Roel
(SOLVED) bin/bash not found when trying to run a script
Mon Jan 13, 2014 9:01 am
All, I haven't found a topic regarding this, so:
To keep my wifi-connection alive, I found a few scripts, one of them being from this forum (by MrEngman, if I remembre correctly).
However, when I try to run the script, the first message looks like "/bin/bash not found", and then signals like "unexpected done, expecting fi" etc.
So it seems like something IS done, but not completely or sufficiently. Should something be done in order to run scripts properly?
texy
Re: bin/bash not found when trying to run a script
Mon Jan 13, 2014 12:37 pm
Hi and welcome to the forum.
Sorry - you need to give us more info - which script are you taking about? Which wifi dongle?
If you have the Edimax type then this may be useful :
http://www.raspberrypi.org/forum/viewto ... 0b#p483763
Texy
RaTTuS
Mon Jan 13, 2014 12:49 pm
can you post the script here [using code blocks]
have you downloaded the script using windows?
Covfefe
Roel
Mon Jan 13, 2014 1:33 pm
Yes, I used this one:
#!/bin/bash
while true ; do
   if ifconfig wlan0 | grep -q "inet addr:" ; then
      sleep 60
   else
      echo "Network connection down! Attempting reconnection."
      ifup --force wlan0
      sleep 10
   fi
done
And it came from http://www.raspberrypi.org/phpBB3/viewtopic.php?t=16054
Thanks!
*edit* No I completely retyped it from my Debian machine using vim. So no Windows involved here.
I am (besides the wifi-keep-alive routine) just curious why my RPi just doesn't "eat" script.
RaTTuS
Mon Jan 13, 2014 1:42 pm
are you using raspbian or openelec or arch or something else ?
Covfefe
Roel
Mon Jan 13, 2014 2:02 pm
I am using Raspbian, and by the way, the dongle is a white TP-Link with a realtek chipset, which needs firmware-realtek.
By the way, I AM familiar with Debian, I just never used scripts so far.
duberry
Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
Mon Jan 13, 2014 5:56 pm
what is displayed when you type
which bash
in a terminal ?
fyi
i get this
[email protected] / $ which bash
/bin/bash
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
redhawk
Mon Jan 13, 2014 7:32 pm
If you edit your script with vi (not pico or nano) is each line terminated with ^M ??
Richard S.
Roel
Tue Jan 14, 2014 5:59 am
duberry:
[email protected] ~ $ which bash
/bin/bash
redhawk: no, not a single line was ended with ^M
Should it be?
Tue Jan 14, 2014 7:00 am
Perhaps you could try typing in a minimal script to see if that works.
#!/bin/bash
echo "It works!"
Then chmod 700 myscript, (or whatever you called it) and run with ./myscript
Richard-TX
Tue Jan 14, 2014 7:49 am
Roel wrote:Yes, I used this one:
I don't like the syntax of that shell script.
Here is how I would write it.
#!/bin/sh
# I use /bin/sh for scripts.  It keeps things saner....and smaller and maybe more secure.
while true
do
if [ $? -eq 0 ]
 then
 sleep 60
# I added the exit 0 since once the connection is up, there is no need for the script to continue running.
# If the above statement is not true then comment out the next line.
 exit 0
else
      ifup --force wlan0
      sleep 10
fi
done
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
Roel
Tue Jan 14, 2014 10:53 am
rpdom: OK, will do. But I guess I need to (sudo) chmod +x in order to run the script?
Richard-TX: thank you, I'll check this tonight as well. Only thing that raises a question is your "I added the exit 0 since once the connection is up, there is no need for the script to continue running" statement.
The idea is to run a script in the background that checks the connection every x minutes , and bring up the interface again once the connection was lost (which, unfortunately, happens every now and then using wireless).
The other solution would be to work with wicd-curses, but I read a lot of nasty things about connection duration of wicd-curses...
Tue Jan 14, 2014 12:46 pm
Roel wrote:rpdom: OK, will do. But I guess I need to (sudo) chmod +x in order to run the script?
As you own the script you don't need sudo. Also chown 700 will set the permissions to -rwx------ which is enough for you to run it (chmod +x sets all three "x" bits)
Joe Schmoe
Tue Jan 14, 2014 1:09 pm
Also chown 700 will set the permissions to ...
