207440 NOTICE: Thread AESink start, auto delete: false
20:30:53 13.912287 T:2987390032 NOTICE: Thread CRBPWorker start, auto delete: false
20:30:53 14.053675 T:3057811456 NOTICE: Running database version Addons16
20:30:54 14.952456 T:3057811456 NOTICE: ADDONS: Using repository repository.xbmc.org
20:30:54 14.952718 T:3057811456 NOTICE: ADDONS: Using repository repository.xbmcadult
20:30:54 14.952882 T:3057811456 NOTICE: ADDONS: Using repository repository.openelec.tv
20:30:54 15.129735 T:3057811456 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
20:30:54 15.130475 T:2970612816 NOTICE: Thread PeripBusCEC start, auto delete: false
20:30:54 15.133780 T:2979001424 NOTICE: Thread CECAdapter start, auto delete: false
20:30:54 15.267135 T:2962224208 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
20:30:54 15.287459 T:3057811456 NOTICE: Raspberry PI firmware version: Mar 19 2014 23:26:47
Copyright (c) 2012 Broadcom
version 98eb97cd0061f2fcff808fe5f32f851d5eada1ee (tainted) (release)
20:30:54 15.287744 T:3057811456 NOTICE: ARM mem: 320MB GPU mem: 192MB MPG2:0 WVC1:0
20:30:54 15.288207 T:3057811456 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
20:30:54 15.298067 T:3057811456 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
20:30:54 15.298328 T:3057811456 NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
20:30:54 15.298571 T:3057811456 NOTICE: Checking resolution 16
20:30:54 15.315450 T:3057811456 NOTICE: GL_VENDOR = Broadcom
20:30:54 15.315714 T:3057811456 NOTICE: GL_RENDERER = VideoCore IV HW
20:30:54 15.315876 T:3057811456 NOTICE: GL_VERSION = OpenGL ES 2.0
20:30:54 15.316084 T:3057811456 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
20:30:54 15.316430 T:3057811456 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
20:30:55 16.209620 T:3057811456 NOTICE: No Joystick name specified, loading default map
20:30:55 16.350344 T:2935915600 NOTICE: Previous line repeats 35 times.
20:30:55 16.350344 T:2935915600 NOTICE: Thread CECAdapterUpdate start, auto delete: false
20:30:56 16.585342 T:3057811456 NOTICE: Running database version Addons16
20:30:56 16.596008 T:3057811456 NOTICE: Running database version ViewModes6
20:30:56 16.666973 T:3057811456 NOTICE: Running database version Textures13
20:30:56 16.705563 T:3057811456 NOTICE: Running database version MyMusic46
20:30:56 16.885105 T:3057811456 NOTICE: Running database version MyVideos78
20:30:56 16.900305 T:3057811456 NOTICE: Running database version TV22
20:30:56 16.911190 T:3057811456 NOTICE: Running database version Epg7
20:30:56 16.912064 T:3057811456 NOTICE: start dvd mediatype detection
20:30:56 16.912598 T:3057811456 NOTICE: initializing playlistplayer
20:30:56 16.912893 T:3057811456 NOTICE: DONE initializing playlistplayer
20:30:56 16.916965 T:2925470800 NOTICE: Thread DetectDVDMedia start, auto delete: false
20:30:58 19.173252 T:3057800272 NOTICE: ActiveAE::ResampleSounds - resample /usr/share/xbmc/addons/skin.confluence/sounds/cursor.wav took 287ms
20:30:59 19.490385 T:3057800272 NOTICE: ActiveAE::ResampleSounds - resample /usr/share/xbmc/addons/skin.confluence/sounds/click.wav took 314ms
20:30:59 19.571733 T:3057811456 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
20:30:59 19.624193 T:3057811456 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:30:59 19.800726 T:3057800272 NOTICE: ActiveAE::ResampleSounds - resample /usr/share/xbmc/addons/skin.confluence/sounds/back.wav took 310ms
20:30:59 20.114149 T:3057800272 NOTICE: ActiveAE::ResampleSounds - resample /usr/share/xbmc/addons/skin.confluence/sounds/shutter.wav took 313ms
20:30:59 20.153660 T:2924823632 NOTICE: Thread LanguageInvoker start, auto delete: false
20:30:59 20.297245 T:3057811456 NOTICE: Previous line repeats 2 times.
