yanewby
raspistill: command not found
Sat Dec 28, 2013 2:36 pm
I have just unboxed my new raspberry pi camera module that I received as a present.
I have installed it as per the instructions.
I have run sudo raspi-config and enabled the camera.
The problem I have is when I run this:
I get an error message stating:
-bash: raspistill: command not found
This suggests to me that raspistill is not installed.
How do I install this? Any other ideas what could be wrong?
Richard-TX
Re: raspistill: command not found
Sat Dec 28, 2013 3:06 pm
Did you go through the raspi-config menu and select the camera add-on support option?
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
yanewby
Sat Dec 28, 2013 3:11 pm
Yes, and I've done sudo apt-get update && sudo apt-get upgrade.
The updates did not find anything to upgrade or install.
tvoverbeek
Sat Dec 28, 2013 3:28 pm
Strange ..., the 'sudo apt-get update' and 'sudo apt-get upgrade' should have installed it.
I am assuming you are running raspbian.
What is the output from 'uname -a' in a terminal? It currently should show kernel version 3.10.24+.
What you could try is to run 'sudo rpi-update' which updates to the latest kernel, modules and firmware utilities, including raspistill and raspivid.
If you run an other distribution I do not know how the camera utilities can be installed.
Good luck with the camera.
Sat Dec 28, 2013 11:27 pm
Try
sudo rpi-update
followed by a reboot
