MrEngman
Re: Edimax Wi-Fi adapter not functioning correctly
Wed Dec 25, 2013 1:42 am
Well if it's any help I usually use this format for /etc/network/interfaces file
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "network-name"
wpa-psk "network-password"
Works with all the wifi adaptors I have including the EW7811Un.
And adding additional wlan sections (wlan1, wlan2 etc.) with the same format and I can connect more than one wifi adaptor at the same time.
MrEngman
7ewis
Wed Dec 25, 2013 2:46 pm
MrEngman wrote:Well if it's any help I usually use this format for /etc/network/interfaces file
auto lo
allow-hotplug wlan0
MrEngman
Tried this earlier today, and the adapter is actually flashing constantly now, but it still doesn't want to connect to my Wi-Fi. If there are spaces in the SSID, it doesn't need to have \ in-between the words or something does it?
What is the normal flash? I can't remember but mine is flashing constantly then may pause for a second or two, then resume the constant flashing.
Raspberry Pi - Model B (512MB)
MrEngman
Wed Dec 25, 2013 4:02 pm
Not sure about spaces in the SSID. Looked around using Google and there were conflicting reports, some saying it's OK and others that it doesn't work like you are finding at the moment. Could be worth trying without a space if you can.
My adaptor flashes on approx. once a second or probably just a little faster. It flashes 4 or 5 single flashes and then one double flash, two very short flashes, repeating the sequence continuously.
MrEngman