20:30:59 20.297245 T:3057811456 NOTICE: initialize done
20:30:59 20.297632 T:3057811456 NOTICE: Running the application...
20:31:00 20.902248 T:3057800272 NOTICE: ActiveAE::ResampleSounds - resample /usr/share/xbmc/addons/skin.confluence/sounds/notify.wav took 788ms
20:31:00 20.914499 T:3057800272 NOTICE: ActiveAE::ResampleSounds - resample /usr/share/xbmc/addons/skin.confluence/sounds/out.wav took 6ms
20:31:02 22.493666 T:2899653712 NOTICE: Thread JobWorker start, auto delete: true
20:31:02 22.936249 T:3057811456 NOTICE: starting zeroconf publishing
20:31:02 22.936972 T:3057811456 NOTICE: Webserver: Starting...
20:31:02 22.940435 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
20:31:02 22.943756 T:3057811456 NOTICE: WebServer: Started the webserver
20:31:02 22.944574 T:3057811456 NOTICE: starting upnp controller
20:31:02 23.000950 T:3057811456 NOTICE: starting upnp server
20:31:02 23.117041 T:3057811456 NOTICE: ES: Starting event server
20:31:02 23.136967 T:2649572432 NOTICE: Thread EventServer start, auto delete: false
20:31:02 23.137285 T:2649572432 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:31:02 23.137568 T:2649572432 NOTICE: UDP: Listening on port 9777
20:31:02 23.140381 T:2641183824 NOTICE: Thread TCPServer start, auto delete: false
20:31:02 23.143908 T:2632795216 NOTICE: Thread JobWorker start, auto delete: true
20:31:02 23.254751 T:2624406608 NOTICE: Thread AirPlayServer start, auto delete: false
20:31:03 23.696493 T:2802705488 NOTICE: Thread LanguageInvoker start, auto delete: false
20:31:03 24.178778 T:2908046416 NOTICE: -->Python Interpreter Initialized<--
20:31:04 25.000313 T:2792178768 NOTICE: Thread JobWorker start, auto delete: true
20:31:05 26.207535 T:2916435024 NOTICE: -->Python Interpreter Initialized<--
20:31:05 26.218884 T:2802705488 NOTICE: -->Python Interpreter Initialized<--
20:31:05 26.339567 T:2924823632 NOTICE: -->Python Interpreter Initialized<--
20:31:07 27.997267 T:2916435024 NOTICE: ## OpenELEC Addon ## 0.3.14
20:31:08 29.373655 T:2908046416 NOTICE: StorageServer Module loaded RUN
20:31:10 31.342607 T:2908046416 NOTICE: StorageClient-2.5.4 Starting server
20:31:10 31.343725 T:2908046416 NOTICE: StorageServer-2.5.4 Storage Server starting /storage/.xbmc/temp/commoncache.db
20:31:16 37.060932 T:3048207440 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:4410)
20:48:20 1061.178589 T:2632795216 NOTICE: Thread JobWorker start, auto delete: true
20:48:20 1061.186157 T:2811094096 NOTICE: Thread LanguageInvoker start, auto delete: false
20:48:21 1062.125122 T:2811094096 NOTICE: -->Python Interpreter Initialized<--
21:05:32 2092.760254 T:2691515472 NOTICE: Thread JobWorker start, auto delete: true
21:05:32 2092.765381 T:2792178768 NOTICE: Thread LanguageInvoker start, auto delete: false
21:05:33 2093.689697 T:2792178768 NOTICE: -->Python Interpreter Initialized<--
21:35:35 3896.017334 T:2716681296 NOTICE: Thread JobWorker start, auto delete: true
