Transmission Device Full?
Posted: Fri Dec 20, 2013 11:39 pm
I am using the Transmission Web UI on my headless Raspberry Pi torrentbox, I have a 64GB USB plugged in and mounted but when I try to download it says the device is full. I did fdisk -l and df -i here is the output:
Any idea how I should fix this?
Thanks,
Bgordy
pi@raspberrypi ~ $ sudo fdisk -l
Disk /dev/mmcblk0: 7884 MB, 7884242944 bytes
4 heads, 16 sectors/track, 240608 cylinders, total 15398912 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000eb461
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 8192 2507812 1249810+ e W95 FAT16 (LBA)
/dev/mmcblk0p2 2514944 15333375 6409216 85 Linux extended
/dev/mmcblk0p3 15333376 15398911 32768 83 Linux
/dev/mmcblk0p5 2523136 2646015 61440 c W95 FAT32 (LBA)
/dev/mmcblk0p6 2654208 15333375 6339584 83 Linux
Disk /dev/sda: 64.0 GB, 64016220160 bytes
255 heads, 63 sectors/track, 7782 cylinders, total 125031680 sectors
Disk identifier: 0x3487e3fe
/dev/sda1 32 125031679 62515824 7 HPFS/NTFS/exFAT
pi@raspberrypi ~ $ df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
rootfs 396704 74597 322107 19% /
/dev/root 396704 74597 322107 19% /
devtmpfs 53956 342 53614 1% /dev
tmpfs 56022 289 55733 1% /run
tmpfs 56022 1 56021 1% /run/lock
tmpfs 56022 2 56020 1% /run/shm
/dev/mmcblk0p5 0 0 0 - /boot
tmpfs 56022 3 56019 1% /tmp
/dev/sda1 62480944 16 62480928 1% /home/pi/TorrentStorage
Thanks,
Bgordy
