Yacine
libattr.so.1 => not found
Tue Dec 31, 2013 7:38 pm
Hi all,
I'm going crazy with this error since a while:
error while loading shared libraries: libattr.so.1: cannot open shared object file: No such file or directory
I started looking for a solution on the internet but nothing to do, I can not solve my problem.
I think it is because it lacks a library, but I do not know how to solve.
[email protected] /lib $ ldd /bin/ls
        /usr/lib/arm-linux-gnueabihf/libcofi_rpi.so (0xb6f14000)
        libselinux.so.1 => /lib/arm-linux-gnueabihf/libselinux.so.1 (0xb6ee4000)
        librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xb6ed5000)
        libacl.so.1 => /lib/arm-linux-gnueabihf/libacl.so.1 (0xb6ec6000)
        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb6e9e000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6d6f000)
        /lib/ld-linux-armhf.so.3 (0xb6f20000)
        libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb6d64000)
        libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6d45000)
I would appreciate any help, thanks !
http://www.shadowblog.fr/ <= Blog pour ceux qui débutent avec le Raspberry Pi
Re: libattr.so.1 => not found
Tue Dec 31, 2013 8:14 pm
sudo apt-get install libattr1
Yacine
Tue Dec 31, 2013 9:44 pm
Thanks for your answer, but it doesn't work. Here is what I get:
Setting up install-info (4.13a.dfsg.1-10) ...
cp: error while loading shared libraries: libattr.so.1: cannot open shared object file: No such file or directory
dpkg: error processing install-info (--configure):
 subprocess installed post-installation script returned error exit status 127
 install-info
Yacine
Thu Jan 02, 2014 1:00 am
In fact I can't upgrade neither install any new package, because the command cp seems to use tje libattr.so library.
Any idea on how solving this ? Thanks a lot!
Thu Jan 02, 2014 1:19 am
You'll need to find a way of getting a good copy of libattr.so.1
Or you're going to have to rebuild your SDCard (or recover it from that backup you took last week ... oh you didn't back it up).
If you get a USB SDCard reader you can have two SDCards mounted on one RPi. Build a new copy of Rasbian on a new card.
Boot the RPi from the new card.
Mount the broken Raspbian installation in the card reader.
You then have two choices
1. Copy config stuff from the broken Raspbian to the new install (so you don't have to reconfigure everything), you will need to re-install all of those software packages (it's a right pain in the tail, but do-able).
2. Copy cp -R /lib/* to the broken Raspbian, copy cp -R /usr/* to the broken Raspbian. You can probably get away without copying /bin or /sbin, but you may want to add those two. Shouldn't need /var or /opt
When my 32GB SDCard was about to expire I chose option 1. It involved copying /etc, /root and /home to the newly built card then working through what software packages I needed to re-install and what packages I could forget (things I'd only installed for experiments). I've since moved /home stuff to my NAS box (2TB HD) and have that on an NFS share (so it won't go missing again).
Option 2, if it works is a better rescue and will have a lower impact. If you go that way then the first things to do once you're back running are
1. Take a backup
2. sudo apt-get update, sudo apt-get dist-upgrade, rpi-upate & reboot
3. Take another backup
Yacine
Thu Jan 02, 2014 1:50 am
Ok thanks !
I think i'll go with the option 1. Because all I need is my blog's files (I use the Rpi as web server for my blog, and yeah :cry: I didn't back it up).
Is it possible to access to those files easily, wich are in /var/www/ ?
Thanks again for your help :)
jojopi
Thu Jan 02, 2014 2:19 am
Yacine wrote:In fact I can't upgrade neither install any new package, because the command cp seems to use tje libattr.so library.
The missing libattr.so.1 will not stop you installing libattr1 itself. It is merely blocking the completion of package install-info, which you already have in half-configured state. If these are your only problems, you can do:
sudo apt-get purge install-info
sudo apt-get install --reinstall libattr1
sudo apt-get install info
(There may be a better way to get apt/dpkg to defer configuration of install-info until after libattr1 is reinstalled, but I can not find it.)
Yacine
Thu Jan 02, 2014 11:33 am
\o/ YEAH !!!
Thanks jojopi, it now works correclty :)
