djrosu
raspistill preview resolution not correct?
Wed Dec 18, 2013 9:01 pm
I have a strange problem with the raspberry pi camera and raspistill. I have a rpi with the camera module connected to an 1920x1080 monitor. It boots up in the correct resolution.
When I run the following command on the conole:
raspistill -ex auto -awb auto -w 1920 -h 1080 -p '0,0,1920,1080' -v -o test.jpg
The camera preview seems to be "zoomed in" and the actual capture resolution of 1920x1080 is only shown for a brief moment when the actual screen capture happens. I noticed that when I run the command above replacing -p '0,0,1920,1080' with -fp the same thing happens but the output of raspistill shows " Preview window 0,0,1024,768" instead of " Preview window 0,0,1920,1080". I am confused.
Any ideas?
Below is the output of raspistill:
raspistill Camera App v1.3.5
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen No
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera preview port to video render.
Connecting camera stills port to encoder input port
Enabling encoder output port
Starting capture 0
Finished capture 0
Closing down
Close down completed, all components disconnected, disabled and destroyed
Re: raspistill preview resolution not correct?
Wed Dec 18, 2013 9:10 pm
Yes, it's a known bug - the video preview mode runs at a different resolution to the full stills capture mode. I need to generate a new mode that enables full field of view video at 30fps but I haven't had time.
djrosu
Tue Jan 07, 2014 3:50 pm
Ok, if you can point me to the general area of the relevant code in raspistill.c I may have some time to take a look...
Tue Jan 07, 2014 4:12 pm
It's not a bug in the app, it needs a new mode in the GPU camera driver to handle full frame 30fps. I tried one the other day but it didn't work - need some tech help from my boss when he's not too busy.
djrosu
Tue Jan 07, 2014 6:53 pm
Ahhh... ok. Will it display the proper preview resolution at 15fps? Is there a way to force it to that frame rate?
Wed Jan 08, 2014 10:13 am
There is the full preview mode which should do that but the last time I tried it it didn't do what I expected. Give it a go...
djrosu
Thu Jan 30, 2014 3:27 pm
The full preview mode doesn't work either (behaves the same) as I described in my original post. Am I using it wrong? The command I used was posted also.
djrosu
Thu Feb 06, 2014 3:23 pm
Any progress on this issue? If there is any way I can help implementing a proper video mode to enable the preview match the actual capture resolution I am willing... Thanks!
Thu Feb 06, 2014 4:26 pm
Still working on in when we can. Busy at the moment though of actual work. I'll check with the boss to see if he has made any progress.
Not much others can do I'm afraid.
dsangree
Tue May 19, 2015 2:31 am
Was this ever resolved?
fc_key
Fri Jan 06, 2017 10:30 pm
Hey guys
I'm running into the exact same problem, when does this get fixed? With the resolution 720p the preview and the picture match perfectly on a full hd tv
Thank you for the soon answer :)
Friendly greetings fc_key
Sat Jan 07, 2017 11:51 am
fc_key wrote:Hey guys
Not sure when this will be fixed. The RPF are taking on some more people soon to work on this sort of stuff. Is this reported in the github repo?
fc_key
Sat Jan 07, 2017 12:50 pm
Thank you for the answer, can you help me out, was is meant with "is this reportet in the github repo?"
Sat Jan 07, 2017 1:34 pm
In order to keep track of what needs to be fixed, the github repo has a bug tracker, which is used by the RPF to keep track of everything that needs doing.
https://github.com/raspberrypi/userland/issues
Check to see if bug is already there, if not, you can easily add a new one, give as much detail as possible to make it easier to diagnose.
fc_key
Mon Jan 09, 2017 10:52 am
Thank you for the answer: Here is the link for the reported issue: https://github.com/raspberrypi/userland/issues/363
6by9
Mon Jan 09, 2017 12:44 pm
I've just commented on github.
Not a userland or firmware issue, but due to the way PiCamera sets up the pipeline. I believe it was addressed in a recent update but can't see the relevant docs.
fc_key
Mon Jan 09, 2017 9:04 pm
Hey hi there, i commented on the githup, because some things seems a little strange to me, but maybe I'm wrong :D
