zsawyer
Unable to format SD card, Tried DISKPART
Mon Dec 30, 2013 2:08 am
SD card stopped working, as evidence of no video on my Raspberry Pi and a replacement SD card worked fine.
OS: Vista
4Gig Card came with a Raspberry Pi kit
Was working and preloaded with NOOBS.
Successful install of Raspian
Then stopped working.
Started with SDformatter4, windows still did not recognize.
So I tried a slurry of other formattings from 3rd party to DISKPART
Disk Management tells me 3.82G RAW and Healthy Primary Partition
Active@ Partition manager also states the filesize and lists it as unknown.
Here are my results of DISKPART
DISKPART> select disk 2
Disk 2 is now the selected disk.
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 466 GB 0 B
Disk 1 Online 699 GB 0 B
* Disk 2 Online 3920 MB 0 B
Disk 3 No Media 0 B 0 B
Disk 4 No Media 0 B 0 B
Disk 5 No Media 0 B 0 B
DISKPART> select partition 1
There is no partition selected.
DISKPART> list partition
Partition ### Type Size Offset
* Partition 1 Primary 3920 MB 0 B
DISKPART> clean all
DiskPart succeeded in cleaning the disk.
DISKPART> format fs=fat32 quick
0 percent completed
DiskPart has encountered an error: The parameter is incorrect.
See the System Event Log for more information.
DISKPART> format fs=fat32 quick override
0 percent completed
DISKPART> delete partition
There are no partitions selected.
Please select a partition, and try again.
DISKPART> create partition MSR
There is insufficient free space to create a partition at the specified size
and offset.
Specify different size and offset values or don't specify either to create the
maximum sized partition.
DISKPART> create partition primary
and offset.
DISKPART>
I think my computer is lying to me, and I don't know how...
I bolded what I thought was most interesting and what I hope could tell me what is wrong.
Any help would be most appreciative, thank you in advance.
Re: Unable to format SD card, Tried DISKPART
Mon Dec 30, 2013 9:57 am
After you write the new one single 3.9GB partition close diskpart, safely eject the card. Re-insert it and carry on to the next steps.
zsawyer
Tue Dec 31, 2013 6:22 pm
I am wanting to use the old 3.9G card as a backup.
What diskpart command are you referring to as "write the new one single 3.9GB partition" ?
any create partition command states the error no partition selected.
Some of the format commands act like they are working and the percentage counts up but then shows:
"0 percent completed
DiskPart has encountered an error: The parameter is incorrect."
I do not understand why diskpart will not select the partition.
