mladic97
Raspberry showing green
Mon Jan 27, 2014 5:07 pm
I have connected a HDMI - DVI cable to my raspberry and it shows green background where it should be black color. When I connect my raspberry with a HDMI - HDMI cable on my TV, it works perfectly. I have chacked the cable and the cable is good. What should I do?
drgeoff
Re: Raspberry showing green
Mon Jan 27, 2014 5:18 pm
Try adding config_hdmi_boost=4. (See http://elinux.org/RPiconfig#Video_mode_options.) If necessary try higher values up to 7.
mladic97
Mon Jan 27, 2014 5:41 pm
drgeoff wrote:Try adding config_hdmi_boost=4. (See http://elinux.org/RPiconfig#Video_mode_options.) If necessary try higher values up to 7.
should I add that in the config.txt file?
mladic97
Mon Jan 27, 2014 5:42 pm
The only way of get it working is connecting the cable after it has boot up.
mladic97
Mon Jan 27, 2014 9:32 pm
Not working.
