apt-get doesn't work
Posted: Sat Jan 04, 2014 5:25 am
by smeezekitty
Now I finally have my pi "sorta" working but the keyboard still repeats sometimes.
Now my problem is with apt-get though
This is the image: http://www.cnx-software.com/2012/07/31/ ... pberry-pi/ (no GUI)
for example apt-get install links2 gives me this
Building package lists... Done
Building dependency tree
Reading state information Done
The following extra packages will be installed:
libdirectfb-1.2-9 libgpm2 libjpeg8 libsvga1 libtiff4 libts-0.0-0 libx11-6 libx11-data libxau6 libxcb1 libxdmcp6 tsconf
Suggested packages:
gpm
The following new packages will be installed:
libdirectfb-1.2-9 libgpm2 libjpeg8 libsvga1 libtiff4 libts-0.0-0 libx11-6 libx11-data libxau6 libxcb1 libxdmcp6 links2 tsconf
0 upgraded, 13 newly installed, 0 to remove and 0 not upgraded.
Need to get 3220 kB/4754 kB of archives.
After this operation, 9395 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libtiff4 armhf 3.9.6-6
    404 Not found
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxcb1 armhf 1.8.1-1
    404 Not found
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libx11-data all 2:1.5.0-1
    404 Not found
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libx11-6 armhf 2:1.5.0-1
    404 Not found
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main links2 armhf 2.7-1
    404 Not found
Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/t/tiff3/libtiff4_3.9.6-6_armhf.deb 404  Not Found
E: Unable to fetch archives, maybe run apt-get update to try with --fix-missing?
Please help
Re: apt-get doesn't work
Posted: Sat Jan 04, 2014 5:48 am
by rpdom
Your package index is out of date. It is trying to download old versions of the files which don't exist on the servers anymore.
Run "apt-get update" first to update the indexes, then try the install again.
You should probably also run an "apt-get update" to upgrade any other software that has new versions.
Posted: Sat Jan 04, 2014 6:09 am
by smeezekitty
apt-get update succeeded but I still got the same errors
Posted: Sat Jan 04, 2014 6:44 am
by rpdom
Strange. That should have worked.
I'm showing the current version of libtiff as 3.9.6-11, but yours is showing 3.9.6-6?
What does the output of "apt-cache policy libtiff4" show?
Posted: Sat Jan 04, 2014 6:53 am
by smeezekitty
rpdom wrote:Strange. That should have worked.
libtiff4:
   installed: (none)
   Candidate: 3.9.6-6
   Version table:
        3.9.6-6 0
            500 http://mirrordirector.raspbian.org/raspbian/ wheezy/main armhf Packages
            100 /var/lib/dpkg/status
Posted: Sat Jan 04, 2014 7:44 am
by rpdom
Hmm, that's still showing the old version.
Perhaps the mirrors haven't all been updated yet?
Wait a while (a day perhaps) and then try the apt-get update again. You should see some "GET" messages instead of "HIT". (GET means "new version found - downloading". HIT means "found same version - no download needed")
Posted: Sat Jan 04, 2014 7:53 am
by smeezekitty
rpdom wrote:Hmm, that's still showing the old version.
I will try it in the morning. It is almost bed time here anyway
I got all hits on the apt-get update
Posted: Sat Jan 04, 2014 6:15 pm
by smeezekitty
Still having a problem.
All hits on apt-get update
-edit-
changing the repos to archive.raspbian.org
Now I get several "Get"
followed by sitting at
100% [2 PACKAGES BZIP2 0 B]
for a VERY long time (> 3 minutes)
and then it says
Fetched 7535 kB in 10 min 24s (12.1 kB/s)
W: Failed to fetch bzip2:/var/lib/apt/lists/partial/mirror.raspberrypi.org_raspbian_dists_wheezy_main_binary_armhf_Packages Hash sum mismatch
W: Failed to fetch bzip2:/var/lib/apt/lists/partial/mirror.raspberrypi.org_raspbian_dists_wheezy_contrib_binary_armhf_Packages Hash sum mismatch
W: Failed to fetch bzip2:/var/lib/apt/lists/partial/mirror.raspberrypi.org_raspbian_dists_wheezy_non-free_binary_armhf_Packages Hash sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
Posted: Mon Jan 06, 2014 1:37 am
by smeezekitty
bump
Posted: Mon Jan 06, 2014 6:02 am
by rpdom
Just one more thing - how much free space have you got in your root (/) file system? Please show output of "df -h /"
Posted: Mon Jan 06, 2014 7:21 pm
by smeezekitty
Thanks for responding
Filesystem        Size Used Avail Use% Mounted on
rootfs            433M 262M 149M   64% /
/dev/root         433M 262M 149M   64% /
tmpfs              22M 188K  22M    1% /run
tmpfs             5.0M    0 5.0M    0% /run/lock
tmpfs              44M    0  44M    0% /tmp
tmpfs              10M    0  10M    0% /dev
tmpfs              44M    0  44M    0% /run/shm
/dev/mmcblk0p1     31M  19M  13M   60% /boot
