trevorboultwood
Unable to mount root fs
Mon May 28, 2012 11:13 am
So I just recieved the pi this morning, and I try to boot and recieve the
'Kernel panic - not syncing: VFS Unable to mount root fs on unknown-block(179,2)'
It then stops there and I am unable to type...
The line of code before that: 'No filesystem could mount root, tried: ext4'
I have no idea what be the problem :S
Any suggestions? Thank you very much!
mr_spider
Re: Unable to mount root fs
Tue May 29, 2012 3:47 am
I had the same problem as well! Either try another SD card, or if you're more advanced, download the actual Fedora image, un-gzip it (it downloads as a *.gz), then using dd, write the resultant file to an SD card.
nick.mccloud
Tue May 29, 2012 8:04 am
I'd hesitate to use the Fedora image as it has 'issues'. However it does sound like your card wasn't completely imaged. As it got as far as reading the first part, the dos partition that allows it to boot up, I'd redo the image and try again.
jezmck
Wed May 30, 2012 10:38 pm
I had the same problem with 4 SD cards.
I ended up ordering a preloaded card from ebay, and my pi now works fine.
zfh10
Sat Jun 09, 2012 1:45 am
I have the same problem. My Pi has just arrived and I want to get it going. Got the new Debian image. I get '-110 errors', Kernal Panics, and now 'No filesystem could mount root'. I've tried 2 different SD cards now, including a Kingston that is supposed to work. Really disappointed that I have to muck around like this....it should just work! Have spent 5 hours on this so far, researching and formatting new cards. There's been a few swearwords. Feel like smashing the Pi with a hammer to be honest.
<deep breath>
If anyone can help (not hammer choice, but Pi help) I'd be grateful.
jezmck
Sat Jun 09, 2012 9:10 am
Can you try the other OSs? e.g. Arch.
felice
Sat Jun 23, 2012 10:42 pm
Nearly, same problem here. After flashing debian wheezy image to the sd card, it boot's and run's fine until I install some Software. Then, after reboot it throw's the "No filesystem could mount root" Error.
Does anybody know if it's a hardware(the sd card) bug or it may be solved by refactoring the images?
diegom_ch
Mon Jul 30, 2012 5:12 am
No hardware problem. No Raspberry Pi problem. She's inocent I swear. You just need "CONFIG_LBDAF=y" in your kernel. If you have compiled it yourself, recompile it with that config set. If you haven't, well, you can start doing it or get updated kernel images.
If you haven't compiled it and you want to give it a try, you will have to do the following:
  • Get the sources and the config of the kernel you are trying to use.
  • If you aren't currently using another ARM box (which is probably the case) you will have to build your own cross toolchain.
  • Use the config and the (cross) toolchain to recompile the kernel.
If you are wondering how to do all this which seems pretty easy (?), you will find out it's not. But is it worth the effort? God yes.
Maybe the most frustrating part can be the cross toolchain. Some people avoid this problem using some kind of virtualization like qemu. My advice would be: if you really can't make the cross toolchain and you are about to kill your cat, then use the virtualization. That's because this technique uses too much resources when compiling or doing any other intensive stuff.
