Yesterday I bought a raspberry pi because i wanted to get an advantage of programing. So I put the NOOBS lite on my sd card and installed the OS. I did it on my TV. Today I woke up and decided to run it on my computer screen. So I picked up a HDMI-DVI cable and on the screen green and red background appeared. To solve this, I connected my Raspberry Pi to the TV i first connceted to and then to my computer screen again. All worked well and I decided to change the resolution so I changed the config.txt to 1600x1200. I command "sudo restart" and after that the green and red background appears every time and the boot freezes to
"PANIC: VFS: Unable to mount root fs on unknown-block(179,2)
Entering kdb (current=0xcb846c80, pid 1) due to Keyboard Entry
kdb> _"
So I decided to format the SD card but my computer wont allow it. I tried to format the SD card from Ubuntu GParted without results. Did the same with CMD and on my macbook, still no result. Not even the recovery mode is working. I think my SD card may be corupted. What should I do now?
