cpfeil
DHCPDISCOVER in endless Loop on startup
Wed Dec 25, 2013 1:41 pm
I am running Raspberry pi with raspian installed.
Due to wrong entries in wpa_supplicant file, my pi is stuck in an endless DHCPDISCOVER mode during boot of my device.
How can i stop the loop and edit wpa_supplicant file again? I tried to press multiple keys on my keyboard but nothing worked.
Sending on   Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
No DHCPOFFERS received.
Regards,
Christian
MrEngman
Re: DHCPDISCOVER in endless Loop on startup
Wed Dec 25, 2013 1:57 pm
Unplug the wifi adaptor maybe?
MrEngman
cpfeil
Wed Dec 25, 2013 9:19 pm
MrEngman wrote:Unplug the wifi adaptor maybe?
MrEngman
no, this does not help. It continues to run in a loop. I have no possibility to run sudo nano to edit the wpa_supplicant again.
Any ideas?
Christian
bananaPi
Tue Dec 31, 2013 12:07 pm
If you have the possibility, you could take the sd card off and edit the file on another computer. Note that if it is not a Linux-machine, you may need to install the drivers for the EXT-2 filesystem (should be freeware or open source).
