Buffer I/O Error on Reboot
Posted: Fri Jan 31, 2014 2:34 pm
by burhan
neeed helpp :(
i just installed the wheezy in my pi and and it is working fine but when i reboot it .it gives different error e.g buffer i/o error , respawning too fast . What can i do now??? need help because when i want to use my pi. just reinstalled wheezy again and again because it only work once :(
Re: How to start using your Raspberry Pi
Posted: Fri Jan 31, 2014 7:44 pm
by abishur
burhan wrote:neeed helpp :(
Do you have a USB hub attached? If not what all is connected to the Pi? And while that doesn't strike me as a power issue, what is the Amp rating of your power supply? Is it a well known brand or a generic charger?
Posted: Sun Feb 02, 2014 1:26 pm
by burhan
Don't know about amp , i
am using laptop usb port as a power supply of pi .Mouse , keyboard and lcd is attached with hdmi port
Posted: Mon Feb 03, 2014 11:45 am
by burhan
here is a text for config file which i am using its works fine only 1st tym after rebooting. it starts giving different error :(
by burhan
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=1
hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
Posted: Mon Feb 03, 2014 3:20 pm
by abishur
Just thinking out loud here, I would try a different power source, usb ports tend to only provide 500mA of current. If you're using the model B with a mouse, keyboard, and monitor then it's very possible that the pi is crashing because it doesn't have enough power.
When you say "when you reboot" how are you rebooting the pi?
Re: Buffer I/O Error on Reboot
Posted: Wed Feb 05, 2014 4:51 pm
by abishur
Did you get to follow up on your issue?
Posted: Fri Feb 21, 2014 9:45 pm
by burhan
yes sir, its a B model and i just tried to reboot with different power supplies but getting same errors ..don't know what to do :(
after installing wheezy and after getting into the teirminal i wrote "sudo halt" to shut it down and unplugged the power supply and after 1min i just attached the power supply and got this kind of error
Posted: Fri Feb 21, 2014 9:48 pm
by burhan
Sir if it is crashing just because of the attachment of mouse ,keyboard and monitor then what's the solution??
Posted: Sat Feb 22, 2014 6:06 pm
by DougieLawson
Attach the mouse and keyboard to a powered USB hub. Or get a better 5V 1.5A power supply.
Posted: Fri Feb 28, 2014 4:12 pm
by burhan
same error with 5V 1.5A power supply . sir if it works fine on first boot then i don't think its the power issue. need your suggestion
Posted: Fri Feb 28, 2014 4:17 pm
by DougieLawson
I think you should try a brand new SDCard.
Posted: Fri Feb 28, 2014 4:19 pm
by burhan
sir i am using brand new sandisk 4gb card
by DougieLawson
burhan wrote:sir i am using brand new sandisk 4gb card
Try a new RPi.
Posted: Fri Feb 28, 2014 4:21 pm
by burhan
means there is no solution . my pi is working well :( but just for 1 time boot
Posted: Fri Feb 28, 2014 4:48 pm
by DougieLawson
You could try
sudo apt-get update && sudo apt-get dist-upgrade && sudo rpi-update
that gets all software packages updated and updates the system firmware (which has some recent fixes for SDCard corruptions).
Posted: Fri Feb 28, 2014 4:53 pm
by burhan
ok thank you sir i;ll try this
