learning
Parse xbee API frames
Mon Jan 20, 2014 1:53 pm
I have got my routers (AT mode) connected to a micro-controller and sending comma separated data to the coordinator (API mode), the coordinator is connected to the rasp and data received is viewed in a terminal program. How can i eliminate the API header information attached before the actual data?
Loonhaunt
Re: Parse xbee API frames
Sat Feb 01, 2014 9:13 pm
Quick Question,(S) where did you find XCTU for your Pi. I assume you are using Wheezy?
Are you connecting with FTDI and Driver. If so I do not know which one to use, nor the mechanics of unzipping with terminal.
Thanks,
Work looks pretty cool so far. I am anxious to get going on this as well.
Dave
Good luck with your question, if I get that far I will help you out,