21:35:35 3896.019531 T:2792178768 NOTICE: Thread LanguageInvoker start, auto delete: false
21:35:36 3896.511230 T:2792178768 NOTICE: -->Python Interpreter Initialized<--
22:05:37 5697.642578 T:2708292688 NOTICE: Thread JobWorker start, auto delete: true
22:05:37 5697.645020 T:2699904080 NOTICE: Thread LanguageInvoker start, auto delete: false
22:05:37 5698.154297 T:2699904080 NOTICE: -->Python Interpreter Initialized<--
22:35:39 7499.727539 T:2683126864 NOTICE: Thread JobWorker start, auto delete: true
22:35:39 7499.729980 T:2699904080 NOTICE: Thread LanguageInvoker start, auto delete: false
22:35:39 7500.253906 T:2699904080 NOTICE: -->Python Interpreter Initialized<--
22:35:40 7501.366699 T:2699904080 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.ValueError'>
Error Contents: could not convert string to float:
File "/storage/.xbmc/addons/weather.yahoo/default.py", line 212, in <module>
forecast(location, locationid)
File "/storage/.xbmc/addons/weather.yahoo/default.py", line 120, in forecast
properties(query,loc)
File "/storage/.xbmc/addons/weather.yahoo/default.py", line 169, in properties
set_property('Current.FeelsLike' , feelslike(int(condition[0].attributes['temp'].value), int(round(float(wind[0].attributes['speed'].value) + 0.5))))
ValueError: could not convert string to float:
-->End of Python script error report<--
22:42:23 7903.556152 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
22:42:29 7909.546387 T:2792354896 NOTICE: Thread LanguageInvoker start, auto delete: false
22:42:29 7910.461914 T:2792354896 NOTICE: -->Python Interpreter Initialized<--
22:45:15 8076.280273 T:2691515472 NOTICE: Thread JobWorker start, auto delete: true
22:45:18 8078.695801 T:2699904080 NOTICE: Previous line repeats 1 times.
22:45:18 8078.695801 T:2699904080 NOTICE: Thread BackgroundLoader start, auto delete: false
22:45:21 8082.400879 T:2691515472 NOTICE: Previous line repeats 1 times.
22:45:21 8082.400879 T:2691515472 WARNING: GetIcon - Unknown nodetype requested videodb://tvshows/titles/6/1/?tvshowid=6
22:45:21 8082.401855 T:2691515472 WARNING: GetIcon - Unknown nodetype requested videodb://tvshows/titles/6/2/?tvshowid=6
22:45:21 8082.402832 T:2691515472 WARNING: GetIcon - Unknown nodetype requested videodb://tvshows/titles/6/-1/?tvshowid=6
22:45:22 8082.542969 T:2699904080 NOTICE: Thread BackgroundLoader start, auto delete: false
22:45:29 8090.233887 T:2792354896 NOTICE: Previous line repeats 2 times.
22:45:29 8090.233887 T:2792354896 WARNING: GetIcon - Unknown nodetype requested videodb://tvshows/titles/6/1/?tvshowid=6
22:45:29 8090.234863 T:2792354896 WARNING: GetIcon - Unknown nodetype requested videodb://tvshows/titles/6/2/?tvshowid=6
22:45:29 8090.235840 T:2792354896 WARNING: GetIcon - Unknown nodetype requested videodb://tvshows/titles/6/-1/?tvshowid=6
22:45:29 8090.409668 T:2699904080 NOTICE: Thread BackgroundLoader start, auto delete: false
22:45:38 8098.543457 T:2765091920 NOTICE: Previous line repeats 3 times.
