Cridi
invalid/unknown driver 'rtl8192cu' - in hostapd
Wed Jan 01, 2014 8:05 pm
Hi Guys
im tryin to set up my Pi as an AP however it does not work. I downloaded hostapd and udhcpd. I Set up everything and it does not work.
after typin hostapd /etc/hostapd/hostapd.conf this occures:
root@raspberrypi:~# hostapd /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
Line 2: invalid/unknown driver 'rtl8192cu'
1 errors found in configuration file '/etc/hostapd/hostapd.conf'
root@raspberrypi:~# lsusb
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
[    3.461566] usb 1-1.2: Product: 802.11n WLAN Adapter
[    3.468721] usb 1-1.2: Manufacturer: Realtek
[    3.486602] usb 1-1.2: SerialNumber: 00e04c000001
[    3.847775] udevd[154]: starting version 175
[    5.006956] Registered led device: led0
[    6.741106] usbcore: registered new interface driver rtl8192cu
[   13.450243] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[   13.891319] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[   23.284580] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
So obviously the right driver is set in hostapd.conf but it does not work. Has someone a Solution idea?:)
Re: invalid/unknown driver 'rtl8192cu' - in hostapd
Thu Jan 02, 2014 12:58 am
Cridi
Thu Jan 02, 2014 11:40 am
Jeah Thanks!
I already found this one half an our after my post here too. But this is not working either way. If I do it like on the page my Pi is emiting the Wifi signal so i can see it on my laptop but i cant connect, there are authification problems -.-
MrEngman
Sat Mar 29, 2014 2:13 am
Cridi wrote:Jeah Thanks!
I can set up my Pi as an AP with the same wifi adaptor on Raspbian
My /etc/hostapd/hostapd.conf is
interface=wlan0
driver=rtl871xdrv
bridge=br0
ssid=NETWORK-NAME
channel=1
wmm_enabled=0
wpa=1
wpa_passphrase=NETWORK-PASSWORD
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
No need to change the line "driver=...". I have even found it works if that line is removed or commented out. Or you can try changing the driver to 8192cu which is the driver module although I think it is totally unnecessary. I've not tried it as it's not necessary to get it working.
I set up my AP using the data Dougie pointed you to. I did, however, compile my own hostapd from the driver source I have. Tried mine with raspbian 3.10.25+ #622 and 3.10.34+ #660 using the same hostapd file for both.
You can download the version of hostapd I compiled from here. This file contains a 8188eu wifi driver for 3.10.25+ and the hostapd I used for 3.10.25+ and 3.10.34+ so I would expect it to work for any revisions between those two, and possibly other versions of 3.10.y as well.
MrEngman
femindharamshi10
Thu Mar 24, 2016 5:31 am
ok so i dont want a bridged connection. i just want a access point so devices can connect to it and access the apache2 server on my pi. so what all do i need to do ?
follow this link fully or partly ? and what about dhcp ? can you please explain ?
