Ahammer18
Rainbow Splash Screen Upon Reboot
Tue Dec 31, 2013 5:23 pm
Let me start off by listing my specs:
Rpi model B
Debian "Wheezy" Raspian (Latest update)
5.1 V = 850mA Motorola Cellphone Charger as Psu
4 GB Lexar Multi-use Sd Card
I have one simple problem. When I boot up Raspian for the first time in awhile, it runs fine. The GUI loads fine and everything is well. The problem starts when I reboot the Pi. Once the Pi shuts off and turns back on, I am greeted by a rainbow splash screen.
I have seen forum posts regarding the rainbow screen, but I haven't seen any that included my problem with rebooting the Pi.
Any help would be greatly appreciated.
FTrevorGowen
Re: Rainbow Splash Screen Upon Reboot
Tue Dec 31, 2013 8:40 pm
Ahammer18 wrote:Let me start off by listing my specs:
Rpi model B
Your "5.1V 850mA" PSU may be "marginal" (5V 1000mA is recommended for a Model B). The best check of this is to measure the voltage between the test points TP1 & TP2 (marked as susch on the PCB) - it should be at least 4.75V. A secondary issue could be too much resistive "voltage droop" because of a poor quality power cable (same test applies).
(FWIW, there are examples of measured good & bad PSU behaviour here: http://www.cpmspectrepi.webspace.virgin ... dPSUs.html )
Trev.
Ahammer18
Wed Jan 01, 2014 1:44 am
Thanks for your reply. Do you have a well working PSU that you would reccomend? Also, could it be anything else unrelated to the power supply?
Wed Jan 01, 2014 2:08 am
smeezekitty
Wed Jan 01, 2014 2:20 am
How is that a problem?
Wed Jan 01, 2014 2:24 am
smeezekitty wrote:How is that a problem?
How is that comment not a non-sequitur?
HNY 2014
Ahammer18
Wed Jan 01, 2014 2:39 am
So is running 5 V through the pi a problem?
Wed Jan 01, 2014 2:35 pm
Ahammer18 wrote:So is running 5 V through the pi a problem?
You're commenting on my forum signature.
Wiring any 5V supply to any GPIO pin other than pin2 will make your RPi die very quickly.
Carve it a nice headstone and give it a good burial.
Richard-TX
Wed Jan 01, 2014 2:45 pm
I get a rainbow splash screen whenever I power my Rpi from a USB hub. All of my Rpis work fine.
I have not seen any detrimental effects from it in over a year of nearly daily use.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
smeezekitty
Fri Jan 03, 2014 8:49 am
HNY 2014
"How is it a problem" actually makes sense. Mine does it too and I assume it is by design.
So unless there is an actually problem other than the splash screen, why worry?
FTrevorGowen
Fri Jan 03, 2014 1:57 pm
HNY 2014
To some extent I think the O.P. may have been open to mis-interpretation ie. if only the RGB splash screen was being seen it could have been a problem. Said splash screen is related to the very first part of the boot process but, depending upon the monitor/TV and/or installation type (eg. NOOBS cf. raw image) may not be seen because the display in use "activates" too late. (A simpler example w.r.t. my setup is that I have to switch my "shared" monitor between VGA, for my netbook, to DVI, for a Pi, within the time the splash screen is being generated in order to see it. That's not always possible :) )
Trev.
Richard-TX
Sat Jan 04, 2014 5:42 am
I had a problem with 2 new Pis that I just bought. Both of the made in the UK and from Allied. They would intermittently hang on the rainbow screen. adding boot_delay=1 to the /boot/config.txt file fixed it. The big question is what did the UK builder change? I have Sony built and China built Rpi's and none of them hang. Just these 2 new ones.
Richard
Sat Jan 04, 2014 7:40 am
The Sony ones are the UK built ones.
It is possible there was a change of memory chip at some point. This can mean the GPU code has to be updated with new timing details.
gsh
Sat Jan 04, 2014 7:42 am
Are the two new ones with Micron memory (they have an M on them)
If so then there is another forum page with something you can try...
http://www.raspberrypi.org/forum/viewto ... lit=gordon
Gordon
Gordon Hollingworth PhD
Kegluneq
Sun Jan 05, 2014 3:41 pm
Richard-TX wrote:I had a problem with 2 new Pis that I just bought. Both of the made in the UK and from Allied. They would intermittently hang on the rainbow screen. adding boot_delay=1 to the /boot/config.txt file fixed it. The big question is what did the UK builder change? I have Sony built and China built Rpi's and none of them hang. Just these 2 new ones.
Just to clarify (I'm not able to check this at the moment), are you literally just adding the line 'boot_delay=1' to the text file? I now have this in my Raspbian image:
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
boot_delay=1
...but as I'm a complete noob I'm not totally sure that's what people are referring to.
raspberrypiguy2000
Sun Jan 05, 2014 3:53 pm
it is supost to be there
Sun Jan 05, 2014 3:55 pm
That's what you need to delay boot until the SDCard is ready.
Sun Jan 05, 2014 3:57 pm
Yes, that is exactly what we are referring to.
Kegluneq
Sun Jan 05, 2014 4:24 pm
Thanks guys, I'm into Raspbian now at last!