Actually,
chown 700 file
will set the ownership of the file to the user who's uid is 700 - which probably doesn't exist on your system.
Note that the above command does have to be run either as root or via sudo, because of stupid restrictions that were placed on the Unix "chown" functionality sometime in the last few decades.
Yesfan
Tue Jan 14, 2014 1:12 pm
rpdom, you meant "chmod 700", right? "chown" changes the owner of the file, not the file permissions.
Pete
jojopi
Tue Jan 14, 2014 1:28 pm
"chmod +x" sets all the execute bits that are not prohibited by your current umask. That is almost always what you want, otherwise you should change your umask. (On the other hand, "chmod -x" clears the execute bits except any that are set but prohibited by umask. That is not very useful, so you should use "chmod a-x" to clear them all instead.)
We do not seem to be getting any closer to diagnosing the actual problem. The errors in the original post are not reported very accurately, but I cannot produce anything even close to them by the usual faults of CR-LF line endings, or literal no-break spaces in a copy and paste.
If Roel has "completely retyped" the script, then I suspect the version we see above is not the same one being executed.
Roel
Tue Jan 14, 2014 1:37 pm
jojopi wrote:We do not seem to be getting any closer to diagnosing the actual problem. The errors in the original post are not reported very accurately, but I cannot produce anything even close to them by the usual faults of CR-LF line endings, or literal no-break spaces in a copy and paste.
I found the script here: http://www.raspberrypi.org/phpBB3/viewtopic.php?t=16054
And yes, I retyped it because I was vi-ing through ssh. and didn't know how to paste in vi from clipboard...
Richard-TX
Tue Jan 14, 2014 2:24 pm
Rule of thumb for executables.
chmod 755 filename
Ownership of the file does not matter.
run yours as root. ie sudo /full/pathto/filename
Richard
Richard-TX
Tue Jan 14, 2014 2:32 pm
you might check for control characters in the original script.
cat -v filename should work.
Richard
Joe Schmoe
Tue Jan 14, 2014 2:40 pm
chmod 755 filename
N.B. The "chmod" thing is only necessary for scripts. It is important to note that compilers will set the executable bit for you when they create the final output file (Nitpick: I suppose technically you could say that it is the assembler that creates the final output file, and thus sets the executable bit).
In a way, this is kind of an annoying inconvenience for scripts. In a perfect world, it wouldn't be necessary - especially because (when you really think it through), there isn't really a meaningful distinction between "executable" and "readable" in the world of scripts (as there, in fact, is in the world of compiled executables).
Anyway, I have a macro in vi(m) that saves the file and makes it executable; I use this the first time I save any script:
map <leader>X :w<bar>call system('chmod +x '.bufname(""))<bar>e<cr>
Tue Jan 14, 2014 4:44 pm
Pete
Yes, sorry. I was in a hurry to get back to work and didn't check what I typoed. Mea culpa :(
wimble
Tue Jan 14, 2014 5:02 pm
Roel wrote:And yes, I retyped it because I was vi-ing through ssh. and didn't know how to paste in vi from clipboard...
If you're using PuTTY to connect from a Windows machine to the Pi, then it's right click, so you end up with the following sequence:
vi network-monitor.sh  (to edit the blank file)
i                      (to get into insert mode)
right-click            (to insert the copied text)
Esc                    (to return to command mode)
:wq                    (to write the file and quit)
You can also use shift-Insert instead of the right click instead.
Joe Schmoe
Tue Jan 14, 2014 5:22 pm
Yes, it is always better to use Shift/Insert instead of messing around with mice and menus.
Also, when I create a file on Unix that comes from the ciipboard, it is usually better to start with:
cat > file
Shift/Insert
Control/D
Followed by:
vim file
Because vi(m) is (in my systems) configured (and if it isn't on your systems, it should be) for auto-indent. So, when doing a big paste, it is safer to use cat rather than vi(m).
Roel
Tue Jan 14, 2014 8:49 pm
You are right, the script showed terrible symbols when viewing with cat -v.
This time I copied and pasted using shift-insert (of which feature I did NOT know) and it works like a charm.
The script is running as it is and I'm curious if it does what it promises.
Later on I will try the other script and to see what happens.
Sorry to have kept you all busy for such stupid mistake of mine...
Thanks all!!