22:45:38 8098.543457 T:2765091920 NOTICE: Thread LanguageInvoker start, auto delete: false
22:45:38 8099.479980 T:2765091920 NOTICE: -->Python Interpreter Initialized<--
23:15:41 9901.791016 T:2756703312 NOTICE: Thread JobWorker start, auto delete: true
23:15:41 9901.793945 T:2699904080 NOTICE: Thread LanguageInvoker start, auto delete: false
23:15:41 9902.258789 T:2699904080 NOTICE: -->Python Interpreter Initialized<--
23:39:24 11324.698242 T:2756703312 NOTICE: Thread JobWorker start, auto delete: true
23:39:24 11324.706055 T:2878202960 NOTICE: Thread LanguageInvoker start, auto delete: false
23:39:25 11325.633789 T:2878202960 NOTICE: -->Python Interpreter Initialized<--
00:09:27 13128.077148 T:2756703312 NOTICE: Thread JobWorker start, auto delete: true
00:09:27 13128.080078 T:2765091920 NOTICE: Thread LanguageInvoker start, auto delete: false
00:09:28 13128.606445 T:2765091920 NOTICE: -->Python Interpreter Initialized<--
00:13:21 13361.797852 T:2765091920 NOTICE: Thread JobWorker start, auto delete: true
00:13:21 13361.806641 T:2756703312 NOTICE: Thread LanguageInvoker start, auto delete: false
00:13:22 13362.715820 T:2756703312 NOTICE: -->Python Interpreter Initialized<--
00:43:24 15165.032227 T:2765091920 NOTICE: Thread JobWorker start, auto delete: true
00:43:24 15165.034180 T:2792354896 NOTICE: Thread LanguageInvoker start, auto delete: false
00:43:25 15165.502930 T:2792354896 NOTICE: -->Python Interpreter Initialized<--
00:59:02 16102.861328 T:2708292688 NOTICE: Thread JobWorker start, auto delete: true
00:59:02 16102.864258 T:2878202960 NOTICE: Thread LanguageInvoker start, auto delete: false
00:59:03 16103.782227 T:2878202960 NOTICE: -->Python Interpreter Initialized<--
01:11:11 16831.515625 T:2756703312 NOTICE: Thread JobWorker start, auto delete: true
01:11:13 16834.228516 T:2878202960 NOTICE: Thread FileCache start, auto delete: false
01:11:23 16844.335938 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
01:11:23 16844.335938 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
01:11:23 16844.335938 T:2756703312 ERROR: Open - failed to open source <http://mirrors.xbmc.org/addons/frodo/addons.xml.md5>
01:11:43 16864.431641 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
01:11:43 16864.431641 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
01:11:43 16864.431641 T:2756703312 ERROR: Open - failed to open source <http://mirrors.xbmc.org/addons/gotham/addons.xml|Encoding=gzip>
01:11:45 16866.238281 T:2765091920 NOTICE: Thread FileCache start, auto delete: false
01:17:02 17183.257812 T:2878202960 NOTICE: Previous line repeats 2 times.
01:17:02 17183.257812 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
01:17:02 17183.265625 T:2756703312 NOTICE: Thread LanguageInvoker start, auto delete: false
01:17:03 17184.179688 T:2756703312 NOTICE: -->Python Interpreter Initialized<--
01:47:06 18986.791016 T:2699904080 NOTICE: Thread JobWorker start, auto delete: true
01:47:06 18986.794922 T:2765091920 NOTICE: Thread LanguageInvoker start, auto delete: false
01:47:06 18987.273438 T:2765091920 NOTICE: -->Python Interpreter Initialized<--
02:17:08 20788.523438 T:2756703312 NOTICE: Thread JobWorker start, auto delete: true
02:17:08 20788.525391 T:2792354896 NOTICE: Thread LanguageInvoker start, auto delete: false
02:17:08 20789.089844 T:2792354896 NOTICE: -->Python Interpreter Initialized<--
02:47:09 22590.333984 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
02:47:09 22590.335938 T:2792354896 NOTICE: Thread LanguageInvoker start, auto delete: false
02:47:10 22590.806641 T:2792354896 NOTICE: -->Python Interpreter Initialized<--
03:17:11 24392.160156 T:2699904080 NOTICE: Thread JobWorker start, auto delete: true
03:17:11 24392.162109 T:2708292688 NOTICE: Thread LanguageInvoker start, auto delete: false
03:17:12 24392.664062 T:2708292688 NOTICE: -->Python Interpreter Initialized<--
03:50:13 26373.876953 T:2708292688 NOTICE: Thread JobWorker start, auto delete: true
03:50:13 26373.878906 T:2878202960 NOTICE: Thread LanguageInvoker start, auto delete: false
03:50:13 26374.359375 T:2878202960 NOTICE: -->Python Interpreter Initialized<--
