cant login with default pi and raspberry (solved)
Posted: Sun Jan 26, 2014 1:47 pm
by alf202
hi all,
I cant login with the default pi and raspberry it says login incorrect
any ideas?
ALL HELP IS APPRECIATED
Re: cant login with default pi and raspberry
Posted: Sun Jan 26, 2014 1:52 pm
by DougieLawson
Login is CaSe SeNsItIvE.
Pi <> pi <> PI
raspberry <> Raspberry <> RASPBERRY
the password doesn't display.
the keyboard defaults to QWERTY so in Germany you'll get a problem.
Posted: Sun Jan 26, 2014 1:57 pm
by alf202
DougieLawson wrote:Login is CaSe SeNsItIvE.
Pi <> pi <> PI
it still wont work!
Posted: Sun Jan 26, 2014 2:02 pm
by DougieLawson
Try a different keyboard.
Try typing the password in the id field (just as a test so you can see what comes out).
Check the docs for the os you're running. Is it pi/raspberry or root/root or root/raspberry or something else for id/password.
Posted: Sun Jan 26, 2014 2:07 pm
by redhawk
Just to confirm are you trying to login with Raspbian??
The username is: pi the password is: raspberry (letters are all lowercase, also passwords are never echoed on the screen as a security feature)
If you still cannot login then try typing raspberry as the username - do the letters coming out correctly??
Richard S.
Posted: Sun Jan 26, 2014 5:04 pm
by alf202
Yes I m using raspbian dont worry its all sorted now im using a different keyboard
Re: cant login with default pi and raspberry (solved)
Posted: Thu Mar 06, 2014 7:52 am
by PIrogue
How can a different keyboard solve this problem?
I'm asking because I am experiencing the same trouble: I downloaded this [1] image and I can't login in, neither on terminal, nor via ssh. I know that a qwerty keyboard is expected, so I tried "raspberry" as well as "raspberrz" as password.
When I type letters the all come out correct: I can type "raspberry" (typing z instead of y) as user name and I see that word on the console. So I would expect the letters also to come out correctly when I type in the password.
So what can I do? I do not own a second keyboard. If I really need to try another keyboard, I need to borrow one. Is there any chance I could edit some files on the sd-card, before booting the raspberry?
[1] http://downloads.raspberrypi.org/raspbian_latestthis image
