cesiumfountains
problem with rebooting into gui
Mon Dec 30, 2013 5:02 pm
So, I seem to have an issue with the first reboot after raspi-config. I installed Noobs and then picked raspian as my os. then It proceeds to go to raspi-config and after i customize to us standards and pick boot to desktop then finish. It reboots to a blank screen with a flashing cursor. I have tried re formatting the sd card multiple times and following installation procedures and it still leads to the same problem. also I have a raspberry pi kit from adafruit so i would hope that the problem wouldn't be with a improper sd card or power issue. thanks for your time.
ShiftPlusOne
Re: problem with rebooting into gui
Mon Dec 30, 2013 6:09 pm
Is it a 4GB card? If so, the issue might be that there's not enough free space.
cesiumfountains
Mon Dec 30, 2013 9:26 pm
It is a 4gb card. I thought that would have enough space for raspian? If it doesn't, which size would you recommend?
ShiftPlusOne
Tue Dec 31, 2013 10:13 am
it is enough for Raspbian, it's just not enough for NOOBS + raspbian. Try using a raw image without NOOBS.
Edit: Typing fail.
Tue Dec 31, 2013 12:39 pm
Not all SDCards are created equal. (With apologies to T. Jefferson.)
http://www.bunniestudios.com/blog/?p=3554
It's very interesting how unreliable flash memory is and why no two SDCards (even from the same manufacturer) report the same amount of available space.
cesiumfountains
Tue Dec 31, 2013 7:07 pm
Just installing the raw image seemed to fix the problem. Thanks a ton for you quick and informative responses!
ShiftPlusOne
Tue Dec 31, 2013 7:09 pm
You're welcome