04:23:14 28355.410156 T:2699904080 NOTICE: Thread JobWorker start, auto delete: true
04:23:14 28355.412109 T:2708292688 NOTICE: Thread LanguageInvoker start, auto delete: false
04:23:15 28355.871094 T:2708292688 NOTICE: -->Python Interpreter Initialized<--
04:56:16 30336.896484 T:2708292688 NOTICE: Thread JobWorker start, auto delete: true
04:56:16 30336.900391 T:2699904080 NOTICE: Thread LanguageInvoker start, auto delete: false
04:56:16 30337.402344 T:2699904080 NOTICE: -->Python Interpreter Initialized<--
05:29:18 32318.507812 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
05:29:18 32318.511719 T:2756703312 NOTICE: Thread LanguageInvoker start, auto delete: false
05:29:18 32318.976562 T:2756703312 NOTICE: -->Python Interpreter Initialized<--
06:02:19 34300.000000 T:2699904080 NOTICE: Thread JobWorker start, auto delete: true
06:02:19 34300.003906 T:2756703312 NOTICE: Thread LanguageInvoker start, auto delete: false
06:02:19 34300.464844 T:2756703312 NOTICE: -->Python Interpreter Initialized<--
06:35:20 36281.457031 T:2708292688 NOTICE: Thread JobWorker start, auto delete: true
06:35:20 36281.464844 T:2878202960 NOTICE: Thread LanguageInvoker start, auto delete: false
06:35:21 36282.003906 T:2878202960 NOTICE: -->Python Interpreter Initialized<--
07:08:22 38263.003906 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
07:08:22 38263.007812 T:2708292688 NOTICE: Thread LanguageInvoker start, auto delete: false
07:08:23 38263.617188 T:2708292688 NOTICE: -->Python Interpreter Initialized<--
07:21:21 39041.652344 T:2756703312 NOTICE: Thread JobWorker start, auto delete: true
07:21:31 39051.847656 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
07:21:31 39051.847656 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:21:41 39061.750000 T:2756703312 ERROR: Open - failed to open source <http://mirrors.xbmc.org/addons/gotham/addons.xml.md5>
07:21:51 39071.863281 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
07:21:51 39071.863281 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:22:01 39081.824219 T:2756703312 ERROR: Open - failed to open source <http://mirrors.xbmc.org/addons/frodo/addons.xml.md5>
07:22:12 39092.625000 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
07:22:12 39092.625000 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:22:22 39102.687500 T:2756703312 ERROR: Open - failed to open source <http://mirrors.xbmc.org/addons/gotham/addons.xml|Encoding=gzip>
07:22:32 39112.695312 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
07:22:32 39112.695312 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:22:42 39122.789062 T:2756703312 ERROR: Open - failed to open source <http://mirrors.xbmc.org/addons/frodo/addons.xml|Encoding=gzip>
07:22:42 39122.789062 T:2756703312 ERROR: Repository XBMC.org Add-ons returned no add-ons, listing may have failed
07:22:54 39134.597656 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
07:22:54 39134.597656 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:23:04 39144.648438 T:2756703312 ERROR: Open - failed to open source <http://github.com/xbmc-adult/xbmc-adult/raw/ghmaster/addons.xml.md5>
07:23:14 39154.660156 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
07:23:14 39154.660156 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:23:24 39164.710938 T:2756703312 ERROR: Open - failed to open source <http://github.com/xbmc-adult/xbmc-adult/raw/ghmaster/addons.xml>
07:23:24 39164.714844 T:2756703312 ERROR: Repository XBMC-Adult Addons returned no add-ons, listing may have failed
07:23:36 39176.503906 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
07:23:36 39176.503906 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:23:46 39186.554688 T:2756703312 ERROR: Open - failed to open source <http://addons.openelec.tv/4.1/RPi/arm/addons.xml.md5>
07:23:56 39196.562500 T:2756703312 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
07:23:56 39196.562500 T:2756703312 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
07:24:06 39206.632812 T:2756703312 ERROR: Open - failed to open source <http://addons.openelec.tv/4.1/RPi/arm/addons.xml>
