bigguyone
cant download to SD card
Fri Feb 07, 2014 6:04 pm
ok dont know what i did but had RaspbarryXBMC running, lost sound no matter what i went on. Then it would play video & stop. When it did this it would say XBMC will restart. Now when i trun it on all it will do is load command lines (like it did when i got the SD card) but stops at (can not mount ).
My computer wont read the sd card to formate and reload Raspberry XMBC on it. I know it has to be the sd card i tried it in my other raspberry and it dose the same thing. So any one know what i did worng besides mess up?
FTrevorGowen
Re: cant download to SD card
Fri Feb 07, 2014 6:24 pm
bigguyone wrote:ok dont know what i did but had RaspbarryXBMC running, lost sound no matter what i went on. Then it would play video & stop. When it did this it would say XBMC will restart. Now when i trun it on all it will do is load command lines (like it did when i got the SD card) but stops at (can not mount ).
Looks like you've suffered filesystem/SD Card corruption. Are you trying to re-format the card with "ordinary" Windows "tools"? If so, try the recommended SDA Formatting tool (https://www.sdcard.org/downloads/formatter_4/ ) instead, with the settings shown here:
http://www.cpmspectrepi.webspace.virgin ... reparation or, if you have one, try formatting it in a digital camera.
Trev.
bigguyone
Fri Feb 07, 2014 6:46 pm
This is the site i went to but when i put the card in my computer it dont see it, but i have tried the other card that works fine and it wont see it ether. Both of these cards are from Raspberry.
FTrevorGowen
Fri Feb 07, 2014 7:18 pm
bigguyone wrote:This is the site i went to but when i put the card in my computer it dont see it, but i have tried the other card that works fine and it wont see it ether. Both of these cards are from Raspberry.
Are you using a "bulit-in" SD card slot or an external "USB stick-like" card reader/writer? (Some built-in card slots are not fully SDHC compatible an may not work with cards larger than 4Gb).
Assuming you're Windows based, what version? Do you have "admin" rights?
You say "Both of these cards are from Raspberry" were they pre-installed with NOOBS, and did you use that to install RaspBMC?
(Like this one here: http://swag.raspberrypi.org/collections ... gb-sd-card ?)
Trev.
drgeoff
Fri Feb 07, 2014 7:33 pm
I'm guessing that both your cards came with NOOBS pre-installed and that you've never had occasion to require, or have never succeeded at, installing anything on either of the cards via your PC. I'm wondering if your SD card reader doesn't support SDHC cards. Almost all 4 Gbyte cards are SDHC and these have a different interface protocol from the one used in all SD cards up to and including 2 Gbyte (and a few very rare 4Gbyte cards.) Older hardware that was designed before the SDHC specification won't work with SDHC cards.
If the above is the case, get yourself another card reader. If you are near a Poundland shop they can be had there. I'll leave you to guess the price. :)
bigguyone
Fri Feb 07, 2014 7:56 pm
I do have Win 7 on other computer at home i know one of these did read the card, when i frist got them i think i copyed them to my ext HHD but i tried to copy the files to sent to a sd card but didnt know witch ones Could i copy one card on compter then send it to the other card?
drgeoff
Fri Feb 07, 2014 8:06 pm
bigguyone wrote:I do have Win 7 on other computer at home ...... Could i copy one card on compter then send it to the other card?
Yes and no!
There is more than one type of file system on the SD cards that RPis use. Windows only understands (and only sees, and only displays) one of them.
So an "unaided" WIn 7 computer cannot copy RPi SD cards.
By installing various other bits of software a Win 7 computer could copy the cards.
Much easier for both of us (me explaining and you doing) for you to re-install NOOBS.
bigguyone
Fri Feb 07, 2014 8:26 pm
Oh yes i see. i will try and see if Win 7 will read it, if so i will formate and load NOOBS on it and see if it will work.
Iam still trying to get XBMC to work right ,like trying to get a library & get movies, TV shows in it. Trying to make it as easy as i can so wife can use it. But i guess i messed something up would like to get it working to were i can cut cable off
But i will post when i try reloading NOOBS later.
I have learn a lot on here from the other post looks like theres a lot more too.
Thanks for the help