07:24:06 39206.636719 T:2756703312 ERROR: Repository [COLOR FF757677]Open[/COLOR][COLOR FF8ABEE2]ELEC[/COLOR] Mediacenter OS Add-ons returned no add-ons, listing may have failed
07:41:24 40244.640625 T:2756703312 NOTICE: Thread JobWorker start, auto delete: true
07:41:24 40244.644531 T:2708292688 NOTICE: Thread LanguageInvoker start, auto delete: false
07:41:24 40245.089844 T:2708292688 NOTICE: -->Python Interpreter Initialized<--
08:14:25 42226.171875 T:2708292688 NOTICE: Thread JobWorker start, auto delete: true
08:14:25 42226.175781 T:2756703312 NOTICE: Thread LanguageInvoker start, auto delete: false
08:14:26 42226.707031 T:2756703312 NOTICE: -->Python Interpreter Initialized<--
08:47:27 44207.742188 T:2708292688 NOTICE: Thread JobWorker start, auto delete: true
08:47:27 44207.746094 T:2878202960 NOTICE: Thread LanguageInvoker start, auto delete: false
08:47:27 44208.191406 T:2878202960 NOTICE: -->Python Interpreter Initialized<--
09:20:28 46189.175781 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
09:20:28 46189.179688 T:2708292688 NOTICE: Thread LanguageInvoker start, auto delete: false
09:20:29 46189.679688 T:2708292688 NOTICE: -->Python Interpreter Initialized<--
09:53:30 48170.750000 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
09:53:30 48170.750000 T:2699904080 NOTICE: Thread LanguageInvoker start, auto delete: false
09:53:30 48171.261719 T:2699904080 NOTICE: -->Python Interpreter Initialized<--
10:26:31 50152.296875 T:2878202960 NOTICE: Thread JobWorker start, auto delete: true
10:26:31 50152.300781 T:2756703312 NOTICE: Thread LanguageInvoker start, auto delete: false
10:26:32 50152.746094 T:2756703312 NOTICE: -->Python Interpreter Initialized<--
10:27:49 50229.617188 T:3057811456 NOTICE: Storing total System Uptime
10:27:49 50229.621094 T:3057811456 NOTICE: Saving settings
10:27:49 50229.917969 T:3057811456 NOTICE: stop all
#!/bin/sh
while : ; do
mkdir -p /storage/dmesg
now=$(date +%Y-%m-%d-%H.%M.%S)
dmesg > /storage/dmesg/$now.log
sleep 900 # 15 min
done &
jdb,jdb wrote:The BRANCH=next firmware now includes support for FIQ acceleration of high-speed isochronous transactions.
cvlc -vvv v4l2:///dev/video0:chroma="H264":width=1920:height=1024:fps=30 --sout '#rtp{sdp=rtsp://:8554/}' :demux=h264
rtsp://192.168.1.101:8554/
Please post full dmesg since boot and lsusb -v for the device.Defiant wrote:No visible improvement on stk1160 Video grabber.
Hi Defiant, What command are you using to perform the capture?Defiant wrote:No visible improvement on stk1160 Video grabber.
Ah.Defiant wrote:Sure, please note that the device needs a lot bandwidth: It uses a resolution of 720x480px with 30 fps and 2 Byte/px uncompressed.
lsusb: http://pastebin.com/mEvKz2xv
dmesg: http://pastebin.com/xjhUY59g
gst-launch-1.0 v4l2src ! fakesink
gst-launch-1.0 v4l2src num-buffers=100 ! jpegenc ! avimux ! filesink location=/tmp/test.avi
not needed, just do: sudo UPDATE_SELF=0 BRANCH=next rpi-updateB+W wrote: Thank you for the reply. I don't think I've ever manually updated this way. How would this work for installing the next branch?
I can confirm.Defiant wrote:No visible improvement on stk1160 Video grabber.
$ lsusb
Bus 001 Device 004: ID 05e1:0408 Syntek Semiconductor Co., Ltd STK1160 Video Capture Device
$ uname -a
Linux **** 3.10.33+ #659 PREEMPT Wed Mar 19 16:33:57 GMT 2014 armv6l GNU/Linux
$ cat /boot/cmdline.txt
dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x7 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
I tried with the following command:$ dmesg
[ 1143.187315] URB packet 0, status -63 [Buffer error (overrun)].
[ 1143.260192] URB packet 0, status -63 [Buffer error (overrun)].
[ 1146.717841] print_err_status: 14 callbacks suppressed
[ 1146.717877] URB packet 0, status -63 [Buffer error (overrun)].
[ 1146.968293] URB packet 0, status -63 [Buffer error (overrun)].
[ 1147.097833] URB packet 0, status -63 [Buffer error (overrun)].
mplayer -tv driver=v4l2:width=320:height=240:outfmt=rgb32:input=1 tv://
more information:[...]Frame too small! (827920<829440) Wrong format?
Frame too small! (823098<829440) Wrong format?
V: 0.0 54/ 54 ??% ??% ??,?% 0 0
Frame too small! (825758<829440) Wrong format?
Frame too small! (825420<829440) Wrong format?[...]
